Independent Z Leveling
Looks good, but the fact that the corrections end up being all negative and about equal indicates that either bed or the plane that the carriage moves in isn't quite flat. I suggest that after levelling and before printing, you do a single G30 probe at bed centre so that Z=0 is correct there.
@dc42 I was wondering about that. The bed is a Mic6 plate so it should be flat to about .15mm but I guess thats the deviation its measuring. I'm trying to understand how you can determine the flatness of the plate from only probing three points.
I think its probably that all three of the rails are not in parallel to each other. Most notably the back center rail. I may need to work on aligning it better with the other two. -
@3DPrintingWorld said in Independent Z Leveling:
You can't. I am assuming that you homed Z by doing a single G30 probe near the centre of the bed. That gives a 4th point.
@dc42 You are correct. I seem to be saying that with every reply.
It does probe in the center first. I was wondering if that probe was needed and if it is taken into account because its not in "BED" file.
This looks better! I have two flex plates, I was originally testing on a buildtak and had a thought that there might be bubbles that I cant see bc its black. I switched to my clear PEX sheet and got much better results!
Now that I know the bed is flat is there a reason to keep the first probe in the center?
You don't need to probe in the centre before you do the three G30 probes near the leadscrews, assuming you have homed Z at least once since power up. However, I recommend that you probe the centre (e.g. by doing G28 Z) at the end, in case there is a difference in height between the middle and the edges.
I'm not an engineer but
I became interested in assembling a 3D printer and there were questions on which I have not yet decided. Can I ask you in this forum what is wrong I am writing in the config.g so that the Z sensor starts working -
@Vladimir said in Independent Z Leveling:
I became interested in assembling a 3D printer and there were questions on which I have not yet decided. Can I ask you in this forum what is wrong I am writing in the config.g so that the Z sensor starts workingYes of course; but please start a new thread for your post, describe the problem you are having, and include your config.g file with your post.
Now I made the record right? is it new thread for my post
Good afternoon
Please help with the Сonfig file for Duet Wi Fi version 2.03
I assembled a Cartesian printer where XY moves in the same plane with ball screws and 3 step motors
the Z table is lowered with balls crews and 2 step motors. I connect inductive sensor NPN normally open;( works at a height of about 2 mm from the Al table in my opinion the sensor response level is low to a heated table)
The problem is that I can’t level Z table with a probe and I can’t get a table map and auto-calibrationPlease help me what am I doing wrong
kind regards
; generated by RepRapFirmware Configuration Tool v2.1.6 on Tue Jan 14 2020 10:57:13 GMT+0300 (Москва, стандартное время)
M550 P"Gnutik" ; set printer name
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
; M564 S0 H0
M569 P3 S1 ; physical drive 3 goes forwards Extruder
M569 P0 S0 ; physical drive 0 goes forwards drive Y
M569 P1 S0 ; physical drive 1 goes forwards drive Y
M569 P2 S0 ; physical drive 2 goes forwards drive X
M569 P5 S0 ; physical drive 5 goes forwards drive Z
M569 P6 S0 ; physical drive 6 goes forwards drive Z
M584 X2 Y0:1 Z5:6 E3
M671 X-27:980 Y21:21
M92 X400.00 Y400.00 Z1280.00 E418.50 ; set steps per mm
M566 X400.00 Y400.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X400.00 Y400.00 Z10.00 E250.00 ; set accelerations (mm/s^2)
M906 X1800 Y1800 Z1800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M208 X300 Y200 Z0 S1 ; set axis minima
M208 X750 Y450 Z500 S0 ; set axis maxima
M574 X0 S0 "X-stop"
M574 Y0 S0 "Y-stop"
M574 Z0 S0 "Z-stop"
M558 P5 I1 H5 F120 T6000
G31 X0 Y0 Z0,1
M557 X30:740 Y0:450 S20 ; define mesh grid
M307 H0 B0 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M501
@Vladimir You're still posting inside someone elses topic. Create a new topic from the main forum. https://forum.duet3d.com/category/5/duet-hardware-and-wiring
@dc42 If I issue a G28 Z then wont it start to start a cyclic dependency. Since homez has a G32? Or should the G32 only be in home all?
