No output from G32 on DSF 1.2.4 / DWC 2.07
I wanna say that I first installed my Duet 3, upgraded to RRF 3 stable and all the packages that go with it that I didn’t see the G32 response. There was an update somewhere in between there and now that I was getting it but when DWC 2.0.7 came out and I upgraded all packages, the G32 responses stopped.
After an apt-get sequence, I still get it just fine.
Duet Web Control 2.0.7
Board: Duet 3 MB6HC (MB6HC)
DSF Version: 1.2.4.0
Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)Chrome browser, if that makes any difference.
2/15/2020, 7:14:53 PM G32
Leadscrew adjustments made: 0.118 0.120 0.109, points used 3, deviation before 0.115 after 0.000 -
Tried in chrome just to verify (I usually use Firefox)
What is in your bed.g?
@Danal
; bed.g
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Jan 23 2020 14:06:49 GMT+0100 (Midden-Europese standaardtijd)M561 ; clear any existing bed transform
G1 Z5 H2 ; move nozzle up
;4-point bed levelling
G30 P0 X15 Y45 Z-99999
G30 P1 X15 Y275 Z-99999
G30 P2 X275 Y275 Z-99999
G30 P3 X275 Y45 Z-99999 S3
G1 X0 Y0 F5000 ; move the head to the corner (optional) -
Hmmm... I'm really stumped. I don't see any differences that would make a difference, and I'm getting it consistently.
SSH into your Pi, and try the following (while you run a G32):
- sudo journalctl -fu duetcontrolserver
If that doesn't show anything relevant, then:
- sudo journalctl -fu duetwebserver
There will (should) be a lot more output on the webserver, and again, it is up to our eyeballs to see if anything is relevant.
Hi, I mentioned in another post that since upgrading to RRF3.01_RC1 I too do not get any output from G32. I have Duet3 with raspberry pi.
@Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
This is my output from the above command:
Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file Leadscrew_Levelling.g on channel HTTP
Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file bed.g on channel HTTP
Feb 17 10:50:26 Duet3 DuetControlServer[345]: [info] Executing nested macro file homeall.g on channel HTTP
Feb 17 10:50:35 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
Feb 17 10:50:52 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
Feb 17 10:50:52 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file homeall.g
Feb 17 10:51:02 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
Feb 17 10:51:13 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
Feb 17 10:51:13 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
Feb 17 10:51:26 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
Feb 17 10:51:30 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file deployprobe.g not found
Feb 17 10:51:38 Duet3 DuetControlServer[345]: [info] HTTP: Optional macro file retractprobe.g not found
Feb 17 10:51:38 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file bed.g
Feb 17 10:51:39 Duet3 DuetControlServer[345]: [info] HTTP: Finished macro file Leadscrew_Levelling.gand with sudo lournalctl -fu duetwebserver I get:
Feb 17 10:54:24 Duet3 DuetWebServer[463]: [DoCode] Executing code 'M98 P"0:/macros/Bed Levelling/Leadscrew_Levelling.g"'
Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 69796.3473ms
Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
Feb 17 10:55:33 Duet3 DuetWebServer[463]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
Feb 17 10:55:33 Duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
Feb 17 10:55:33 Duet3 DuetWebServer[463]: Request finished in 69805.2756ms 200 text/plain; charset=utf-8With both examples I notice the Pi does not return to "pi@Duet3:~ $ " is this something to do with the problem?
@chas2706 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
That is due to the
-f
switch which means follow and waits for new stuff to be written to the journal. Not returning to the command prompt without hitting Ctrl-C is normal in this case. -
@oliof said in No output from G32 on DSF 1.2.4 / DWC 2.07:
That is due to the -f switch which means follow and waits for new stuff to be written to the journal. Not returning to the command prompt without hitting Ctrl-C is normal in this case.
Ok thanks I see.
I don't know what the problem is then. I just get no output from the console at all. -
@dc42 Do you have any suggestions.
Also I noticed that when I enter any command in the console it does not work first time I have to enter twice! I am running RRF3.0.2_RC1 DWC2.0.7 DSF1.2.4.0 on Duet 3 board with SBC. -
Yeah, I don't see anything in those logs that looks wrong.
I am well and truly stumped. The "must send twice" is equally weird.
Yes it is both weird and annoying.
The bed levelling must be working because my prints are still good but its not right that you get no feedback.
Do you think that the two issues may be linked?
i.e. there's no bed deviation result because it was only reported once? -
Also I noticed that when I enter any command in the console it does not work first time I have to enter twice! I am running RRF3.0.2_RC1 DWC2.0.7 DSF1.2.4.0 on Duet 3 board with SBC.One for @chrishamm I think, because in standalone mode I don't see any of these issues, and neither have I seen any reports of them. So I suspect it is a DSF issue, or a DSF/RRF interaction.
@dc42 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
dc42 How do I roll back to Duet Software Framework 1.2.3.0 so I can go back to RRF3.0.1_beta2 and DWC2.06 because it was definitely working on that firmware setup.
I’m not seeing any output from G32 either.
Duet3+Pi 3B+
Duet Web Control: 2.0.7
Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3) -
sudo apt-get install duetsoftwareframework=1.2.3.0
Thanks for that.
@Danal Just to be sure: this is my bed.g logs for completeness. Don't believe there's much to go on in there. (by the way, I had upgraded to 3.01-RC2 before.)
duetcontrolserver:
Feb 18 20:30:45 duet3 DuetControlServer[352]: [info] Executing nested macro file bed.g on channel HTTP
Feb 18 20:30:46 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:30:53 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:30:53 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:30:54 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:30:54 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:31:01 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:31:01 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:02 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:31:02 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:02 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
Feb 18 20:31:04 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:31:11 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:31:11 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:12 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:31:12 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:31:19 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:31:19 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:20 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:31:20 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:20 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
Feb 18 20:31:23 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:31:30 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:31:30 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:31 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:31:31 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:31:38 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:31:38 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:39 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:31:39 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:39 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
Feb 18 20:31:42 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:31:49 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:31:49 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:50 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:31:50 duet3 DuetControlServer[352]: [info] Executing nested macro file deployprobe.g on channel HTTP
Feb 18 20:31:57 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file deployprobe.g
Feb 18 20:31:57 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] HTTP: Finished intermediate macro file retractprobe.g
Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] Executing nested macro file retractprobe.g on channel HTTP
Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file retractprobe.g
Feb 18 20:31:58 duet3 DuetControlServer[352]: [info] HTTP: Finished macro file bed.gduetwebserver:
Feb 18 20:30:44 duet3 DuetWebServer[463]: info: DuetWebServer.Controllers.MachineController[0]
Feb 18 20:30:44 duet3 DuetWebServer[463]: [DoCode] Executing code 'G32'
Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
Feb 18 20:31:58 duet3 DuetWebServer[463]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
Feb 18 20:31:58 duet3 DuetWebServer[463]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 73655.5472ms
Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
Feb 18 20:31:58 duet3 DuetWebServer[463]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
Feb 18 20:31:58 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
Feb 18 20:31:58 duet3 DuetWebServer[463]: Request finished in 73656.4125ms 200 text/plain; charset=utf-8
Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
Feb 18 20:33:05 duet3 DuetWebServer[463]: Request starting HTTP/1.1 POST http://duet3.local/machine/code text/plain;charset=UTF-8 3
Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Cors.Infrastructure.CorsService[4]
Feb 18 20:33:05 duet3 DuetWebServer[463]: CORS policy execution successful.
Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
Feb 18 20:33:05 duet3 DuetWebServer[463]: Executing endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
Feb 18 20:33:05 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
Feb 18 20:33:05 duet3 DuetWebServer[463]: Route matched with {action = "DoCode", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] DoCode() on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
Feb 18 20:33:05 duet3 DuetWebServer[463]: info: DuetWebServer.Controllers.MachineController[0]
Feb 18 20:33:05 duet3 DuetWebServer[463]: [DoCode] Executing code 'G32'
Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
Feb 18 20:34:19 duet3 DuetWebServer[463]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
Feb 18 20:34:19 duet3 DuetWebServer[463]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 73870.6134ms
Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
Feb 18 20:34:19 duet3 DuetWebServer[463]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
Feb 18 20:34:19 duet3 DuetWebServer[463]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
Feb 18 20:34:19 duet3 DuetWebServer[463]: Request finished in 73872.5775ms 200 text/plain; charset=utf-8
