Tuning Jerk/Accel/Speed settings
@wcj97 said in Tuning Jerk/Accel/Speed settings:
if my max speed for my extruder is 6mm/s
That may be the max for extrusion, but not the max for retraction. So don't set your extruder M203 that low.
You'll want to set your extruder jerk higher than that as well so that your retractions can be faster and so that pressure advance can quickly change direction.
The extrusion speed is so low that it doesn't really matter, but retraction and pressure advance can be much quicker.
The extruder doesn't have a lot of mass to throw around like the other axis do, it's just rotation, so your jerk/accel can be quite high without issue (without skipping of course). Basically you can set the max speed and jerk/accel high enough that they ever really come into play. That allows pressure advance and retraction and the acceleration and jerk of the XY axis to dictate.
@wcj97 No. "Jerk" doesn't work like that in RRF firmware. Jerk is never applied at the start of a move. (True instantaneous speed change is actually impossible in any case). Think of it as a speed change threshold which gets applied when a the object is in motion and there is a change of direction. So instead of one move slowing down to a complete standstill before the next move starts, the move will slow down to the instantaneous speed change threshold (jerk) instead, and the next move commences at that speed. Given that any print move will be a combination of XY and E, and the speed will be the lowest of any of those axes at any point in time, then the only time that extruder jerk would be applied to a print move is if it is set to give a lower speed than X or Y, in which case it would slow down the entire print move. There are only two (I think) instances where extruder jerk is applied. One is when using pressure advance, and I can't remember the other. But in both cases, setting extruder high rather than low is the way to go.
@deckingman said in Tuning Jerk/Accel/Speed settings:
How does the start of the move look like? I had an assumption that start of the move, since going from 0, will always use acceleration from 0 but I had issues with new Orion sensor triggering falsely and the guy's from precise piezo asked me to set the Z jerk to 0 as Z move would "jump to jerk speed" and that triggers the Orion. I made the change and solved the problem so looks like that jerk value do affect the start of the move.
It does in recent versions of RRF if you set the jerk policy to 1 in M566.
@dc42 this is interesting. why would
M566 X500.00 Y500.00 Z0.00 E6.00
not trigger my piezo on
G30
whileM566 X1500.00 Y1500.00 Z50.00 E6.00
will trigger
G30
when the bed starts to rise?that's the only
M566
in all the files, I never set P to 1 ?It is confusing me. I kept the M566Z0 as I didn't notice any difference in print behavior between Z0 and Z50 and with Z0 piezo sensor works ok. Why I would like to know how it actually behaves is I was thinking about adding support of RRF to the gcodestat so that I can calculate precise print time from a g-code, but I'm waiting for the few more 3.x versions as I see you are still changing things
@dc42 said in Tuning Jerk/Accel/Speed settings:
I missed that - thanks (and thank goodness its optional)
I seem to recall having similar behavior displayed on my machine when commissioning the Z axis. It wasn't related to a piezo probe, but merely the fact that jerk was "being applied" from a stand still. I'm not certain of this, but it rang a bell for sure. I even remember making a thread about my Z axis making noises at one point.
@arhi said in Tuning Jerk/Accel/Speed settings:
G30
will trigger
G30
M566
Having Z jerk set to 0 would cause stuttering in X and Y when using mesh bed compensation since it would be trying to slow down to nothing in X and Y while it waited for the Z axis to adjust position.
The gcode wiki entry for M566 is instructional here.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M566_Set_allowable_instantaneous_speed_change
When mesh bed compensation is used, movement may be jerky if the allowed Z jerk is too low, because the Z speed needs to change abruptly as the head moves between squares in the mesh.
The default jerk policy is 0, which replicates the behaviour of earlier versions of RRF (jerk is only applied between two printing moves, or between two travel moves, and only if they both involve XY movement or neither does). Changing the jerk policy to 1 allows jerk to be applied between any pair of moves.
I've had good results with jerk policy 1, I think mainly because it reduces the pause time between the end of a print move and the start of a travel move. Since before jerk was only being applied between two consecutive print moves or travel moves, but not between print moves and travel moves.
@Phaedrux I agree. I could see how it could help alleviate bulging at termination points. I might try it out and see how it goes. If anything, it just makes every move consistent. The beginning and end of every print move would be the same.
@Phaedrux said in Tuning Jerk/Accel/Speed settings:
Interesting. But I don't think I'd want to attempt an instantaneous speed change from rest with the 3Kgs of mass that I have to shift.
Yes, my understanding of it was only between moves. I wasn't aware of it being applied from a resting start. @dc42 would have to clarify.
@Phaedrux AFAIK, in marlin et al, jerk is applied all the time no matter what. Those firmwares are (for some reason, last time I checked) unable to drive the steppers SLOW ENOUGH to start from an actual stop.
@bot can't say really, visually and sound to me seem 100% identical between M566Z0 and M566Z50. I cannot differentiate them. What I can say is that Orion does differentiate them as it reads 775-779 when idling and trigger is set to 850. I move to 0,0 wait 5 seconds and do G30 so the bed starts going up if the M566Z50 the second bed starts to go up I get trigger and if M566Z0 the trigger happens only when the bed hits the nozzle. Looking at the movement, listening to a motor, no difference between the two, but there definitely is something different.
@Phaedrux I did read the manual, but the behavior I'm seeing does not verify what I read there. During first few layers I don't notice any stuttering with
M566Z0
but in any case I did change my script to setup M566Z50 normally and I doM566Z0
only during homing and probing. But again, audio/visuals do not show difference betweenM566Z50
andM566Z0
. I never set P to 1 so whatever is default (0 by documentation).I run now the
M566
without parameters and I set Z0 again and looks like I cannot set zero ?! Maybe it has to do with point that it's printing now but again, nothing set M566 to any value but 0 since the machine was turned on today.2/20/2020, 8:42:50 PM M566Z0 2/20/2020, 8:42:52 PM M566 Maximum jerk rates (mm/min): X: 500.0, Y: 500.0, Z: 6.0, E: 6.0, jerk policy: 0
Seems that lowest value for Z is 6.0 ?
@arhi yes. Right below the section I quoted from the wiki it states the minimum as 0.6mm/s
.................. Yes, my understanding of it was only between moves. I wasn't aware of it being applied from a resting start. @dc42 would have to clarify.
That's two of us then
I wrote "Jerk" doesn't work like that in RRF firmware. Jerk is never applied at the start of a move." To which DC replied "It does in recent versions of RRF if you set the jerk policy to 1 in M566."
@arhi are you positive the Z axis is only moving in one direction when it triggers the piezo? Is the probe command moving the z axis a tiny bit in one direction first? Is any other type of Z compensation enabled when this occurs?
@bot I'm not sure of anything
not easy to see things clearly with all this glass and acrylic. It does look like the bed is put into position and then sits still 3sec as configured and then goes up towards the nozzle. If I set jerk to 0 it works ok, if I set jerk to 60 the start of the movement triggers the piezo.
In any case, none of this is a problem for me, I made it work with analog output and I'm happy with it. It's just confusion about what I'm reading and what I'm seeing first hand. It would be cool to properly understand the behavior that's all.
@arhi I'm glad you got it sorted out!
It's still puzzling that the Jerk value would affect anything in that scenario.
I wish I myself was capable of understanding the source code. I would love to check things over myself but I'm not able to. Not that I don't trust or love the firmware, but there have been a few instances where errant behaviour has gone undetected so I like to highlight problems, no matter how small, when they arise, so they can get attention if they need it.
