Duet WiFi and stepper motor Failrues
@idmurp Did you check each of the 'failed' motors on a different stepper driver? Was it just on Y that the motors lose torque? I can't think of anything off-hand that can 'kill' a stepper motor; even if one coil shorts, the other should hold it. Please test the resistance of each coil pair on each motor, if you have a multimeter, as this is really the only way you'll know for sure.
The problem with the Z hop is, most likely, your acceleration on Z is set to high, though if you only have a motor on one side of Z, could well be binding.
Also, please post your config.g.
COnfig.g below
Tested the steppers using muktimeter, broken ones have identical resistance to non broken.
Have tested another motor on the Y drive cable and they have the correct torque, not tested the "broken" motors on another cable yet. WIll do once I have finished work
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.3 on Tue Nov 26 2019 20:50:06 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CR10 400" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards X axis M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E91.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X400 Y400 Z400 S0 ; set axis maxima ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstops controlled by probe ; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H8 F500 T2000 A5 R0.5s ; set Z probe type to bltouch and the dive height + speeds G31 P25 X-47 Y-5 Z1.9 ; set Z probe trigger value, offset and trigger height M557 X15:385 Y15:385 S30 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1.6 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Can can confirm that the weak stepper is now weak on both the X and Y Axis circuits. If I plug a new motor into either of those circuits it works fine.
The stepper is now at fault, and its the 3rd occuance in 2 different makes of steppers on this printer which has hardly seen any use.
Do the stepper motors have permanently-wired cables, or detachable cables?
@idmurp said in Duet WiFi and stepper motor Failrues:
17HS4401S
Are these the motors? https://www.amazon.com/Usongshine-nema-17-Stepper-Motor/dp/B07KW6B3ZX?th=1
Rated current is listed as 1500ma and you have 800ma set. It's generally recommended to use 70-85%. So 800 is a little low which could explain the lack of torque. Try 1200ma.
I've never seen anything like multiple motor failures like this before. I would expect a driver to go before a motor.
@dc42 Permenant wires
One of the most common causes of weak motors is a bad crimp connection between the cable and the crimp pin in the Duet connector. Have you tried crimping a new connector on the leads of one of the failed motors?
@dc42 No but I have swapped the motor for a new one, which worked fine. Then put the old one back on and that still had the low torque
okay as it does not seem to be anything obvious. I know this has happened twice on Y so.
Printer is not earthed so earth it
I believe I can remap extruder 2 stepper to be the Y drive so do this.
Use a new fresh and tested cable
Use a new motor for Y drive.
Put a cooling fan on Y drive stepper
bump all of them up to 1200 maThis gives me a essentially fresh start on the Y drive.
is there any chance it could be power supply related? I could swap the power supplies over and use the current heated bed supply for the board.
Then hope....
Any other suggestions?
The only thing that seems unique to your setup is the dual power supply. can you post how you have it all wired up?
Lack of grounding is concerning. How is it grounded now?
@Phaedrux said in Duet WiFi and stepper motor Failrues:
240V to the 2 power supplies from a common plug.
First power supply, 30 amp on a 20 amp fuse powers the board
The second power supply just provides power to the mosfet that powers the bed, 30 amp fuse, it is not connected in any other way to the printer. I can run the printer with the second power supply disconnected alltogether if I dont want a heated bed.
Its a 400X400 printer, I need close to 30 amps just for the bed and had 2 30 amp power supplies to hand.
They do share a common earth bar, something I might change though I dont see how that would affect anything.
The power supplies are grounded, there is no ground on the board or printer itself. WIll ground the printer next
If the cables are not detachable from the stepper motor, you must have used the new cable that came attached to it. That's why I suspect the crimp connections.
@dc42 Cables came with it but not attatched, they are plugged into the stepper via a removable plug.
In other news this looks similar to my problem and was blamed on static build up...
In way of an update I have:
Replaced Y drive and succesfully tested other steppers
Repalced Y drive cable
Remapped Y drive to extruder 2
Grounded the printerI am rerunning the setup and calibration today
Tomorrow Ill work from the same room as the printer and set a long print running, will give me 8-9 hours to monitor temps etc to see what happens -
Our wiki page https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors includes this:
Note: it is highly recommended that the stepper motor casings be grounded, especially in belt-driven printers. Otherwise, motion of the belts causes static charge to build up, which eventually arcs over to the windings. If the motors are screwed to a metal frame, grounding the frame is sufficient.
So I have done all of the above and have now done a reasonable amount of test prints without killing a further stepper....so far. Im suspecting it was static build up, but cant be sure
Have other problems now but all fixable.
Will update further if I do kill another stepper, but so far so good!
