SSR stuck on???
@gnydick said in SSR stuck on???:
@bearer any pointers on how to set that up? Would I just wire two of the pwm pins to the SSR and map the bed heater to that pwm?
i'd use the "ground" from a fan, that ground is pwm controlled by the duet and you can use any supply voltage, the one on the fan output is convenient though. then unmap the fan if needed and map the heater. I'm sure some of the wizzards can help with the config if needed
@Phaedrux I am, but it will take time. I'd like to get everything else tested out while I wait.
You can also use a spare heater output on the Duet or the DueX5.
Here's the directions for using a chamber heater. It's the same principal. Using an alternate pin for controlling an extra heater. The only difference for you is that instead of defining a new heater 3, you'd be altering the configuration for heater 0 (the bed on duet 2)
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_a_chamber_heater
@Phaedrux thanks
It is highly unlikely that the SSR has failed since it is not stuck in the 'on' position. It is way more likely that there is a wiring error.
Are you aware that the positive line will always be high no matter if the heater is on or off?
Simply wiring the negative to ground will cause all these issues.
Verify the ruting of the two control lines. -
@dc42 do I remap a pin to H0 or do map a different heater to "bed"? I'm kinda lost as to which direction to go.
If you are using RRF2 then use a different heater number. Use M140 with an H parameter in config.g to tell the firmware which one.
It's very usual to have a dud bed heater mosfet on a Duet. Is the bed heater LED on the Duet permanently illuminated too?
@whosrdaddy said in SSR stuck on???:
@gnydick : If I look at your photo, I believe you made a wiring error, you have wires labeled "BED-SSR" connected to the VIN connecter an wired VIN to the Bed output connector!!!! Please double check your wiring, diagrams can be found here
Well spotted!
I stared like 10 minutes at his photo and didn't see the error, thanks to @jens55's remark, it all made sense
Completely glossed over that one. Should have looked at the diagram.
But my test asked to disconnect the bed wiring and test the terminals without an SD card present. Was that not actually carried out?
@whosrdaddy yep, that was it! Thank you!
@Phaedrux I didn't, I just disconnected the SSR and used the wires
I guess then with vin being fed into the bed terminals it was also present on the actual win terminals. Of course.
Sometimes I wonder why you even bother asking for help here, you clearly think you know better than all of us.
First post: “it’s all wired correctly”
Humble pie!
@elmoret I'll be the first to admit when I'm wrong. I didn't insist or argue that it was correct or protest against sending photos. So what's your point?
