No output from G32 on DSF 1.2.4 / DWC 2.07
@chrishamm Brilliant. Quick question, sorry to polute this topic, but were you able to implement conditional gcode in this version of dsf?
Just updated to 2.1.0. Think I have found an issue.
I cannot load my Height Map.
I have check the file is there and there are numbers in it but it tells me height map not available.Have rebooted my Maestro and it still is not displaying.
Regards,
Paul
@mvieleers I hope I can get conditional G-code working in DSF next week.
@PaulHew Load the heightmap and it should be automatically displayed. I'll add a file list next to the 3D viewer at some point to avoid confusion.
@chrishamm said in No output from G32 on DSF 1.2.4 / DWC 2.07:
Have pressed the 'Reload height map' button and it will not load.
I will rename the current heightmap.csv and run another.
Regards,
Paul -
Cool!
@PaulHew I have the same issue. After I ran a G29, it displays correctly.
Re-ran Mesh Compensation and still will not display height map.
File is there
@chrishamm
Update, put DWC2.0.7 back on and height map is displayed.Regards,
Paul -
@chrishamm
All fixed with 2.1.1 Thank you. -
Glad it's working now. The issue with G32 not showing any output should be fixed in DSF 1.3.1, too.
Great news. I'll have to stop printing face shields long enough to upgrade and test!
Yay!! I'm still new with 3 motor beds, and it really helps to see the output. Yay!!
@Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
I strongly recommend using a script to auto level until it's under a set value, with a Z home at the end. I've been doing that with one of my printers, and it's been awesome. The other day I had a bit of filament stuck right where my probe hits one spot, and so it couldn't level correctly. It failed to level under my set value, so I went to check and found the filament. Might have saved me a bed surface!
@kraegar said in No output from G32 on DSF 1.2.4 / DWC 2.07:
That is exactly what I do. And check the console output to see that it is converging.
Literally called "prepz.g"
@chrishamm This is indeed correctly working now in DSF 1.3.1. Great job! Thanks! As this was the original issue, I guess this topic can be closed now.
@chrishamm Just to make sure I'm not doing anything wrong...conditional gcode is not yet in dsf 1.3.1, correct?
This has been driving me crazy for months - can confirm console output is restored for G32 (and others for me) with with 2.1.1
Thank you.
