S-Curve/ sinusoidal , Jerk +acceleration
@dc42 I know this is an old topic but your post here is 100% wrong, it is not entirely about ringing. It is instead about how stepper motors work. As you get higher RPM the motor loses torque exponentially. With a proper S curve and a rigid machine it may be possible to cut print time in half without losing steps or quality as you can use every bit of available torque at any given RPM with no fear of step-loss. Gone is the need for max speeds and conservative accelerations as you are only limited by the motor. Instead of the motor at the highest RPM in your desired speed range. There is no fear of going "too fast", setting a max speed is not necessary beyond a software limitation to catch errors in calculation.
Personally I am searching for a feature that dynamically allows the user to define their own curve biased on the torque curve of the steppers. Marlin has already done this, it is not impossible. Though I do not believe they allow this to be user customizable.
Not sure how this slipped past you guys.
@Sphyloid Whilst I accept what you say may be true as a general statement, it only applies to situations where motor torque is a limiting factor, and with the light weight tool heads that 3D printers use, achieving the desired torque is easily done by selecting an appropriate motor. For 3D printers the overal print speed is limited by how fast you can melt and extrude filament, not by how fast you can move the hot end in X or Y directions. So I have to disagree that any form of fancy acceleration control is going to reduce print time at all, let alone cut it in half.
Whilst I accept that there may be some benefit in using S curve acceleration with CNC tool heads that have mechanical cutters, I fail to see how one could coax the filament being forced through a tiny hole to faithfully follow an S curve acceleration profile in the same way that the hot end carriage might. Smooth linear acceleration of molten filament is difficult enough to achieve, due to the severe damping effects and time lags involved with melting filament and forcing that viscous fluid through a tiny hole.
Did the math out and found something very intriguing.
Say your moving mass is 200 grams. With the pitch diameter we can find the force exerted by the motor on the print head, lets say a GT2 12 groove has a pitch diameter of 7.65mm. With a circumference of ~24mm you would get 0.06mm steps out of a 0.9* stepper. Also lets get some RPM numbers at 20mm/s it would be turning 50rpm, 60mm/s would be 150rpm, and 150mm/s 375rpm.
Now that we have our numbers, lets use MS17HA6P4150 running at 24V 1.5A which would make a minimum of 0.385nm from 0-20mm/s, 0.3105nm from 20-60mm/s, 0.16nm from 60-150mm/s. Bear in mind that is only if the driver is outputting 24V 1.5A, at lower supplied voltages the drop is far more aggressive. 12v for example the 60mm/s number being ~30% lower and the 150mm/s number being ~50% lower.
In this config the motor would be able to exert ~100N at 20mm/s, ~80N at 60mm/s, ~40N at 150mm/s. From F=MA we know that the maximum acceleration at 20mm/s is ~500m/s^2, 60mm/s is ~500m/s^2, 150mm/s is 200m/s^2. Then why are numbers for real 3D printers so low? There are several possibilities
-The bottleneck is the extruder
-The weight is higher in real life
-The achievable torque is much lowerWe already know that in i3 style printers using current firmware all three are true. Having movements made of many straight lines instead of curves makes mathematically calculating accelerations very difficult. The stress we are putting on the motors is not immediately obvious. Also lets face it, 3D printers supply their motors with much lower voltages and use far weaker motors. Though I am not familiar with the output voltages of the duet 2, I doubt you can output 12V let alone 24V from that driver chip. Perhaps what is left on the table is more on the hardware side than the software side. With this information I would change my argument to an increase of driver output voltage is better than anything possible on the software side, which is what I believe you have done with duet 3. At which point the increase in vibrations/ringing from an extruder that can keep up may have a greater impact. Increasing printer quality is more complicated than I may have given it credit. Similar to how people think having steel bones would make them much stronger when pound per pound having bigger bones would be stronger.
Perhaps using step files in place of STL would yield better quality and less stress on the motors but would it be an appreciable difference? My opinion has shifted. I now think a duet and an e3d hemera are the best upgrades you can make to any 3d printer. Except on the machine I am engineering. Net moving mass is about 5kg, Hbot linear motion, internal volume is 0.36 cubic meters up to 200C heated enclosure, 220C heated bed, 500C hotend. At this scale, there is appreciable acceleration left on the table. The motion system is very interesting. While the way I designed it for my application is quite overkill, I believe it will yield the cheapest printers for a given stiffness. The designs will be released early 2021 and you will see me at 3d printing events later this year.
@Sphyloid said in S-Curve/ sinusoidal , [censored] +acceleration:
I'm sorry, that's just not true. With constant-current drivers, torque is essentially flat until the supply voltage is insufficient for the required speed. See.g. https://www.omc-stepperonline.com/download/17HS16-2004S1_Torque_Curve.pdf. When the supply voltage is no longer sufficient, the torque drops off approximately in inverse proportion to the speed.
It's a bad idea to run stepper motors at speeds for which insufficient supply voltage is available. The current control won't be accurate, so microstepping won't work any more, precision will suffer and the motor will be noisy; and in the event that the print head hits a blob or curl-up, the motor is likely to lose steps because of insufficient torque to clear the obstruction (which also happens when using stealthChop mode at high speeds). If you ignored all of this and you did want to run the motor in that region, then I concede that reducing acceleration at high speeds would help - which isn't the same thing as using S-curve acceleration.
S-curve acceleration is on our list of features to implement, but only when we can also sort out the far worse issue of [censored].
Accelerations and instant speed are generally set low to maintain print quality. 3D Printers on the whole aren't rigid enough run at max motor accelerations and get good part quality.
Exactly so!
scurve is super cool on miling machine, there can be serious difference in quality if yourun scurve capable machine vs trapesiod .. no clue if it would help on 3d printers but.. read the whole topic and one thing is unclear to me .. the major 2 alghoritms to handle speed change between two lines are "[censored]" and "junction deviation" .. grbl started with [censored] and moved at some point to junction deviation ... most firmwares that used grbl as a base used old version of grbl and are using [censored] (e.g. marlin) while others that started from scratch or used newer version of grbl went with junction deviation (e.g. smoothieware) ..
what I read so far junction deviation gives better quality both for milling and for 3d printing and hear marlin will be moving to it too (first implementation available in mid 2018 iirc, no clue where they are now with it I don't use marlin)
So, what is RRF using ?
RRF uses [censored]. I am quite prepared to add junction deviation as an alternative. However, junction deviation has IMO no sound theoretical basis whatever. The "deviation" figure is purely an artefact.
The practical differences between the two are:
As the angle between entry and exit segments increases, the allowable cornering speed falls off more quickly with JD than with [censored]. For example, with acceleration 1000 and [censored] 600, if I set JD to 0.013 then at 5 degrees the cornering speed for both JD and [censored] is about 115mm/sec. At 90 degrees it is 5.6mm/sec for JD and 10mm/sec for [censored].
[censored] gives different values depending on the angle of entry. For example, in the above calculation the angle of entry was zero (i.e. aligned with X). If I change it to 45 degrees then using [censored] the allowable cornering speed for a 5 degree change in angles jumps from 115 to 155mm/sec. The allowable cornering speed using JD does not change. This makes sense for a Cartesian printer. It doesn't make sense for a delta, and perhaps not for a CoreXY either (depending on the relative sizes of the moving X and Y masses and the reflected rotor inertia).
A true junction deviation system, where the deviation is planned not imaginary, would make far more sense because it would allow instantaneous speed changes to be eliminated. But JD as implemented explicitly doesn't do that.
@dc42 said in S-Curve/ sinusoidal , [censored] +acceleration:
Thanks for the info
I can't really compare [censored] vs JD as I don't have a firmware that support both so I can try one or another, I can compare 2 different firmwares where one is using [censored] and other jd but that's not fair comparison as if I for e.g. compare smoothieware with marlin the prints are ton better on smoothieware but I guess it has more to do with 32bit arm vs 8bit atmega than with [censored] vs jd ... on the other hand if I add stuff like pressure advance on marlin that smoothieware don't have then I can get better result from marlin again irrelevant with jd/[censored]... so maybe the reason I think JD is better is just
- I see firmwares moving from [censored] to jd, never seen one move from jd to [censored]
- the professional big cnc controllers use jd
- new grbl moved to jd too (from [censored])
so it's all 2nd or 3rd leve data, I have no way to test any of that myself other than implementing the move myself... time, for sure, and possibly lack of knowledge prevents me from doing that
"as implemented" where? open source implementation I know are grbl and smoothieware (not same). klipper use junstion deviation and but according to https://github.com/KevinOConnor/klipper/issues/468 https://github.com/KevinOConnor/klipper/blob/master/docs/Kinematics.md define it trough square_corner_velocity. I like the smoothing klipper does (looks much close to S-Curve) but all three seems to be using different junction deviation algo
Why not implement "true" jd system with smoothing ? From untrained/uneducated eye it looks like a winwin (except for the one that need to write the code but..)
I suspect that the move from [censored] to JD is more to do with fashion than anything else. Still, it doesn't make sense to treat X and Y [censored] separately on delta printers and some other architectures.
When cornering at shallow angles, it isn't going to make much difference whether [censored] or JD is used. The difference will come when doing sharp corners, where JD will slow the print head down more. Alternatively, if you set the JD to give equivalent [censored] at 90 degrees to the [censored] values you would have used (e.g. using the formula at http://blog.kyneticcnc.com/2018/10/computing-junction-deviation-for-marlin.html), then JD will allow faster cornering at shallow angles.
Another effect is that when using JD, if you reduce acceleration then the maximum cornering speeds will be reduced in line. This may not be desirable. For example, if you decide to reduce acceleration in an attempt to improve print quality, then curves may be printed jerkily instead of smoothly, because the print speed is greater than the (reduced) allowed cornering speed. So you may have to increase JD to compensate. If you then restore acceleration back to its former value, you may get skipped steps because you are now asking the motors to change their speed instantaneously by too great an amount.
Perhaps a better approach would be to configure a "maximum speed to do a 90 degree corner" instead of a mythical deviation value, and then to calculate the maximum speed for a given angle using the same (complicated) speed vs. angle relationship that JD uses. Or perhaps there is a better relationship to use.
Even if using this approach or native JD, we'll still need to configure Z [censored] (to handle instantaneous speed changes when doing bed compensation) and extruder [censored] (to handle buggy slicers and pressure advance).
always a possibility
I hate changes that are fashion onlyStill, it doesn't make sense to treat X and Y [censored] separately on delta printers and some other architectures.
IMO it should be separate for all axes, the gro of these el-cheapo PRC printers have a moving bed, you can't have same [censored] settings for Y where you move 5kg bed and X where you move 100g head.. just like you cannot have same acceleration nor same max speed...
no clue about delta, corexy or some of those exotic architectures ... I assume corexy will have same X and Y settings but not sure what I base that assumption on
Yes, I know this (dunno much but this I experienced on my skin so I know), you have to change JD and acceleration at the same time, they are dependant on each other (I assumed it's the same with [censored]?)
It's easier to explain for sure and easier to visualize. Maybe that's why klipper is doing it.
Z does introduce complication here for sure, but if implementation allow for separate JD setup (trough 90ΒΊ or whatever settings) for each axis then the Z, E, A would just be another axis?
That "smoothing" klipper does, that looks like S-Curve, sounds great on paper, I assume it is unrelated to JD/[censored], is RRF doing that? Do you think that has merits? It looks to me that it would reduce shaking immensely and lot of slicers still generate those "shaky" codes filling in gaps.
Don't get me wrong I'm talking out of my %#$^^@$ here, trying to learn as much as I can from this conversation. I'm hardly an expert in these matters
@smece said in S-Curve/ sinusoidal , [censored] +acceleration:
Except that any print move, will take place at the lowest speed of X, Y and E. If you have different instantaneous speed thresholds ([censored]) for X and Y, for anything other than pure X or pure Y, then one or other will have to be ignored otherwise the axes movements will get out of sync.
I think the last 2 comments in this thread are quite a good summary: https://www.reddit.com/r/3Dprinting/comments/ccvn0z/is_junction_deviation_better_than_using_normal/
An incidental possible advantage of reducing the cornering speed more as the cornering angle increases is that the reduction in the [censored] used when you do 90 degree corners would make dynamic acceleration adjustment more effective.
Perhaps we should provide the following factors:
- An effective maximum XY [censored] value, used when cornering at shallow angles. When cornering, the speed times the sine of this angle must not exceed that [censored] value.
- A factor that says how much to reduce the [censored] by when cornering at 90 degrees. This would be zero to emulate the existing [censored] algorithm, and about 0.4 to emulate junction deviation. A value of 1.0 would require coming to standstill when doing a 90 degree corner.
We could go further and add a third point, which is the factor to reduce [censored] by when reversing direction (cornering at 180 degrees).
Here is a chart showing the differences between [censored] and junction deviation at various cornering angles. The two [censored] values were for entry angles of 0 degrees and 44.9 degrees. [censored] was set to 10mm/swc for both X and Y, acceleration to 1000mm/sec^2, and JD was set to 0.013 so as to match the 0 degree [censored] values at low angles.
First: I appreciate all the effort, work and thought that is put into RRF by everyone, but especially dc42.
Second: RRF 2.0x IMO has a GREAT and 100% adequate motion model. I am able to PRINT at 100 mm/s, with [censored] and acceleration set appropriately, and have ZERO ringing on very sharp angled corners. [Edit: this turned out to be slightly incorrect. At the time I made this comment, I was doing certain prints at 100 mm/s that did not show the low-frequency oscillation that was occuring. I can NOT print at 100 mm/s -- I get an ultra low frequency oscillation above about 40 mm/s, increasing in amplitude as speed increases] There is also minimal bulging/under-or-over extrusion on the corners, thanks to pressure advance.
Third: I could see areas where we could push the limits and decrease print time slightly while maintaining PERFECT print quality.
This third point is the key. Let's not go ruining something that is nearly perfect for something that is not even close to perfect but a bit faster. Mechanical hardware plays a large role in this. I hope we don't target faulty mechanical setups with the motion algorithms.
One simple idea I had was to be able to scale the [censored] and accel (or only one or the other) based on requested move speed.
EG: user sets max accel and [censored] values, which will be used on moves which execute at the axes' maximum feedrates. If a feedrate is set lower than the maximum, the [censored] and/or accel values are scaled proportionally to the feedrate reduction.
@bot said in S-Curve/ sinusoidal , [censored] +acceleration:
Scaling [censored] in this way might be good. Scaling acceleration may increase ringing. One of the reasons that DAA doesn't work for some users is that they have acceleration set too low.
@deckingman said in S-Curve/ sinusoidal , [censored] +acceleration:
I think I read this already somewhere but I understand it differently ... e.g. if there's no ZE move but only XY then ZE will not be looked at right... now.. the way I imagine XY move (and then easily interpolated further) ..
let's imagine a junction where direction change in X is 10 degree and direction change in Y is 1 degree so if the deviation/[censored]/whatever is same for X and Y the drop in X speed should be f(10) and drop in Y speed should be f(1), real speed should be the max speed where X does not go over f(10) nor Y go over f(1)...
but I fear it's not how it works
but I fear it's not how it worksThat's exactly how it works.
@dc42 hah, that's not how I read the code need to do it rested obviously
thanks a ton for that graph, explains everything :D, now I understand better the difference in curve shape
btw the "smoothing" I mentioned from klipper, RRF don't do that? you think that's a good feature? to me it looks like a good middle ground between trapesoid and s-curve and good for both corexy and cartesian
