Cambio elettronica
te lo mando
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT+0200 (Ora legale dell’Europa centrale)
G91 ; relative positioning
G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-335 ; home X axis
G1 H1 Y-335 ; home Y axis
G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-335 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X60 Y50 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
si sposta verso il dietro e a dx
@Leblond said in Cambio elettronica:
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European
Summer Time) G91; relative positioningI think the problem may be here. The G91 must be on a new line.
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European Summer Time)
G91; relative positioning -
scusami errore mio M574 X1 S1 P"!xstop" avevo tolto "!"
Adesso funzionagrazie della pazienza che mi hai dimotrato fratello
ecco la configurazione funzionante per la tronxy x5sa pro con duet, in caso qualcun'altro ne avesse bisogno
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT+0200 (Ora legale dell’Europa centrale); General preferences
M550 P"X5SA PRO" ; set printer nameM669 K1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
M203 X6000.00 Y6000.00 Z100.00 E1200.00 ; set maximum speeds (mm/min)
M208 X-5 Y0 Z0 S1 ; set axis minima
M208 X352 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"! zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X60:300 Y50:300 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
Buona notte a tutti
Glad you got it working.
buongiorno a tutti voi.
Sto completando la stampante per quanto riguarda l'elettronica ho letto qui https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing e non son sicuro di aver capito bene.
allora ricapitolando, quello che cerco e' nel comando M591 se non erro ed e' il seguente
M591 D0 P1 C "e0_stop" S1 corretto? l'interruttore rimane alto quando c'e' il filamento e viceversa quando non c'e' mi basta solo questo in config? o ho bisogno di altro? -
RISOLTO
@Leblond
Ciao Altro italiano....
possessore di una Tronxy x5sa.
mi dai qualche riscontro. hai finito la configurazione del passaggio alla duet wifi?
HAi preso un clone o una originale?
Ha cambiato altre parti oltre alla motherboard? -
@gdefranc Ciao la configurazione con la duet2 wifi funziona perfettamente, ma purtroppo x colpa mia la duet ha fatto puff, quindi sto aspettando quella nuova sempre la stessa presa da filastruder a parte la scheda, ho sostituito anche il sensore e gli ho messo il 3dtouch, in particolare cosa vorresti sapere?
@Leblond Grazie per la risposta.
Quindi alla fine hai cambiato la motherboard il 3dTouch e niente altro.
l'lcd hai mantenuto quello originale?
A livello meccanico hai fatto qualche modifica?
Usi il piatto in Vetro borosilicato? -
@gdefranc lcd della tronxy non va bene con la duet, quindi ho preso il paneldue 7i, a livello meccanico devo cambiare le chiocciole mettendo quelli in derlin "pom" e dovrei sostituire una t8 che e' storta, gia' da quando e' arrivata la stampante, poi vedro', ho intenzione anche di modificare l'asse z portando da 2 motori ad 1 con un kit di alluminio fatto da https://www.dmakers.it/componenti-per-stampanti-3d/kit-one-z-motor/ , ha solo un problema questo kit, che bisogna acquistare altri pezzi che non vende lui, ma comunque di facile reperibilita', per quanto riguarda il piano di stampa non sto usando il vetro ma uso il suo originale che non e' affatto male
Buongiorno,
vedendo che qui è scritto anche in italiano, mi unisco per condividere e leggere le mie ( poche) e vostre esperienze...
io sto per avviare una stampante fatta interamente da me, sulla falsa riga di sharebot.
asse z con chiocciola a ricircolo, asse y con doppio motore opposto e cinghia GT2, asse x motore singolo e cinghia GT2, carro estrusione a doppio estrusore, dove come principale uso un e3d V6 all metal, e some secondario un e3d v6 lite e bltouch per livellamento piano.
Elettronica con duet ethernet e duet panel i5, ammeniccoli vari come power supply, mosfet per piano riscaldato.
allo stato dei fatti non ho ancora mosso un motore....ho finito i cablaggi, ad esclusione del bltouch.
Prossima mossa sarebbe quella far muovere i motori.
vi faccio due domandine....
domanda 1)
sui due assi x e y ho messo due finecorsa...mentre il finecorsa high (diciamp Y+ e X+) immagino debbano finire come finecorsa di home, quelli sulla parte low (X- e Y- e Z-) vorrei metterli in serie come emergenza. qualcuno di voi ha inserito un emergenza di quel tipo? se si, come?
domanda 2)
per raffreddare gli stepper della scheda ho collegato due fans da 12 v ai pin always on della scheda.
avendo una alimentazione a 24V ho portato il 12v al pin centrale come da descrizione (togliedo il jumper che selezione i 5V interni. Le ventole non si muovono. devo verificare se effettivamente sui due pin il 12v arriva....ma ci sono altre verifiche da poter fare?Intanto vi ringrazio per la pazienza nel leggere tutta questa "spataffiata" di roba!!!
Ciao
@logriso via google translate:
ask you two questions .... question 1)
on the two x and y axes I put two limit switches ... while the high limit switch (say Y + and X +) I guess they must end as home limit switches, those on the low part (X- and Y- and Z-) I would like to put them in series as an emergency. Did any of you put in an emergency like that? if yes, how?You can home to the high or low endstops, but not both; RepRapFirmware only supports one endstop per motor/axis. There is not much point adding an 'emergency' endstop, because the maximum and minimum movement of the axis will be limited by the firmware. After homing, the endstops are effectively ignored.
You can do it if you really want to; connect the 'emergency' endstops in series, connect them to an available pin connector on the Duet, and use M581 https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger to configure this to pause the printer if triggered.
question 2)
to cool the board steppers I connected two 12v fans to the always on pins of the board.
having a 24V power supply I brought the 12v to the central pin as described (I remove the jumper that selects the internal 5V. The fans do not move. I have to check if the 12v actually arrives on the two pins .... but there are other checks what can you do?There is no 12V regulator on the Duet, only VIN (24V) and 5V. So you need to use a buck regulator or something else to step down to 12V. See https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
@logriso Also, probably best if you start a new thread.
Buongiorno a tutti,
aprofitto della interessante discussione per chiedere informazioni su un problema che mi ostacola nel passaggio da RRF2 a RRF3.
Ho una LK4 pro con vari upgrade ( doppio asse Z con viti a ricircolo e assi X e Y con guide lineari e BL-touch v3.1) e monto una scheda Duet2 Wi.Fi.
Attualmente è tutto perfettamente funzionante e configurato, ma dopo aver portato il firmware alla versione 3.20 non riesco a configurare i fine corsa.
In realtà funzionano ma al contrario, attualmente hanno il contatto NA ma la scheda si aspetta un NC.
Dando il comando home si muove un attimo e si ferma, perchè legge che è già a fine corsa. Se invece faccio l'hon di un asse chiudendo manualmente il contatto, l'asse si muove correttamente e lasciandolo si ferma. Nel config.g ho questo riga:
M574 X1 S1 P"xstop"
M574 Y1 S1 P"ystop"
Ho provato a cambiare i paramteri con altre combinazioni ma i fine corsa restano sempre invertiti.
Con il RRF 2.05 funziona perfettamente.
Avete qualche suggerimento?Grazie
Hello everyone, take advantage of the interesting discussion to ask for information on a problem that hinders me in the transition from RRF2 to RRF3. I have a LK4 pro with various upgrades (double Z axis with ball screws and X and Y axes with linear guides and BL-touch v3.1) and I mount a Duet2 Wi.Fi card. Currently everything is fully functional and configured, but after bringing the firmware to version 3.20 I cannot configure the limit switches. Actually they work but on the contrary, they currently have the NO contact but the board expects a NC. By giving the command home it moves for a moment and stops, because it reads that it is already at the end of its travel. If, on the other hand, I hone an axis by manually closing the contact, the axis moves correctly and when it is released, it stops. In config.g I have this line:; Endstops M574 X1 S1 P "xstop" M574 Y1 S1 P "ystop" I tried to change the parameters with other combinations but the limit switches are always inverted. With the RRF 2.05 it works perfectly. Do you have any suggestions? Thank you
You must invert the signal of the pin using a
before the pin nameM574 Y1 S1 P"!ystop"
Thank you very much ! I try as soon as possible.
