No output from G32 on DSF 1.2.4 / DWC 2.07
@chrishamm
Update, put DWC2.0.7 back on and height map is displayed.Regards,
Paul -
@chrishamm
All fixed with 2.1.1 Thank you. -
Glad it's working now. The issue with G32 not showing any output should be fixed in DSF 1.3.1, too.
@chrishamm said in No output from G32 on DSF 1.2.4 / DWC 2.07:
Great news. I'll have to stop printing face shields long enough to upgrade and test!
Yay!! I'm still new with 3 motor beds, and it really helps to see the output. Yay!!
@Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
I strongly recommend using a script to auto level until it's under a set value, with a Z home at the end. I've been doing that with one of my printers, and it's been awesome. The other day I had a bit of filament stuck right where my probe hits one spot, and so it couldn't level correctly. It failed to level under my set value, so I went to check and found the filament. Might have saved me a bed surface!
@kraegar said in No output from G32 on DSF 1.2.4 / DWC 2.07:
That is exactly what I do. And check the console output to see that it is converging.
Literally called "prepz.g"
@chrishamm This is indeed correctly working now in DSF 1.3.1. Great job! Thanks! As this was the original issue, I guess this topic can be closed now.
@chrishamm Just to make sure I'm not doing anything wrong...conditional gcode is not yet in dsf 1.3.1, correct?
This has been driving me crazy for months - can confirm console output is restored for G32 (and others for me) with with 2.1.1
Thank you.
