Did I break the fans?
@drmaestro said in Did I break the fans?:
Do I need to make some change to the m106 commands at the config files before giving these commands?
The commands in config.g would be pretty much the same, so no.
Are you using RRF2 or RRF3? If using 3, you'd need to have some M950 commands in config.g to create the fan pins before M106 can address them. In RRF2 the fan pins are pre-defined.
That all said, it really does sound like you've damaged the fan mosfets.
@Phaedrux I am on RRF2. Is it possible to damage all three mosfets at the same time, even though 2 of them weren't connected to any fans and the non PWM fans are working?
No, only the one that had the output shorted is likely to have been damaged.
Fan 1 is configured in thermostatic mode by default, so you would need to disable thermostatic mode before you can control it manually.
@dc42 Here are the relevant sections on my config file:
M563 P0 D0 H1 F1; Define tool 0 (I added the F1 to be able to assign the second PWM fan to my hotend)
M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. (Thermostatic control is turned off by using H-1 and removing the T command)
Am I doing anything wrong on the config part?
@drmaestro I think that looks ok.
After that's been set, can you turn on the fan with M106 S1?
@Phaedrux Nothing happens. Is there a way to test the problem using a multimeter?
sure, you could probe the mostfets with the diode junction function. you could measure the voltage at the gate to confirm its getting a signal from the processor.
@drmaestro Long shot; does your Duet have a fan fuse (Duet 2 Wifi/Ethernet v1.03 and later)? Have you checked it?
But does sound like the MOSFET has failed.
@bearer What should the voltage be when m106 S1 command is given?
@droftarts It doesn't have a fan fuse, it is an earlier Duet WiFi (1.02 maybe) which also didn't have the fuse for the heated bed (I had to solder a fuse to the board when the smd component burned 2-3 years ago).
Also, is it normal that I am reading 12.4 volts at the fan wire (measured from the Dupont connector side) when the fan is set to 0 and the fan is not connected but if I connect the fan the voltage drops to 1.2 volts?
@drmaestro MOSFETS switch on the ground (or negative) side, so you will always read 12V (if VIN is 12V and the V_FAN JUMPER SELECT is on the VIN and V_FAN pins) on the positive pin. The voltage drop is probably explained by a failed MOSFET, but you really need to check it with a multimeter as @bearer suggested.
My Duet Wifi daily-driver is a pre-production white PCB version; no fuses and some of the pins are a different way around! Haven't managed to kill it yet...
I'd test without power and according to the google search link, far too much to repeat in a post here.
if not, you should have close to 3.3v on the gate when the fan is on, and Vin on the source pin of the mosfet.
I've had an idea today about the fan and would like to ask your opinion on the subject. Until I can fix the board, I was thinking of a temporary solution, which is to connect the part cooling fan to the always on connector. That way, I can cool the part. I understand that the slicing software can vary the amount of cooling depending on the contents of the layer, so this isn't an ideal solution but it is better than not having part cooling for PLA prints. The only problem is how to turn it off for the first 3-4 layers, so that the part can stick to the bed. Right now, I am pausing the print at the 4th layer ans disconnecting the fan connector at the hotend but I am not very comfortable leaving unconnected wires around the hotend. I've found some fan controllers at Aliexpress (for example https://www.aliexpress.com/item/32983495011.html?spm=a2g0o.productlist.0.0.165062189TcZdL&algo_pvid=46d10c0f-61a5-4856-ba09-ca38e93a022d&algo_expid=46d10c0f-61a5-4856-ba09-ca38e93a022d-0&btsid=0ab6d70515864703710462983e2ec8&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_) . Would it be advisable to use them?
Those would probably work to allow you to manually control the fan speed while using the always on connector.
A simple latching switch could work too.
