Not connecting
Agreed, let's get this thread back on track.
@Phaedrux said in Not connecting:
@deckingman said in Not connecting:
@droftarts I didn't know that @Phaedrux was "staff" either. I thought he was just a long time user like me but with much more time on his hands (and a better disposition/more patience than I have)
Maybe you guys should have "Administrator" after your name like David has?
"staff" may be putting too much weight behind it. Community liaison? Assistant to the regional manager? Would it have helped if the moderator tag was on? Labels can be a distraction. This community forum has a wealth of non-official knowledge, it would be a shame for good advice to be discounted simply because it isn't "official". Not saying that's happened here.
@Corexy sorry for the total off-topic diversion of your thread.
No problem at all, and thanks for all your help on this and other topics.
@Phaedrux It doesn't matter a jot to me. I guess users can always look at a person's profile and check out their post count and/or reputation if they have any concerns about the "quality" of the information that they are being presented with.
That's where I'm at. There's nothing wrong with knowing who you're talking to, especially on the internet. But I'm not all hot and bothered about it.
Back on track...I'm still tipping surges over salt air.
My wife and I were talking about it, and were pretty sure all the trouble started when the UPS broke down and I plugged the printers straight into the power point... I think. We get some insane lightning storms here, and there was a memorable one the night before it all died.
Which makes me reluctant to plug anything in until I've got UPS protection again. Plus it was good having about 3 hours battery backup, nice on those big jobs.
So for the sake of science if I can't fix these boards I'll send them back to the team in the UK at my expense, so they can at least have an opportunity to look at the effects of extreme surges and/or salt air on their boards. I am not suggesting the boards are "weak" or anything like that, they've actually lasted longer at my place than any other. My place seems to be an aggressive environment for printers.
@Corexy said in Not connecting:
I actually thought you were staff lol... you aren't?
No, not me - just an end user. Although the Duet guys have paid me the complement of asking to have my printer on their stand at a couple of TCT shows, so it may seem like I'm staff. In the interests of giving full disclosure, they have given me a few boards for which I have paid in time, rather than cash. So a couple of weeks at shows. (Oh and a few hundred hours testing pre-beta firmware)
Well you've always done well for me, so thanks even more for your time.
I've ordered a full set of batteries for my UPS which will be here before the replacement board and my cheapy Ender 3 backup printer. Cost a bit but so does broken printers.
It's almost got to be surges....we were sitting there the other night and some huge sort of brown out came through, making the lights flicker and the TV go funny. I'm going back to regulated UPS supply only for printers.
@Corexy Your power supply issue kind of got me thinking. A few months ago I fitted a DC UPS to my printer so if ever the mains supply fails, the UPS cuts in and it carries on running off the batteries until power is restored. But note - this is a DC UPS. So no mains inverter and the printer runs (24V) directly off the batteries. It just seemed a bit daft to use a conventional UPS with an inverter to convert DC voltage to mains voltage, then drop it back down to DC with the PSU. The heated is what takes most of the current but mine is mains powered so when the power fails, the bed starts to cool. But it's a big old lump of aluminium that takes a very long time to cool and even them it's only parts with a small footprint that are likely to fall off.
But the reason for all this preamble is that maybe you could do something similar. That is to say, run the printer straight from batteries and maybe use a mains heated bed via an SSR. It probably won't hurt the bed heater if the mains supply is dirty and DC supply straight from batteries will be about as clean as you get I'd have thought. Or alternatively, run the bed cold and use painters blue tape. Obviously you'd need to charge the batteries when the printer isn't running. I didn't envisage the printer having to run more than about an hour or so on batteries so I chose small batteries. But it's surprising just how long they last. Not long after I installed the UPS, I forgot to turn the mains back on and ran the printer for nearly 3 days before I got a low battery warning from the UPS. Admittedly the printer wasn't running continuously for that amount of time, but it was still many hours on (small) battery power. And I run 3 gantries (CoreXYUVAB) and 5 extruders with all the axes motors set to run at either 1.8 or 2.3 Amps.
Just a thought..............
You can read about my DC UPS conversion here https://somei3deas.wordpress.com/2019/10/22/fitting-a-dc-uninterruptible-power-supply-ups-and-separate-5v-supply/
and here https://somei3deas.wordpress.com/2019/10/27/ups-battery-installation/ -
and here https://somei3deas.wordpress.com/2019/10/27/ups-battery-installation/Mate at this stage I'm over all the spending and tinkering.
Your idea is most likely excellent and thank, but I'm committed to this now and will run with it until it proves unsuccessful.
This is a pretty serious American UPS I got cheap, but it's always needed a new set of batteries. I've used this for 2 years and never had a printer that was connected to it fail.
I do wonder how power surges would even reach the board through the switch mode power supply, but it still seems the most likely.
@Corexy, do you have DC ground connected to mains ground? I do that right at the PSU terminals. And how good is your mains ground?
Please confirm that you do not have a USB connection between the Duet and a PC - because if you did get a transient on ground, the USB ground loop would pass that to the electronics.
@dc42 said in Not connecting:
Cheers David,
I just put a meter on it, and mains power earth to the Meanwell PSU chassis is zero resistance, but the earth to the aluminium printer chassis is not so good.
I do not have the DC and AC earths connected...is that a thing? I've never seen that before but if you say it's the way to go I will.
Not sure what you mean about "do not have a USB connection between the Duet and a PC", but if you mean during a print, no never. I absolutely never hook up to the computer other than events like this. Everything I do is generally via the DWC.
Do you want me to connect the AC and DC earths to each other?
**EDIT.
Sitting here right now and we just had a large surge event of some sort...lights dimming, appliances making noises.
You could be forgiven for thinking I live in a 3rd world country with this sort of power supply, but this is a newish subdivision which supposedly had all the good gear.
@Corexy Out of curiosity, whereabouts in the world are you?
I am on the lovely mid north coast of NSW, Australia, just out of Port Macquarie and about 70m from a patrolled surf beach.
It's absolutely beautiful except for 3D printers it seems.
I also lived in your country (if you are in the UK) for 2 years.
About half way between Sydney and Brisbane? Getting way off topic - I'll PM you.
This post is deleted! -
@Corexy Just PM'd you - no point in cluttering up the forum with personal stuff.
Copy that, I just deleted my post for that reason
Yay! I'm back up.
Thank you to Roland with helping me out behind the scenes, and again I'd like to offer to send you these 2 blown (or just screwed up by my programming skills) boards at my expense so you can have a look at the effects of 2nd world mains power supply and sub tropical lightning storms on your gear. I don't want anything else, this would be on me as you've been a great help.
I will say that I had no trouble setting up my new board. I just run the configurator and uploaded the whole ZIP file, then copy/pasted my old config.g etc in there. Didn't even need to set the Z offset again.
It's all plugged into a full isolation UPS now, with brand new batteries and will never be plugged into an unprotected supply again.
I'm open to the possibility that I've done something wrong with the old boards, but given the properties history for blown up electronics I doubt it.
I do not think it has anything to do with the Duetwifi product itself, for the record.
@Corexy Glad you are sorted. Fingers crossed that's the end of your probs.
You've seen my track record...you should be more careful with your fingers lol
Straight back into it though. I've got a Micro Swiss all metal kit for this model (Zortrax M200) and a very high temp build plate with Printbite on it. My plan is to get this one running some high temp PC prints, ABS and Nylon in this one. It really works well and I've got a good temp controlled cabinet on it.
In the meantime I bought this little Ender 3 Pro, but I'm kind of enjoying it anyway and it's an intro into V slot printers.
Yes, I know - already mangled the little one .....
I'd be calling that "my backup" for reasons I won't be explaining.
