short-to-ground reported by driver(s) 2 4 9
@Veti yeah, that's right.
@3dprintingnut said in short-to-ground reported by driver(s) 2 4 9:
I expect you'll need to disable SPI poling of those chips in the firmware. I don't know how to do this.
You can use M569 with parameter R-1 to disable monitoring of a driver.
When I had this error message it was a broken cable (one of the 4 cables to the stepper).
Having it on multiple steppers might be caused by another reason.
@dc42 it's fixed, thank you very much.
@dc42 another issue, it shows below warning as soon as turn on power, do you know why and how to fix it?
that is normal for e3d hotends with silicone socks.
what hotend do you have?
@Veti yeah, I use E3D V6 hotend with silicone sleeve, is there any way to close the warning?
@3dprintingnut
FYI, I've seen this error when the drivers don't have any power... (on Duex due to a blown fuse) -
It's simply telling you what you can expect from a runaway heater condition. It can be ignored but it cannot be suppressed.
