Another Predator
Nothing that I can see or understand given my rudimentary experience with deltas. All I can suggest is to go through this very carefully. It holds the key to your success:
@Phaedrux
Cheers that's my bible.
Actually a new board holds my success!
OK does anyone know what would cause it in a Cartesian or XY ? -
@Phaedrux
Sorry just so I understand where you've confirmed it's a calibration error why are you directing me to the Calibrating a delta printer wiki as I've stated I use the documentation to setup always..so I guess I'm asking where in that document does it answer the issues I'm having as I am constantly using those very pages to try to resolve my issues with no success as in no change what so ever.
Is it possible to have a faulty board with no error showing as in nothing on the board because I follow the guides and all appears to work as expected until I try to print and then it does not know where it is in relation to the bed
because if it is possible I won't waste any more of your time on it.
And yes not keeping it light hearted but I've followed every suggestion made here and no change and it's a little frustrating.Cheers
I'm inclined to think it's mechanical or a configuration error. It almost always ends up being mechanical in some way. Something loose, cracked, stripped, shifted, binding, skipping, etc. And when it's not, it's a config error of some kind.
The G1/G0 error you're getting reminds me of a recent thread. See here: https://forum.duet3d.com/topic/14821/error-g0-g1?_=1584397103870
I think that may be your solution to that issue.
I’m not running slicer software this is homing when switching machine on or after trying to print with no start commands in slicer Or if I try to calibrate,
I’ll try G28 in my home file ?
Rather than G1 commands
I do get a G1 error when trying to move -Z from home when the home height is wrong and have to reset to obtain the correct ish height but I can’t calibrate when the height is wrong also the endstops show as 10mm ish + or - when height is wrongCheers
Any delta gurus wanna take another crack at this one? @Danal @jay_s_uk @droftarts
Sure, let me read the thread a little. And take a look at this suddenly popular printer.
Meanwhile, @Carlo, I know you've posted a lot of stuff... but would you mind posting your current config.g and homedelta.g, one more time? And I see you've been on V3 and V2 of the software, which is loaded at this moment? (M122 will tell you).
@Danal
Thanks PhaedruxHi Danal,
Appreciate you having a look,FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-12-13b1
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 19:14:10 GMT+0000 (Greenwich Mean Time); General preferences
M550 P"Street Predator" ; set printer name
M665 L440.470:440.470:440.470 R232.245 H422.803 B185.0 X-0.054 Y-0.244 Z0.000
M666 X-0.263 Y0.223 Z0.040 A0.00 B0.00; Network
M551 P"" ; set password
M552 P192.168.0.25 S1 ; Enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E867.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops; Z-Probe
M558 P5 R0.4 H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P100 X0 Y0 Z-0.08 ; set Z probe trigger value, offset and trigger height
M557 R175 S20 ; define mesh grid; Heaters
M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 X200 ; configure PT100 for heater 1
M143 H1 S400 ; set temperature limit for heater 1 to 400C; Fans
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss; homedelta.g
; called to home all towers on a delta printer
G91 ; relative positioning
;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
G1 H1 X450 Y450 Z450 F1800 ; move all towers to the high end stopping at the endstops (first pass)
;G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
;G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
;G1 X0 Y0 F6000 ; move X+Y to the centre3/16/2020, 11:42:51 PM M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later
Board ID: 08DGM-917DA-G4MSJ-6J1FJ-3S86N-TBN3A
Used output buffers: 3 of 24 (8 max)
Static ram: 25712
Dynamic ram: 92244 of which 380 recycled
Exception stack ram used: 272
Never used ram: 12464
Tasks: NETWORK(ready,628) HEAT(blocked,1176) MAIN(running,3728) IDLE(ready,160)
Owned mutexes:
Last reset 00:06:01 ago, cause: power up
Last software reset at 2020-03-16 19:20, reason: User, spinning module GCodes, available RAM 12304 bytes (slot 0)
Error status: 0
Free file entries: 10
MCU temperature: min 32.5, current 38.0, max 38.2
Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-03-16 23:42:50
Cache data hit count 703568711
Slowest loop: 10.47ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 30.44ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplex
3/16/2020, 11:41:17 PM M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-12-13b1Thanks
@Carlo said in Another Predator:
M208 Z0 S1 ; set minimum ZJust a thought... If you're setting the axis limit with M208 to Z0, you can't go further down with babystepping. I have my M208 to
M208 Z-0.2 S1
, which allows for quite a lot of adjustment of the first layer with babystepping. As you're having particular problems with getting the first layer low enough, I wonder if this settings also impacts setting the Z datum.Ian
Hi Ian,
I’ll make that change and recalibrate 1st thing
That makes sense.Appreciate the help.
Cheers
Did I read somewhere that you switched to Hyaden Mag arms? (Which are great, by the way). What was printed on the stickers that came on the arms?
; homedelta.g
;G1 X0 Y0 F6000 ; move X+Y to the centreI see one problem immediately. A bunch of commands in homedelta.g have been commented out. There are two problems with that:
First, the "second pass" slow home is commented out. This means that tower height, and therefore indirectly bed height, is dependent only one a single bang into the upper switches that occurs at F1800. This is not very repeatable or accurate.
Second, after that single bang, there is not a slight downward move (it is commented out). This means the carriages and effector are "trapped" up against all three switches and cannot adjust for tower offsets or angles. This will produce all kinds of bizarre behaviors. The macro just ends with the carriage sitting there up against the stops. Depending on what the next move is, various weird things are going to happen.
Your homedelta.g should be:
; homedelta.g ; called to home all towers on a delta printer ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 19:14:10 GMT+0000 (Greenwich Mean Time) G91 ; relative positioning ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working G1 H1 X450 Y450 Z450 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass) G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F6000 ; move X+Y to the centre
Or very similar...
I will keep looking.
I notice there is an "m501" near the end of config.g. This loads /sys/config_override.g. Please either post that file, and/or consider taking the M501 out until we get this all straight.
That looks really odd to me. Can you post a couple of pictures of the printer? Preferably with the effector as close to X0Y0Z1 as you can get without damaging anything, and then one or two different photo angles at X0Y185Z1.
Thanks!
Hi Danal,
These are commented out in the home file for Delta Calibration as per the documentation they are not always commented just at the point of posting.
Thanks
@Danal said in Another Predator:
X0Y0Z1
Hi Danal,
Pictures as requested,
X0Y0Z1
X0Y185Z1
 5mm below the endstop switches, correct?
