Bench Testing Mixing Extruder with Pronterface
@deckingman - with that note - trouble - I was expecting to be able to designate a tool that utilized 5 extruders with a simple text command M563 P0 D0:1:2:3:4 with printrun it bounces back that there is an error with the drive numbers. Also - I have not been able to issue simple gcode commands via Duet Web Control - though I am able to connect...
What does the error say?
What happens when you try to send commands in the DWC console?
@Phaedrux Nothing happens when I attempt to send gcode through the Duet Web Interface - though the log state that I am connected, the log does not indicate that any code was sent. Another issue that I am having with DWC is that if I attempt to upload the zipped reprap config file I get an AJAX error and it disconnects. If I remember right - I was having this issue before and had to disconnect my power supply from the board and run it strictly of usb to get the upload to work - very inconvenient. I guess I'll open my housing and pull the micro SD out to update reprap config files.
To the issue at hand, which is getting a tool designated for bench testing my extruder setup. The following is how print run responds when issued:
SENDING:M563 P0 D0:1:2:3:4
Error: Tool creation: bad drive number
[ERROR] Error: Tool creation: bad drive numberI'm using a duet wifi with x5 expansion - I have a total of 7 extruder steppers and for this tool I am trying to use the 2 that are on the Duet Wifi and the first 3 that are on the x5 expansion.
Sounds like you might have a mismatched DWC version? What versions are you running?
@Phaedrux - you may be right - this is what is listed on DWC. Should the Web Interface Version be HTML: 3.0? I'm starting to get very confused...
Firmware Version: 3.0 (2020-01-03b3)
Web Interface Version: HTML: 1.11 -
@Phaedrux - not able to upload file with DWC - followed instructions here:
to unzip DuetWebControl-SD.zip onto SD card after deleting old file contents
issue remains - AJAX error when uploading files via DWC
Just to confirm, you've wiped out the /www folder and replaced it with the contents of the zip file and the DWC version now shows as 2.0.7?
What browser are you using?
@Phaedrux -scratch that - installed and seems to be in sync now.
still trouble defining tool head - same bounce back from DWC on issuing M563 P0 D0:1:2:3:4
'tool creation:bad drive number
@ractorIII said in Bench Testing Mixing Extruder with Pronterface:
M584 X0 Y2 Z1 E3:4:5:6:7:8 ; set drive mapping
How do you have your motors connected? The drive mappings don't match what you're trying to use for tool drives.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Feb 01 2020 21:20:25 GMT-0500 (Eastern Standard Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S1 ; physical drive 4 goes forwards
M569 P5 S1 ; physical drive 5 goes forwards
M569 P6 S1 ; physical drive 6 goes forwards
M569 P7 S1 ; physical drive 7 goes forwards
M569 P8 S1 ; physical drive 8 goes forwards
M569 P9 S1 ; physical drive 9 goes forwards
M584 X0 Y2 Z1 E3:4:5:6:7:8:9 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16:16:16:16:16 I1 ; configure microstepping with interpolation
M92 X87.58 Y87.58 Z1511.57 E3200.00:3200.00:3200.00:3200.00:3200.00:3200.00:3200.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00:1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800:800:800:800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-315 Y-650 Z-50 S1 ; set axis minima
M208 X315 Y650 Z300 S0 ; set axis maxima; Endstops
M574 X0 Y0 Z0 S0 ; set active low and disabled endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X-300:215 Y-635:195 S20 ; define mesh grid; Heaters
M140 H-1 ; disable heated bed; Fans
M106 P0 C"FAN3" S1 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 C"FAN4" S1 I0 F500 H-1 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 C"FAN5" S1 I0 F500 H-1 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 S"V" D0:1:2:3:4 F-1 ; define tool 0
M568 P0 S1 ; enable mixing for tool 0
M567 P0 E0.2:0.2:0.2:0.2:0.2 ; set mixing ratios for tool 0; Custom settings are not defined
T0 ; select first tool -
@Phaedrux - yeah - I wasn't sure if the drive should match the extruder number or the drive number, so I tried both M563 P0 D0:1:2:3:4 and M563 P0 D3:4:5:6:7 am getting the same 'tool creation: bad drive number. I read the sections on drive mapping and tool defining and everything seems to be in order. Unless I missed something. Dumbfounded at the moment.
@ractorIII The drive numbers used when you define a tool refer to the extruder drives in the order that they are created. So if you have physical drives assigned to extruders 3 to 7 in M584 then the extruder drive numbers when you define a tool are 0 to 4. Which looks like that's how you have done it.
Perhaps the M584 command to set up the extruder drives failed. If you send M584 without parameters, what does it report?
EDIT: maximum number of extruders supported by RRF3 on Duet 2 is 6. So your command:
is failing because you are trying to create 7 extruders. If you really need 7 then I can increase the limit.
thanks @dc42 - I need 5 extruder steppers at the moment - if that is the case I'll remap my motors so my dual Y steppers are not doubled up on one driver. Maybe that will fix my issue - I'll look into your other suggestions later today.
I would be interested in having more extruder steppers available in the future - or even the ability of mapping all of the drivers as extruders - the goal would be precise stationary liquid slurry mixing machine.
@deckingman - thanks for your help. Eliminating the E6 driver mapping resolved the issue. All steppers are tested to be operating as expected.
I would like to use that final stepper on the Duex5 as an extruder eventually but will not need it anytime soon.
Sorry - this was meant to be a message toward @dc42 :
I'll increase the maximum number of extruder drivers to 7 in the next RRF3 build for Duet 2.
