RRF 3.01-RC10, DWC 2.1.5 and DSF 2.1.1 released
@Silrocco The file you are looking for (DuetMaestroIAP.bin) is available here: https://github.com/dc42/RepRapFirmware/releases/tag/3.0 Please upload that before you upload the firmware file.
Thanks. I'm currently printing a part so when done I'll attempt uploading it.
is the github repo fully up to date? It is tagged as RC10, but the Version.h file claims to be RC9+1 (and this is the version reported by DWC when using an LPC build).https://github.com/dc42/RepRapFirmware/blob/3.01-RC10/src/Version.h
Thanks!
I'm sorry, it looks like I may have failed to commit that file before I did the release. That was the very last change I made. All other changes were in previous commits.
If that is the only file I wouldn't worry about it David.
Uploading DuetMaestroAP.bin didn't work either, getting an infinite upload status for minutes that I have to cancel out.
@gloomyandy said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
I'm not worried - I just need to avoid making the same mistake when I do the 3.01 stable release
@Silrocco said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
Is that repeatable? What is the file size of the DuetMaestroAP.bin file on your PC?
Duet WiFi, Ethernet and Maestro: a default bed heater is no longer created, so you need to use M140 H0 in config.g if you want to replicate the prevous behaviour. The online configurator already generates this command automatically when you configure a bed heater. Any M143 H0 command must come later in config.g than the M140 H0 command, because M140 resets the temperature limit for the heater to the default for bed heaters.
This is confusing to me so need to check. M140 is used to set the bed temp? What is new, to set the bed temp we now need to do
M140 H0 S100
in g-code for the job or ? Why would that ever be in config.g ? Shouldn't config.g only beM308 S0
to define bed temp sensor andM950 H0
to create bed heater?Am I missing something or ?
M140
RepRapFirmware also provides an optional 'H' parameter to set the hot bed heater number(s). If no heated bed is present, a negative value may be specified to disable it. M140 commands with H parameters would normally be used only in the config.g file.
So maybe
M140 H0 P0
does what's required? if it does, I have to say it's not clear from the documentation few more words would have to be added both for M950 and M140 -
i am not able to get heat bed configured:
M308 S0 P"bed_temp" Y"thermistor" T100000 B4250 R4700 ; define bed termistor sensor M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
once i issue M140 S40
Error: M140: No bed heater has been configured for slot 0
and i do no see heat bed on DWCwhat is wrong? please advice how to treat it
In response to the last 2 posts: READ THE UPGRADE NOTES!!!!
Why do I bother to write them?
@arhi https://duet3d.dozuki.com/Wiki/Gcode#Section_M140_Set_Bed_Temperature_Fast
It's basically just telling the firmware that heater is a bed so that it uses appropriate values for a bed heater by default. There have been many people with issues where their bed would give heater faults for heating too slowly because the firmware was expecting it to act like a hotend by default. This change just informs the firmware that it is a bed again.
At least I think that's what's going on.
@dc42 I did, and I got it working but is very unclear
I created a heater already so "no longer created", but I just did .. I just added the code and it works but ... maybe
"default bed heater is no longer auto assigned, so you need to assign it using M140; use M140 H0 in config.g ..."
I know I'm nitpicking and you have more important things to do but looking at M140 amd M950 there's nothing about assigning heater to this or that
@arhi said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
The upgrade notes are:
Upgrade notes:
If you tell me what you didn't find clear, I will try to improve the text.
@Phaedrux said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
If you look my question I c/p both related paragraphs from the documentation.
1st issue - heater is already created with M950 so what's being "created again". reading your comment it looks like heater is being assigned .... ok, makes sense that's required, just needs to be properly documented
2nd issue - M140 is "set bed temp fast" .. there is zero chance a normal person will look there to find how to assign a heater to be a bed heater ... like negative infinite
again, nitpicking but maybe, just maybe someone find it useful, if not well sorry for wasting everyone's minute
@dc42 said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
I really don't want to waste your time nitpicking so apologies but .. sometimes stronger then me ... so ..
this part:
this makes no sense to me, I created the heater already and there is nowhere in the g-code documentation about other way of creating a heater.
Now using something like "is no longer assigned to bed" or some wording like that with updating M140 to explain H is assigning heater id to bed heater id would imo solve the problem
I've changed the M140 (and M141) headings and text in the GCodes wiki page, and changed "created" to "assigned" in the upgrade notes. I hope this will help make it clearer.
based on our discussion here i have updated g-code M140 documentation with the note and sample error.
personally I read release notes and could not figure out what to do with M140...perhaps we should rename M140 from "Set Bed Temperature (Fast) " to
"Configure Bed Heater or Set Bed Temperature (Fast)"any thoughts?
@c310 said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
I've already done that.
