Release 3.01-RC10
@dc42 ok I reassemble the FW and then I tell you
@dc42 made reloaded FW 3.01-RC10
yes the tool is always active
1/5/2020, 14:51:33 T
Tool 0 is selected -
@dc42 I compress all the sd and send it to you?
it still does not work
the engine practically vibrates as if it were stalled
@dc42 I confirm that with version 3 of the fw I have this problem, but with the version of FW 2.05 everything works great, so I will continue to use FW 2.05, until you can understand where the problem lies
Hi everyone, have you discovered anything about my problem?
good morning guys
I have found that by sending the axes home manually one at a time starting with x, y and z, the extruder works -
but as soon as a g28 is made it no longer works and the extruder stalls
I also installed Release 3.01-RC12 ma niet
for @dc42 no idea?
Guys forgive me if I insist, but it seems strange to me that only I have a problem with a brand new card and you can't find a solution
@Leblond said in Release 3.01-RC10:
When you send "G28" or "G28 Z" ?
Can you post homeall.g?
good morning guys
I have found that by sending the axes home manually one at a time starting with x, y and z, the extruder worksG28 X
Extruder Works
G28 Y
Extruder Works
G28 Z
Extruder WorksG28
Does not work? -
it is exact only when sending g28 the extruder stalls
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
G91 ; relative positioning
M913 X50 Y50 ; Riduci la corrente al 50%
G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-9999 ; home X axis
G1 H1 Y-9999 ; home Y axis
G1 X5 Y5 F2000 ; go back a few mm
G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-9999 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X60 Y50 F9000 ; go to first bed probe point and home Z
M913 X100 Y100 :Riporta la corrente al 100%
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z10 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
; homeall.g
;G90 ; absolute positioningCan you try:
;homeall.g G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position ;;;M913 X50 Y50 ; Riduci la corrente al 50% G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass) G1 X5 Y5 F2000 ; go back a few mm G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-9999 F360 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X60 Y50 F9000 ; go to first bed probe point and home Z ;;;M913 X100 Y100 :Riporta la corrente al 100% G30 ; home Z by probing the bed
@sebkritikel ok now i try
@sebkritikel said in Release 3.01-RC10:
91/5000wait because it gives me an error "6/5/2020, 18:12:41 G28
Error: G0 / G1: insufficient axes homed " -
This post is deleted! -
Error: G0 / G1: insufficient axes homed "Ok maybe my mistake. Please try:
;homeall.g G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position ;;;M913 X50 Y50 ; Riduci la corrente al 50% G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-9999 ; home X axis G1 H1 Y-9999 ; home Y axis G1 X5 Y5 F2000 ; go back a few mm G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-9999 F360; then move slowly to Y axis endstop G90 ; absolute positioning G1 X60 Y50 F9000 ; go to first bed probe point and home Z ;;;M913 X100 Y100 :Riporta la corrente al 100% G30 ; home Z by probing the bed
