RepRapFirmware 3.01-RC6 released
@ChrisP It looks like you have a PanelDue connected to your Duet 3 and that is not fully supported yet while the Duet 3 is operating in SBC mode. At present the only transmitted command from the firmware to DSF is M20 which you can see in the logs. So I suggest don't use the PanelDue for anything else than pausing prints (not resuming) or emergency stops in SBC mode until support for PanelDue has been fully implemented.
Can you share the output of M122 if you are certain the firmware reset unexpectedly?
@chrishamm
You are absolutely correct that I have a PanelDue connectedI hadn't anticipated that this could be part of the problem since i'ts been connected since it has always been connected to the Duet3 from the first time I set it up over a few weeks ago. I was aware that it had limitations but have kept it there as an easy way to view teh temperatures and print progress - I don't use it for anything onther than displaying info currently. With previous firmwares / DCS it's been operating fine. That said, I'll take the advice and remove it for now.
Is there a was that I can issue M122 and grab the result from the Pi as when the crashed happen, the web interface becomes totally unresponsive and requires me to press the hardware reset on the Duet3 to bring things back to life?
edit: I will unplug the PanelDue, power cycle and try the print again.... I'm only running test prints currently to ensure the system is stable... clearly not quite ready for a proper print yet
@ChrisP It sounds like there is a problem in DCS and I'll be happy to look into it. To obtain some debug info, please connect to your Pi via ssh, run
sudo journalctl -u duetcontrolserver -en 100 --no-pager
, and share the output you get.PS: It's fine to leave the PanelDue attached but be aware that most file-related commands will not work as expected.
@ChrisP said in RepRapFirmware 3.01-RC6 released:
log in using ssh and do
echo M122 | sudo /opt/dsf/bin/CodeConsole
should work if DuetControlServer is still running, if that is not the case, you'll need to connect to the Duets micro USB port and use it as a serial console. -
@chrishamm said in RepRapFirmware 3.01-RC6 released:
, and share the output you get.Thanks for the help. I'm running this as a test machine anyway, so I'm happy to test anything on it if it'll help move forward. Here's the log from a fresh boot (with PanelDue disconnected):
-- Logs begin at Thu 2019-02-14 10:11:59 GMT, end at Sat 2020-04-04 12:33:27 BST. -- Apr 04 12:28:50 starttex systemd[1]: Started Duet Control Server. Apr 04 12:28:52 starttex DuetControlServer[350]: Duet Control Server v1.3.0 Apr 04 12:28:52 starttex DuetControlServer[350]: Written by Christian Hammacher for Duet3D Apr 04 12:28:52 starttex DuetControlServer[350]: Licensed under the terms of the GNU Public License Version 3 Apr 04 12:28:54 starttex DuetControlServer[350]: [info] Settings loaded Apr 04 12:28:55 starttex DuetControlServer[350]: [info] Environment initialized Apr 04 12:28:55 starttex DuetControlServer[350]: [warn] Downgrading protocol version 2 to 1 Apr 04 12:28:55 starttex DuetControlServer[350]: [warn] Incompatible firmware, please upgrade as soon as possible Apr 04 12:28:55 starttex DuetControlServer[350]: [info] Connection to Duet established Apr 04 12:28:55 starttex DuetControlServer[350]: [info] IPC socket created at /var/run/dsf/dcs.sock Apr 04 12:28:55 starttex DuetControlServer[350]: [info] Executing system macro file config.g on channel Trigger Apr 04 12:28:56 starttex DuetControlServer[350]: [warn] Deprecated firmware detected, please update it in order to use DSF Apr 04 12:28:56 starttex DuetControlServer[350]: [warn] Deprecated firmware detected, please update it in order to use DSF Apr 04 12:28:57 starttex DuetControlServer[350]: [info] Trigger: Finished system macro file config.g Apr 04 12:31:48 starttex DuetControlServer[350]: [info] System time has been changed Apr 04 12:32:05 starttex DuetControlServer[350]: [info] Flashing IAP binary Apr 04 12:32:05 starttex DuetControlServer[350]: [info] Flashing RepRapFirmware Apr 04 12:32:11 starttex DuetControlServer[350]: [info] Verifying checksum Apr 04 12:32:14 starttex DuetControlServer[350]: [info] Firmware update successful Apr 04 12:32:14 starttex DuetControlServer[350]: [fatal] Abnormal program termination Apr 04 12:32:14 starttex DuetControlServer[350]: [fatal] SPI task faulted Apr 04 12:32:14 starttex DuetControlServer[350]: System.Exception: Invalid protocol version 2 Apr 04 12:32:14 starttex DuetControlServer[350]: at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1130 Apr 04 12:32:14 starttex DuetControlServer[350]: at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean mustSucceed) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 157 Apr 04 12:32:14 starttex DuetControlServer[350]: at DuetControlServer.SPI.Interface.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 744 Apr 04 12:32:14 starttex DuetControlServer[350]: [fatal] SPI task faulted Apr 04 12:32:14 starttex DuetControlServer[350]: System.Exception: Invalid protocol version 2 Apr 04 12:32:14 starttex DuetControlServer[350]: at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1130 Apr 04 12:32:14 starttex DuetControlServer[350]: at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean mustSucceed) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 157 Apr 04 12:32:14 starttex DuetControlServer[350]: at DuetControlServer.SPI.Interface.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 744 Apr 04 12:32:14 starttex systemd[1]: duetcontrolserver.service: Succeeded. Apr 04 12:32:19 starttex systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart. Apr 04 12:32:19 starttex systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 1. Apr 04 12:32:20 starttex systemd[1]: Stopped Duet Control Server. Apr 04 12:32:20 starttex systemd[1]: Started Duet Control Server. Apr 04 12:32:20 starttex DuetControlServer[1513]: Duet Control Server v1.3.0 Apr 04 12:32:20 starttex DuetControlServer[1513]: Written by Christian Hammacher for Duet3D Apr 04 12:32:20 starttex DuetControlServer[1513]: Licensed under the terms of the GNU Public License Version 3 Apr 04 12:32:21 starttex DuetControlServer[1513]: [info] Settings loaded Apr 04 12:32:22 starttex DuetControlServer[1513]: [info] Environment initialized Apr 04 12:32:22 starttex DuetControlServer[1513]: [info] Connection to Duet established Apr 04 12:32:22 starttex DuetControlServer[1513]: [info] IPC socket created at /var/run/dsf/dcs.sock Apr 04 12:32:22 starttex DuetControlServer[1513]: [info] Executing system macro file config.g on channel Trigger Apr 04 12:32:26 starttex DuetControlServer[1513]: [info] Trigger: Finished system macro file config.g
@ChrisP Thanks, please run that when DSF becomes unresponsive. So far nothing unusual in this excerpt.
@bearer said in RepRapFirmware 3.01-RC6 released:
should work if DuetControlServer is still running, if that is not the case, you'll need to connect to the Duets micro USB port and use it as a serial console.Don't know why I didn't think of the USB console - this is how I always debug 0.6 and Duet 2s... duh! Interestingly, the service dump mentioned a depreciated firmware, so here's the M122 log that I hope shows this isn't the case...
4/4/2020, 12:36:36 PM M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.01-RC6 running on Duet 3 MB6HC v0.6 or 1.0 Board ID: 08DJM-956L2-G43S8-6J1FJ-3SD6M-9S3GF Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 154084 Dynamic ram: 160852 of which 24 recycled Exception stack ram used: 216 Never used ram: 78040 Tasks: NETWORK(ready,2084) HEAT(blocked,1196) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,216) MAIN(running,4736) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:04:26 ago, cause: software Last software reset at 2020-04-04 12:30, reason: User, spinning module LinuxInterface, available RAM 77332 bytes (slot 1) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 44.2, current 44.9, max 45.0 Supply voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 11.1, current 11.3, max 11.3, under voltage events: 0 Driver 0: standstill, reads 7684, writes 14 timeouts 0, SG min/max 0/0 Driver 1: standstill, reads 7684, writes 14 timeouts 0, SG min/max 0/0 Driver 2: standstill, reads 7685, writes 14 timeouts 0, SG min/max 0/0 Driver 3: standstill, reads 7686, writes 13 timeouts 0, SG min/max 0/0 Driver 4: standstill, reads 7687, writes 12 timeouts 0, SG min/max 0/0 Driver 5: standstill, reads 7688, writes 12 timeouts 0, SG min/max 0/0 Date/time: 2020-04-04 12:36:38 Slowest loop: 3.61ms; fastest: 0.21ms === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.47ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 1018, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 1 Last transfer: 16ms ago RX/TX seq numbers: 8175/8176 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v1.3.0.0 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 31.72
easy to loose sight of the trees in the forrest i guess
timeout 1 cat /dev/ttyACM0 & echo -e "\nM122" > /dev/ttyACM0
should get you the M122 from serial as a one line copy/paste if you should need it (as opposed to installing the less than user friendly console based serial terminals available for the pi)
Thanks but this M122 output doesn't show anything unusual either. Btw, you can keep a log session going when you start a print by running
sudo journalctl -u duetcontrolserver -f
. This way, all the events from DCS are sent to your console window. -
100%
Yeh, I've got Termite on a Windows PC, so I can avoid conole based serial terminals@chrishamm said in RepRapFirmware 3.01-RC6 released:
Cool!The print has now got past where it did last time, annoyingly.
If it is was just the PanelDue causing the issue this time, is it any use to you if I plug it back in to force crashes and post the logs, or not? Or do we just accept that eh PannelDUe is currently dead for this release?edit: I've noticed that the Layer Chart remains blank during printing...?
@chrishamm @dc42 see https://forum.duet3d.com/post/143464 earlier in thread. Says layer time is still wrong. Saw it was supposed to be fixed in 3.01-RC6 release notes. Any suggestions?
@Marco-Bona The only thing I can think of is to clear browser cache?
I've just released DWC 2.1.1 (see https://forum.duet3d.com/topic/15342/duet-web-control-2-1-1-released) and DSF 1.3.1 (see https://forum.duet3d.com/topic/15343/dsf-1-3-1-unstable-released). Please use the corresponding threads for DWC and DSF-related support and this one only for issues involving the firmware.
@droftarts said in RepRapFirmware 3.01-RC6 released:
The issue I thought we were talking about is this one https://forum.duet3d.com/post/142804 whereby the firmware behaves as if the first layer (and the whole print) started when the printer was powered up. I believe that is fixed. Is there another issue with layer times?
For everyone having unexplainable problems using SBC ( @chas2706 might fall under that) AND using my
Exec On MCode
tool please see: https://forum.duet3d.com/post/143593 -
Im assuming this is a firmware related issue rather that a DSF issue, but I'm not sure.
I've noticed that on powerup, the printer clearly isn't parsing filaments.csv properly as it forgets what filament is loaded. The csv file is there and has the correct information, but the web interface shows no filament is loaded and M701 returns "No filament loaded in the selected tool".
I'm currently running 3.01-RC6 with DSF 1.3.1
edit: loading filament sitll fails to show it on the web interface, but M701 reports correctly
I have upgrade from a fresh raspberry image to RC6. Now I would print, upload works then
Failed to connect to duet3.
DCS is not startet.Apr 05 12:29:59 Duet3 DuetControlServer[2388]: Duet Control Server v1.3.1 Apr 05 12:29:59 Duet3 DuetControlServer[2388]: Written by Christian Hammacher for Duet3D Apr 05 12:29:59 Duet3 DuetControlServer[2388]: Licensed under the terms of the GNU Public License Version 3 Apr 05 12:30:00 Duet3 DuetControlServer[2388]: [info] Settings loaded Apr 05 12:30:00 Duet3 DuetControlServer[2388]: [info] Environment initialized Apr 05 12:30:00 Duet3 DuetControlServer[2388]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f) Apr 05 12:30:00 Duet3 DuetControlServer[2388]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f) Apr 05 12:30:00 Duet3 DuetControlServer[2388]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f) Apr 05 12:30:00 Duet3 DuetControlServer[2388]: [warn] Restarting transfer because the number of maximum retries has been exceeded Apr 05 12:30:00 Duet3 DuetControlServer[2388]: [error] Duet is not available Apr 05 12:30:00 Duet3 systemd[1]: duetcontrolserver.service: Succeeded. Apr 05 12:30:06 Duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart. Apr 05 12:30:06 Duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 75. Apr 05 12:30:06 Duet3 systemd[1]: Stopped Duet Control Server. Apr 05 12:30:06 Duet3 systemd[1]: Started Duet Control Server. Apr 05 12:30:06 Duet3 DuetControlServer[2405]: Duet Control Server v1.3.1 Apr 05 12:30:06 Duet3 DuetControlServer[2405]: Written by Christian Hammacher for Duet3D Apr 05 12:30:06 Duet3 DuetControlServer[2405]: Licensed under the terms of the GNU Public License Version 3 Apr 05 12:30:07 Duet3 DuetControlServer[2405]: [info] Settings loaded Apr 05 12:30:07 Duet3 DuetControlServer[2405]: [info] Environment initialized Apr 05 12:30:07 Duet3 DuetControlServer[2405]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f) Apr 05 12:30:07 Duet3 DuetControlServer[2405]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f) Apr 05 12:30:07 Duet3 DuetControlServer[2405]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f) Apr 05 12:30:07 Duet3 DuetControlServer[2405]: [warn] Restarting transfer because the number of maximum retries has been exceeded Apr 05 12:30:07 Duet3 DuetControlServer[2405]: [error] Duet is not available Apr 05 12:30:07 Duet3 systemd[1]: duetcontrolserver.service: Succeeded. Apr 05 12:30:13 Duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart. Apr 05 12:30:13 Duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 76. Apr 05 12:30:13 Duet3 systemd[1]: Stopped Duet Control Server. Apr 05 12:30:13 Duet3 systemd[1]: Started Duet Control Server. Apr 05 12:30:13 Duet3 DuetControlServer[2418]: Duet Control Server v1.3.1 Apr 05 12:30:13 Duet3 DuetControlServer[2418]: Written by Christian Hammacher for Duet3D Apr 05 12:30:13 Duet3 DuetControlServer[2418]: Licensed under the terms of the GNU Public License Version 3
Power cycle doesn't work!
@wilriker said in RepRapFirmware 3.01-RC6 released:
For everyone having unexplainable problems using SBC ( @chas2706 might fall under that) AND using my Exec On MCode tool please see: https://forum.duet3d.com/post/143593
Thanks for the info.
I use your Exec On MCode so I definitely fall into that category. -
I'm back on RC5.
If you're having issues with connections between the DSF and the Duet3, check this out...
https://forum.duet3d.com/post/143792 -
I'm waiting for RC7.
