RepRapFirmware 3.0RC1 released
@3dmntbighker said in RepRapFirmware 3.0RC1 released:
I think the stuff after the T0 is just from copying from the DWC web page.
In any case, try putting the "M669 K1" at the top of the file. I don't think it'll make a difference but it may.
This is covered In the upgrade notes. S0 is no longer supported in M574. Use S1 and invert the pin using ! at the start of the pin name.
@gtj0 said in RepRapFirmware 3.0RC1 released:
Yeah, looking at the file directly on the SD card it looks normal. I can enter M669 K1 in the console and no difference. It really seems to be an issue with M574? There seems to be no way to change the end stop from active high to active low. Changing M574 it always acts the same.
@dc42 said in RepRapFirmware 3.0RC1 released:
It's not noted in the M574 section of the RepRap changes document. Nor on the main G-code page. Which does have many notations about RRF3.
Thanks, I'm operational now. I had some issues with the Piezo sensor but I resolved those.
@3dmntbighker TBH, I didn't know that S0 had been withdrawn either. I was going by this thread https://forum.duet3d.com/topic/13136/m574-usage-on-rrf-3 where David said his intention was not to withdraw S0.
@deckingman said in RepRapFirmware 3.0RC1 released:
That's what we get for being bleeding edge. I don't ask for apologies
DC is "the man". He's done as much for my 3D printing as anyone.
Yes, I changed my mind. I found an inconsistency in how local and remote endstops configured using S0 were treated, and that led me to decide that providing two ways of doing the same thing was an unecessary complication.
Fair enough. @droftarts or someone needs to update the Gcode documentation to reflect that. https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
@deckingman, that's already in hand.
@dc42 @deckingman Done!
need configuration help to connect PT100 via board to DuetWiFi 2 v1.03
after upgrade to rrf-3 i changed config and everything works but the extruder temp sensor. it shows 2000 deg...
downgrading to 2.05 shows correct temperature.here are related lines:
old RRF2 config
M305 P1 S"T0" X200 R395 W2 M143 H1 S350 A0 ; max temp 350 on heater 1, fault if above M570 S60 H1 P10 T15 ; Hot end may be a little slow to heat M563 P0 D0 H1 F2 ; tool definition
RRF-3
M308 S1 P"e0_temp" Y"rtd-max31865" R395 F50 M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1 M143 H1 S350 A0 ; max temp 350 on heater 1, fault if above M570 S60 H1 P10 T15 ; Hot end may be a little slow to heat M563 P0 D0 H1 F2 ; tool definition
w
@c310 said in RepRapFirmware 3.0RC1 released:
old RRF2 config
RRF-3
w
M308 S1 P"spi.cs1" Y"rtd-max31865" R395 F50
Oh yeah, a versioning discussion!
I'm waiting for final 3.0 release to finally get to merging some stuff into it. Do we have any significant non-functional (e.g. performance) improvements over 2.x? I've seen some threads discussing similar stuff, but nothing concrete in the release notes. I'm that guy running crazy PA values with many motors on high speeds so the Duet 2 CPU struggles (not complaining at the moment, just wondering).
@3dmntbighker WoW! thanks!!!
I had to "guess" the same thing 2 days ago because they didn't include those port names under Maestro? I presumed the names would be the same as on Duet WiFi (which I also have with a PT100).
another temperature / pin question:
in RRF3 which ID should i assign to CPU temp sensor?
in RRF2 it wasM106 P1 L30 T44:63 H100:101 C"System"
@c310
i use this commands to declare the "virtual" sensorsM308 S20 Y"mcu-temp" A"CPU" ; Defineix sensor S20 com a temperatura de la CPU
M308 S21 Y"drivers" A"Duet_drv" ; Defineix sensor S21 com a temperatura dels drivers de la duet
M308 S22 Y"drivers-duex" A"Duex_drv" ; Defineix sensor S22 com a temperatura dels drivers de la duex5In this case, sensors 20 to 22 to declare mcu & drivers.
After that, use it as a standard sensor.Hope it helps you. I'm runing 3.0RC1 on a DuetWifi + Duex5 and there is no issue at all. A little tricky to configure but not impossible, using Reprap config tool as a start point.
In the Upgrade Notes for RRF 3.0RC1 I forgot to mention that on Duet 3, there is no longer a default bed heater configured. Use M140 to configure one, for example M140 H0 will usee Heater 0 as the bed heater.
For the record, 3.0RC1 on my Maestro seems to have the same issue Duets have always had for me. The DWC sometimes dies part way through the print. The print completes, but a hard reset is the only way to get the DWC working again. This happened in my WiFi as well.
