Unsolved Release 3.01-RC10
Good morning and good May 1st
Well I have a problem that repeats itself every time I homing, then I thought the last problem had been the fault of the nozzle blocked by the filament, in part yes, it blocked because the extruder motor stops, now I understood the reason, the tests I did are all without filament in order not to damage the nozzle, I describe what I did:
1: I set the temperature to 180 in order to have the extrusion and retraction buttons active the drive buttons work very well and the motor responds
2: if I homing all the axes and retry the procedure n.1 the extruder no longer works
3: I did the single homing of the axes
4: homing x axis and retrying the extruder and it works
5: homing y axis and retrying the extruder and it works
6: z axis homing and try again the extruder does not work
I tried to load the fw one by one starting from 3.0 until the last beta and the problem persists,
7: I removed the sd and reformatted and loaded the fw but nothing happens
Any suggestions on this?
for @ dc42
m92
Steps / mm: X: 80.000, Y: 80.000, Z: 400.000, E: 424.000
M906
Motor current (mA) - X: 800, Y: 800, Z: 800, E: 800, idle factor 30%
M913
Motor current% of normal - X: 100, Y: 100, Z: 100, E: 0
m563 p0
Tool 0 - drives: 0; heaters (active / standby temps): 1 (180.0 / 0.0); xmap: X; ymap: Y; fans: 0; status: selected -
to restart the engine I have to reset with the command M999
@Leblond said in Release 3.01-RC10:
Please post your homez.g file.
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
G91 ; relative positioning
G90 ; absolute positioning
G1 X60 Y50 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z10 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
now I have mounted the fw 2.05 to see if even with this it does the same problem
Is the tool still selected when you have this problem? Send T by itself to report the current tool number.
@dc42 ok I reassemble the FW and then I tell you
@dc42 made reloaded FW 3.01-RC10
yes the tool is always active
1/5/2020, 14:51:33 T
Tool 0 is selected -
@dc42 I compress all the sd and send it to you?
it still does not work
the engine practically vibrates as if it were stalled
@dc42 I confirm that with version 3 of the fw I have this problem, but with the version of FW 2.05 everything works great, so I will continue to use FW 2.05, until you can understand where the problem lies
Hi everyone, have you discovered anything about my problem?
good morning guys
I have found that by sending the axes home manually one at a time starting with x, y and z, the extruder works -
but as soon as a g28 is made it no longer works and the extruder stalls
I also installed Release 3.01-RC12 ma niet
for @dc42 no idea?
Guys forgive me if I insist, but it seems strange to me that only I have a problem with a brand new card and you can't find a solution
When you send "G28" or "G28 Z" ?
Can you post homeall.g?
good morning guys
I have found that by sending the axes home manually one at a time starting with x, y and z, the extruder worksG28 X
Extruder Works
G28 Y
Extruder Works
G28 Z
Extruder WorksG28
Does not work? -
it is exact only when sending g28 the extruder stalls
