RepRapFirmware 3.01-RC6 released
@chas2706 said in RepRapFirmware 3.01-RC6 released:
@Danal said in RepRapFirmware 3.01-RC6 released:
o again, I'm just a fellow user, trying to help improve understanding so that people don't get painted into corners... if DWC didn't regress to the level it was when the backup was taken, the the backup/restore procedure is the thing to fix for next time.
Thanks for your help danal. I really appreciate your input.
I am just so frustrated with the problems I am experiencing.@Danal
Wait a minute... "Win32 disk manager"??? That won't deal with the Unix partitions on that card. Will it?I am no Linux expert but I can confirm that win32 disk manager deals with the unix partitions because I have used it for many years on my rpi projects.
It was available for the rpi way before etcher or raspberry pi imager.Yeah, I think we both mean "win32diskimager". That does work on complete SD cards. Although I have read where it can skip certain parts of cards on certain drives. Probably not what happened here.
And, yes, I understand the frustration. I was up until 2:30 last night doing a "five minute install" of LaTEX on an unrelated system... and had calls starting at 7 AM. I really should have walked away about 11 PM, but you get that "one more command and it has GOT to work" syndrome.
Sorry yes. My mistake!
Looks like I will just have to spend hours setting up my config again from scratch.
A lessen learnt - don't download from the "unstable list".
Again, thanks for you help. -
hopefully when 3.01 hits stable, there won't be a a reason to do so (which didn't quite hold true for 3.0)
In a previous post somewhere I read that @ DC42 does not have Duet 3 with SBC so based on this how can new firmware be released if the owner of firmware does not have the hardware?
@chas2706 He is not the only person developing and testing the firmware. The software for SBC Raspi DSF has even a different owner Chris Hamm.
Correct. DC42 is the primary (but not only) author of the firmware for the Duet Board itself, and is the lead engineer for the company, and a principal owner of the company.
Chrishamm is the primary developer for Duet Web and for Duet Software Framework on the Pi. I do not know his other relationships to the company. Chris has the hardware to test D3+Pi.
And... anyone can open a "pull" request, it is the nature of github. So there are somewhere between 7 and a dozen other contributors. Probably not all that relevant to our discussion here.
I just installed 3.01 RC6
I have run into a couple of issues and I'm not sure if it is the firmware or the web control...I also updated it to 2.1.0- I have a load filament Macro and when I tried to use it it did not function...it is pretty simple the extruder was up to temperature
M83
G92 E0
G1 E1200 F3000
G1 E200 F10
Also on the same note if I try to press the extrusion control from DWC it does not work either but the funny thing is that if you do it on panel duo it does work. - on the tools block when extruders and bed are on and you go to the control all and press turn everything off...that does not function
It will work if you change the set all active temperatures and set all active temperatures to some other value then back to 0 again
i get thats its frustrating when things go pear shaped; and I don't have an explanation as to why I was able to downgrade to a specific version but you were not - however it does suggest something being amiss with your setup.
if you still have a backup sd card, I would encourage you to make a copy and then try that with my suggestions for restoring the RRF firmware which is on the sd. there really is no reason that shouldn't give you the same combination of apt packages and rrf firmware as you had when you made the backup.
seem to be working on duet2eth but when I upload Duet2CombinedIAP.bin in the system tab it shows uploading forever, never finishes?!
I updated the DWC to 2.1.0, but I haven't noticed any changes.
Yesterday I tried to make a couple of prints but the layer screen remained with the same problem I had.
It always hangs on the second layer and the statistics are wrong.
This morning I try to start the print and see if something has changed.
I'll update you as soon as possible.
Thanks -
I'm sorry that there are some issues with upgrading to the new RRF/DWC/DSF. There have been many major changes, especially to DSF and DWC which now support almost the full object model.
Here's a summary of issues we are aware of with upgrading to RRF 3.01-RC6, DWC 2.1.0 and DSF 1.3.0.
- DWC issue: extrude/retract buttons greyed out when they shouldn't be. Workaround: if you need those buttons, use DWC 2.0.7.
- DWC issue: when you click on a heater in the Fault state there is a new dialog that allows you to reset the fault; but the heater fault reset doesn't work.
- Upgrading RRF+DSF+DWC on Duet 3 with attached RPi does not always go smoothly.
- DSF issue: laser and magnetic filament monitors without a filament present switch are not handled. Workaround: add 1 to the filament monitor type (M591 P parameter) to say that a filament present switch is present, and put a jumper across the filament present switch pins to simulate the presence of filament.
We are preparing a new DWC release (2.1.1) to address #1 and #2, and a new DSF release (1.3.1) to address #4. Chrishamm will provide new instructions to address #3. I will then lock this thread and we will start two new threads: one for issues users are having using the new release on Duet 3 + SBC, and one for other users.
for me work this to upgrade my sbc:
apt remove duetsoftwareframework duetcontrolserver duetsd duettools duetwebserver duetwebcontrol reprapfirmware
and install with
apt install duetsoftwareframework duetcontrolserver duetsd duettools duetwebserver duetwebcontrol reprapfirmware
@droftarts, I send you the DWC screen, as you can see nothing has changed since the previous build.
The only doubt is that there is something at the beginning of the file that creates some noise.M117 Preparing ;write Preparing G4 S2 ;delay 2 seconds M140 S60 ;set bed temperature and move on M141 S0 ;set heated chamber temperature and move on M104 T0 S195 ;wait for the extruder to reach desired temperature M107 ;start with the fan off G28 ;home all axes T0 ;select tool 0 G1 X-23 Y-24 F10000 ;go to the center of bed G1 Z10 F1000 ;E go to Z10 M107 P0 ;turn off leds G30 X-23 Y-24 S-2 H1.915 ;probe current position and ajust Z offset G1 Z40 F1000 ;E go to Z40 M106 P0 S1 ;turn on leds T0 ;reset current tool M584 P4 ;apply custom setting G1 X-87 Y160 F10000 ;go to X-87 Y160 M117 Spray print adhesive ;write Spray print adhesive G4 S2 ;delay 2 seconds M226 ;pause M190 S60 ;wait for the bed to reach desired temperature M109 S205 ;wait for the extruder to reach desired temperature G1 U130 F10000 ;go to U130 G92 E0 ;reset the extruder position G1 X-137 E25 F500 ;move to X-137 and extrude 25mm of feed stock G92 E0 ;reset the extruder position G1 E-4 F5000 ;retract 4mm G1 X-187 F500 ;go to X-187 G1 Y165 F500 ;go to Y165 G10 ;retract G1 X-137 F500 ;go to X-137 and clean nozzle G1 XO Y0 U0 F10000 ;go to X0 Y0 U0 M584 P3 ;apply custom setting G21 ;metric values G90 ;absolute positioning M117 Print starting ;write Print starting G4 S2 ;delay 2 seconds G92 E0 ;reset the extruder position G1 E4 F500 ;unretract 4mm G11 ;unretract
I am attaching the file to verify.
HA_Rudder.gcode -
@Marco-Bona can you confirm youโre using the latest firmware and DWC versions? Shown on System tab of DWC. I have not had a chance to test if the layer time problem is fixed.
@droftarts, I confirm, I am using DWC 2.1.0, I have updated to RRF3.01 RC6 and DuetWiFiServer 1.23.
M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC6 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-04-03b3
@dc42 thanks for your clear statement. have a nice weekend.
I've just stumbled across another odd error.
I had just started a print but a bit of purge material got caught on the head so I paused the print (I have a hardware button and use the input to trigger a pause using M581).On first press of the button, all motion stopped instantly but the pause script (below) wasn't executed. I pressed the button again and the notification to say that the print had been paused be external trigger showed but the head still didn't move out of the way.
; Pause macro file M83 ; relative extruder movements G1 E-3 F2500 ; retract 3mm G91 ; relative moves G1 Z10 F5000 ; raise nozzle 10mm G90 ; absolute moves G1 X0 Y110 F5000 ; move head out of the way of the print
I then pressed Emergency Stop on the web interface at which point the web interface said it was tying to reconnect, but it never came back to life. I tried moving the axis by hand to move the hot nozzle off the print but all the axis motors were sitll powered and holding. I took the following dump fron the DCS service log on the SBC:
Apr 04 11:25:18 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:25:28 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:25:38 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:25:46 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:25:50 starttex DuetControlServer[360]: [info] Selected file /opt/dsf/sd/gcodes/Test Parts/20x20x10 8dia hole.gcode Apr 04 11:25:50 starttex DuetControlServer[360]: [info] Starting file print Apr 04 11:25:50 starttex DuetControlServer[360]: [info] File: Optional macro file start.g not found Apr 04 11:25:50 starttex DuetControlServer[360]: [info] Executing nested macro file pre_print.g on channel File Apr 04 11:25:51 starttex DuetControlServer[360]: [info] Executing nested macro file homeall.g on channel File Apr 04 11:25:51 starttex DuetControlServer[360]: [info] Executing nested macro file homez.g on channel File Apr 04 11:25:54 starttex DuetControlServer[360]: [info] File: Finished macro file homez.g Apr 04 11:25:54 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:25:54 starttex DuetControlServer[360]: [info] Executing nested macro file homex.g on channel File Apr 04 11:25:55 starttex DuetControlServer[360]: [info] File: Finished macro file homex.g Apr 04 11:25:55 starttex DuetControlServer[360]: [info] Executing nested macro file homey.g on channel File Apr 04 11:25:59 starttex DuetControlServer[360]: [info] File: Finished macro file homey.g Apr 04 11:26:01 starttex DuetControlServer[360]: [info] File: Finished macro file homeall.g Apr 04 11:26:01 starttex DuetControlServer[360]: [info] Executing nested macro file tfree0.g on channel File Apr 04 11:26:02 starttex DuetControlServer[360]: [info] File: Finished macro file tfree0.g Apr 04 11:26:02 starttex DuetControlServer[360]: [info] Executing nested macro file tpre0.g on channel File Apr 04 11:26:02 starttex DuetControlServer[360]: [info] File: Finished intermediate macro file tpre0.g Apr 04 11:26:02 starttex DuetControlServer[360]: [info] Executing nested macro file tpost0.g on channel File Apr 04 11:26:02 starttex DuetControlServer[360]: [info] Executing nested macro file config.g on channel File Apr 04 11:26:02 starttex DuetControlServer[360]: [info] File: Finished macro file config.g Apr 04 11:26:02 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:26:02 starttex DuetControlServer[360]: [info] File: Finished macro file tpost0.g Apr 04 11:26:02 starttex DuetControlServer[360]: [info] Executing nested macro file tfree0.g on channel File Apr 04 11:26:03 starttex DuetControlServer[360]: [info] File: Finished macro file tfree0.g Apr 04 11:26:10 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:26:18 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:26:26 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:26:35 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:31:16 starttex DuetControlServer[360]: [info] File: Finished macro file pre_print.g Apr 04 11:31:17 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:31:18 starttex DuetControlServer[360]: [info] Executing nested macro file purge.g on channel File Apr 04 11:31:18 starttex DuetControlServer[360]: [info] File: Finished macro file purge.g Apr 04 11:31:18 starttex DuetControlServer[360]: [info] Executing nested macro file wipe.g on channel File Apr 04 11:31:20 starttex DuetControlServer[360]: [info] File: Finished macro file wipe.g Apr 04 11:31:25 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:31:33 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:31:42 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:31:50 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:32:00 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:32:10 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:32:18 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Restarting transfer because the number of maximum retries has been exceeded Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Restarting transfer because the number of maximum retries has been exceeded Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Restarting transfer because the number of maximum retries has been exceeded Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa) Apr 04 11:32:18 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x7222, got 0x7aaa)
I pressed the reset button on the Duet3 (by the power LEDs) and everything came back to life. I've since tried to recreate the issue, but can't unfortunately as yet.
The printer has been running solidly for days, so I'm not inclined to believe its a hardware or other setup issue at the moment.
update:
I've not just had it crash randomly mid-print. Web interface becomes unresponsive and service logs are full of:Apr 04 12:03:53 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x92b3, got 0x23e3) Apr 04 12:03:53 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x92b3, got 0x23e3) Apr 04 12:03:53 starttex DuetControlServer[360]: [warn] Bad data checksum (expected 0x92b3, got 0x23e3) Apr 04 12:03:53 starttex DuetControlServer[360]: [warn] Restarting transfer because the number of maximum retries has been exceeded
I also seem to be getting lots of this. Which is confusing as I don't have the macros page open on anything...?
Apr 04 12:02:45 starttex DuetControlServer[360]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
@ChrisP It looks like you have a PanelDue connected to your Duet 3 and that is not fully supported yet while the Duet 3 is operating in SBC mode. At present the only transmitted command from the firmware to DSF is M20 which you can see in the logs. So I suggest don't use the PanelDue for anything else than pausing prints (not resuming) or emergency stops in SBC mode until support for PanelDue has been fully implemented.
Can you share the output of M122 if you are certain the firmware reset unexpectedly?
@chrishamm
You are absolutely correct that I have a PanelDue connectedI hadn't anticipated that this could be part of the problem since i'ts been connected since it has always been connected to the Duet3 from the first time I set it up over a few weeks ago. I was aware that it had limitations but have kept it there as an easy way to view teh temperatures and print progress - I don't use it for anything onther than displaying info currently. With previous firmwares / DCS it's been operating fine. That said, I'll take the advice and remove it for now.
Is there a was that I can issue M122 and grab the result from the Pi as when the crashed happen, the web interface becomes totally unresponsive and requires me to press the hardware reset on the Duet3 to bring things back to life?
edit: I will unplug the PanelDue, power cycle and try the print again.... I'm only running test prints currently to ensure the system is stable... clearly not quite ready for a proper print yet
@ChrisP It sounds like there is a problem in DCS and I'll be happy to look into it. To obtain some debug info, please connect to your Pi via ssh, run
sudo journalctl -u duetcontrolserver -en 100 --no-pager
, and share the output you get.PS: It's fine to leave the PanelDue attached but be aware that most file-related commands will not work as expected.
