Laser turns off after following code is sent after M3
@morokolli said in Laser turns off after following code is sent after M3:
Reload of sample and config.g.
config.g.txt
peukku.nc.txtM452 C"exp.heater5" Q200 ; laser uses heater3 pin, PWM frequency 100Hz
You didn't select sticky laser power. https://duet3d.dozuki.com/Wiki/Gcode#Section_M452_Select_Laser_Printer_Mode
Still same thing while using:
M452 C"exp.heater5" Q200 S1
Here's video:
https://www.youtube.com/watch?v=2FMmwe_Vmpk -
More debug info:
If F value in G1 F300 is more than F1015 All lines are done as they should. If i's lower, piece is missing. And if speed is added over F1200, next line starts to suffer. Hopefully picture explains better:
any update on this? im having the same issue.
M452 is set to sticky in the config but (quite randomly) it forgets the Gcode "stickiness" and only restores after it hits the next G1 Sxxx
settings in my config file:
M307 H2 A-1 C-1 D-1 ; Disable Heater output on H2 M452 P2 I1 S1 R255 F200 ; Enable Laser mode, on output 2 (heater 2), with max intensity being 255, and a PWM frequency of 200
example of some gcode that causes issues (a simple square being cut)
; ; Operation: 2 ; Type: Laser Cut ; Paths: 1 ; Passes: 2 ; Cut rate: 5 mm/s ; ; Pass 0 ; Pass 0 Path 0 G0 X57.57 Y76.11 ; Pass Z Height 5mm (Offset: 0mm) G0 Z5.00 M3 G1 X7.57 Y76.11 S255.00 F300 G1 X7.57 Y9.42 G1 X57.57 Y9.42 G1 X57.57 Y76.11 G1 X57.57 Y76.11 M5 ; Pass 1 ; Pass 1 Path 0 G0 X57.57 Y76.11 ; Pass Z Height 4.8mm (Offset: 0mm) G0 Z4.80 M3 G1 X7.57 Y76.11 S255.00 F300 G1 X7.57 Y9.42 G1 X57.57 Y9.42 G1 X57.57 Y76.11 G1 X57.57 Y76.11 M5 ; Disable Laser/Spindle M106 P2 S0 ;turn off laser power
It seems quite random.
in the above case it did the first two lines of the cut before turning the laser off, restarted on the second pass and completed all 4 lines,I ran the code again straight away and it did all four lines of the first pass, and turned off after the 3rd line of the second pass.
Im running the latest firmware RC4
@craigb244 said in Laser turns off after following code is sent after M3:
The latest full release is 2.04. What RC4 are you using? It's definitely not the latest.
@Phaedrux sorry I was half asleep when I wrote that and been playing with a lot of firmwares (on other stuff)
I have the lastest firmware downloaded 2weeks ago, so what ever that is... I'll report back later when I'm home .
I'll test that square file on 2.05RC2 which is ready to go out. But I recommend RRF3 for laser cutters/engarvers because it implements velocity ramping.
; Operation: 2
; Type: Laser Cut
; Paths: 1
; Passes: 2
; Cut rate: 5 mm/s
;; Pass 0
; Pass 0 Path 0
G0 X57.57 Y76.11
G0 Z5.00M3
G1 X7.57 Y9.42
G1 X57.57 Y9.42
G1 X57.57 Y76.11
G1 X57.57 Y76.11
M5; Pass 1
; Pass 1 Path 0
G0 X57.57 Y76.11
G0 Z4.80M3
G1 X7.57 Y9.42
G1 X57.57 Y9.42
G1 X57.57 Y76.11
G1 X57.57 Y76.11
M106 P2 S0 ;turn off laser powerI just tested that file on 2.05RC2. It runs OK except that it turns the laser off at the start of the 4th side of the 2nd square. I will look into it.
On further investigation:
- You are using both M3/M5 and G1 S parameters, which I wasn't expecting;
- If I delete the M3/M5 commands so that it uses just G1 S oarameters, it works correctly
- If I delete the G1 S parameters so that it uses just the M3/M5 commands, it fails
So G1 S parameters appear to be wrking correctly. but M3/M5 commands are not.
I found the issue with M3/M5 in laser mode. I am postponing the 2.05RC2 release until I have fixed it.
@dc42 thanks for looking into this and glad my info helped find the issue (even more glad it's not something I've done my end!)
By the way my firmware is 2.04RC4 (2019-10-19b1)
Quick question...
You say "You are using both M3/M5 and G1 S parameters, which I wasn't expecting;"Is using M3/M5 not the "correct" way to control the laser?
Is using M3/M5 not the "correct" way to control the laser?I was expecting user to either use M3/M5 to control the laser, or (preferably) use the G1 S parameter.
To fix this, what I plan to do is to make M3 set the default laser power for the start of the next G1 move, but not turn the laser on immediately. Likewise, M5 would set the default laser power to zero for the start of the next G1 move, but not turn the laser off immediately if it is moving. In both cases, an S parameter on that G1 move would override the power set by M3/M5.
Does this sound reasonable? It means that the laser will never be on when the machine is not moving. In one way, this is safe because it avoids accidentally burning a hold in the bed. However, it means you could leave the machine in a state in which the laser has been "primed" by M3, so that it turns on (perhaps unexpectedly) when you next do a G1 move.
I have now made this change and released firmware 2.05RC2. Please note, your original file included M3 commands with no S parameter. This is not correct, because the M3 command requires the S parameter to specify the required laser power. However, as your code includes S parameters on G1 commands, the M3 commands are not needed.
I note from https://reprap.org/wiki/G-code#M3:Spindle_On.2C_Clockwise.28CNC_specific.29 that Repetier firmware also does not fire the laser except during G1/G2/G3 commands.
Thanks,
The code is what came directly out of laserweb 4, I might message them and see how I can change the way the gcode is produced,I'll update my firmware tonight and let you know how it goes.
Thanks again.
Craig
Updated to 3.0RC1, similar errors.
In my earlier example (peukku.nc) error have moved to another location (bottom line).
And while lasering star last line fails.
Gcode used for star:;Project taehti ; *** START begin *** G90 G21 M84 S0 G92 X0 Y0 Z0 ;No. 1: Engraving 1 M3 G00 X15.2204 Y25.2874 F1200 G01 X10.3421 Y17.0845 F1200 S255 G01 X1.3756 Y19.1117 S255 G01 X7.3967 Y12.1317 S255 G01 X2.4490 Y3.8119 S255 G01 X11.2939 Y7.6139 S255 G01 X17.5111 Y0.4065 S255 G01 X16.6361 Y9.9102 S255 G01 X25.4043 Y13.6792 S255 G01 X16.0954 Y15.7838 S255 G01 X15.2204 Y25.2874 S255 ; this line fails to laser. M5 G00 X0.0000 Y0.0000 M05
Did you try 2.05 ?
No, update fails:
@morokolli see this thread about downgrading: https://forum.duet3d.com/topic/13401/cant-change-from-v3-0-to-v2-05-missing-file/9
@dc42 I'll rather stay at V3 codebase.
Reverting back to 2.05 requires re-setting too many things (endstops, laser control, etc..)
