Spurios "sensor not work" and not enough movement faults
@clegg78 said in Spurios "sensor not work" and not enough movement faults:
I am seeing the exact same issues, I have a few other posts in this category abou tit as well... Its incredibly frustrating. I just had to disable the sensors entirely to keep them from screwing up prints. As someone noted, even setting the M591 Dx to S0 wont stop "Sensor Not Working" errors. I've gotten the "Sensor Not working" errors on the extruder that wasnt even being used in a print before! (I have an IDEX rig)
You have to set to M591 Dx S0 P0 to fully disable the sensor(s) to stop the errors.
I am happy someone else is seeing this problem cause its driving me insane.
I've also done new wires, new crimps, shorter wires, even had a sensor RMA'd to see if that helped. I also tried differnet endstops (CONN_LCD and E1/Z endstops) per @dc42 @droftarts and others recommendations.
It is incredibly frustrating! I just sanded a good bit of the pcb side of the housing down and was able to get the AGC down to around 80. I then did right at a 2 hour print with absolutely NO errors or pauses, which is the longest print i've had go error free since i installed it !
The range of output was between 84% and 104%, which was a significant increase as well.
I'm about to do a 8 hour print, so fingers crossed it actually helps!
well so much for those good vibes. 20 minutes into the print and it error'd with "Extruder 0 reports not enough movement"....
I had several not enough movement errors when I first installed the mag sensor. I was able to flash the firmware up to version 3 which did not really help, but it did show that the agc was in a good place, stays around 70. I had to really go through my printer and make sure everything was spot on. Delta, 1 meter Bowden tube, E3d V6 hot end and Duet smart effector. The big break through was reducing the exstruder motor current from 2400 to 2150 and then setup PTFE tubing from the filament spool to the monitor so that there is about 6 inches of tubing that directs the filiment straight into the monitor, no binding at monitor entrance. I have had this setup for some months now and rarely have movement issues and when I do there is always a reason, usually a slightly clogged nozzle. My printer is truely a load and go machine thanks to this monitor and the turning I had to do to make it work properly.
How do you update the firmware in the sensor? I am getting 'not enough movement' errors but my sensor does not report the 'AGC' value cheers
@invertmast said in Spurios "sensor not work" and not enough movement faults:
@invertmast, are your AGC readings still consistently below 100?
@CTRDevelopments, updating the firmware requires an AVR programmer (e.g. USBASP) and a 2.54mm pitch 2x3 pogo pin adapter such as this https://www.tindie.com/products/nicody/pogo-pins-2x6/ or https://www.sparkfun.com/products/11591.programming-/253682618407 or https://www.ebay.co.uk/itm/POGO-ICSP-AVR-Pogo-Pin-ICSP-ISP-Adapter-Kit/153891594446.
@dc42 said in Spurios "sensor not work" and not enough movement faults:
dc42 , thanks. Would this work as the programmer?
https://www.amazon.co.uk/ARCELI-Programmer-ATMEGA8-ATMEGA128-Support/dp/B077WRT87B/ref=sr_1_1?dchild=1&keywords=USBASP&qid=1588138376&s=electronics&sr=1-1 -
@CTRDevelopments probably, but i'd consider either a genuine usbasp or a clone of something that isn't usbasp as the clones can be notoriously troublesome.
also check the links in this post if that is something you can use https://forum.duet3d.com/post/147110
@bearer thanks for this, I dont want something that will cause more issue than its worth!
I get pauses like this which I am confused about as it looks to me like it is within the limits set?
Rather than me mess it up can i send the unit back to get reprogrammed? It is causing me more hassle at the moment as it keeps stopping the print for no reason
@CTRDevelopments said in Spurios "sensor not work" and not enough movement faults:
I think we can arrange that. Which country are you in?
@dc42 UK, happy to post where ever needed. thanks
@dc42 If I purchase a new unit will it come with the newest firmware? Thinking it might be cheaper than sending this one back
I'm sorry, I missed your reply of 1 May. You are welcome to send it back to me for reprogramming at: Woodpeckers, Wearne, Langport TA10 0QQ. If you send just the PCB, in an antistatic bag and a padded bag, then it should be thin enough go as a large letter which will reduce the postage.
DC, OK, will do thanks. It just paused my print reporting -4% movement? IS this any sort of clue as to what the issue could be?
@dc42 I bought mine about a year ago from Filastruder and gave up when it wouldn't work. I think mine is a firmware issue as well. It's probable an early one because the serial # is 015. I have my min set really low, M591 D0 P3 C3 S1 R10:130 L24.7 E3.0. It starts off fine and prints for a while with a min of 93% and then drops to 24%, stays there for a while and eventually will drop again. If I pause it without doing anything to the filament or changing anything it goes back to normal 93%. My extrusion is fine and no clogs. Would it be possible for me to exchange it with Filastruder? I know it was a year ago but I never could get to work.
Thanks -
@chickenwoman said in Spurios "sensor not work" and not enough movement faults:
ThanksHi, sorry to hear you've had some issues, please contact Filastruder and seek an exchange. Refer them to this post as authorization. Normally it would only be a 6 month warranty window but in this instance we will do an exchange.
@Phaedrux Thank you, I appreciate it.
