Home all not working
@Corexy said in Home all not working:
I've also got a "homedelta.g" file in there. Can that be deleted?
Yes If you do not have a delta you can delete it.
Thanks guys,
All good and knocking out a reasonably tidy print if I say so myself. Bed leveling ran in the start of the print, can't tell if it set up a map or not.
One issue I'm having that is after using the e stop to cancel a print, I can't move my Z axis up and down. I have to switch off the machine and star it again to get operation.
What have I missed here? The Z axis worked before in any order of operation.
What have I missed here? The Z axis worked before in any order of operation.Axes cannot be moved until they have been homed, unless you either use G1 H2 movements or you use
M584M564 to allow axis movement before homing. Emergency stop sends M112 to do the stop followed by M999 to reset the controller. -
@dc42 said in Home all not working:
What have I missed here? The Z axis worked before in any order of operation.Axes cannot be moved until they have been homed, unless you either use G1 H2 movements or you use M584 to allow axis movement before homing. Emergency stop sends M112 to do the stop followed by M999 to reset the controller.
No worries David, thank you.
I do recall an M584 back on the old config.g somewhere, and as I'm the only one who uses this machine I'd like to remove the limitation. So where would I put the M584 command?
Now I'm retuning the heaters, which I haven't done for years or at all on this board.
What I'm worried about is that why the extruder (PT100/H1) and bed (thermistor/H0), both have the same "B0", meaning they are both operating by PWM? Shouldn't the bed be different (B1 or something) due to the thermistor? The M307 H1 settings are from my first hot end heater test, and I'll run it a second time once it's all cooled down. Haven't done the bed yet.
M143 S280 ; Set maximum extruder temperature to 280C
M143 H0 S140 ; Set maximum bed temperature to 140C
M305 P0 T100000 B4000 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
M305 P1 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
M307 H0 A144.9 C625.3 D1.0 B0
M307 H1 A895.8 C393.4 D6.1 V24.3 B0 -
M584
It's actually M564 to allow moving an axis before being homed or to allow an axis to move beyond the travel limit.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
You can place M564 H0 in config.g
B0 is fine for both bed and extruder. B1 would be bang bang and is not recommended.
Thanks very much, appreciated.
So just a "M564 H0" in general preferences, just after M83?
M83 ; ...but relative extruder movesI'm also getting another odd fault message come up:
"attempt to read a gcode unsigned array that is too long M84 P3 E0:1"
Any idea what that's all about?
Yes M564 H0 can go there.
Can you post your config.g as it currently is? It would seem you might have two lines superimposed to cause that M84 P3 error...
@Phaedrux said in Home all not working:
Sorry mate, been busy with work and haven't had time to turn the printer on.
config.g as it stands right now:
; Configuration file for Duet WiFi
; generated by RepRapFirmware Configuration Tool on Sat Oct 22 2016 18:28:19 GMT+1100 (AUS Eastern Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"Zortrax M200" ; Set machine name
M552 S1 ; Enable network and acquire dynamic address via DHCP; Drives
M584 X0 Y1 Z2 E3 ; Set drive mapping
M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
M92 X80 Y80 Z800 E122 ; Set steps per mm
M566 X1600 Y1600 Z12 E800 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z1200 E8000 ; Set maximum speeds (mm/min)
M201 X1200 Y1200 Z20 E1200 ; Set accelerations (mm/s^2)
M906 X1100 Y1100 Z800 E600 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Endstops
M574 Z0 S0 ; Define active low and unused microswitches
M574 X1 Y1 S1 ; Define active high microswitches
M208 X195 Y195 Z175 S0 ; Set axis maxima; Z-Probe
M558 P1 X0 Y0 Z1 H5 F600 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
G31 P500 X0 Y0 Z2.82 ; Set Z probe trigger value, offset and trigger height
M557 X20:180 Y20:180 S40; Heaters
M307 H1 A892.1 C396.5 D6.4 V24.3 B0; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 X0 Y0 ; Set tool 0 axis offsets
T0; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
When do you get that message? i.e. what do you do (if anything) that causes it to pop up? What do you get in the console if just send M84?
Also, what do you get if you send
M98 Pconfig.g
in the console? -
Hi All,
Sorry about the delayed response. I'm a farmer, and with Australia's drought at the moment hungry mouths are calling me away from my hobbies.
"attempt to read a gcode unsigned array that is too long M84 P3 E0:1" was occurring when I used the emergency stop. For some reason it's not doing it today...
M84 seemed to do nothing at all, other than to make all my axis's "unhomed".
M98 PCONFIG.G I got the following message:
Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 917C.
It's all working well enough, but on this last print I just did, the temps of the bed and extruder did not drop to my "layer2" temps, despite them definitely being in my S3D profile and having worked every time before.
That message was generated because E0:1 says you want to work on extruder drives 0 and 1, but in your M584 command in config.g you only define one extruder.
M84 by itself disables all stepper drivers. This has the side effect of marking axes as not homed.
That is a common problem. It means that your heater cartridge is over-powered for your extruder, assuming your printer has an ordinary FDM hot end with an aluminium heater block (which will melt at about 660C).
