X Endstop not being recognized
@BearcatTD, is it a microswitch endstop, or some other type?
he is setting up his ender 3 with a duet wifi.
the ender 3 is using micro switches as endstops. -
@BearcatTD, please send M574 without parameters from the console and see what the response is. I want to check that the endstop configuration is as you specified in config.g.
If the configuration is correct and the hardware is working, it should read "stopped" when the LED is off and "not stopped" when the LED is on.
When I send the M574 command with the endstop triggered and untriggered I get the same response, " Endstop configuration: X; low end active high, Y; low end active high; Z; low end z probe.
When I trigger the endstop the led on the board goes out and comes back on when I release the endstop.
Thanks!
@BearcatTD said in X Endstop not being recognized:
Thanks!
If you unplug the X endstop connector from the Duet completely, does M119 show it as triggered or not triggered? If it shows it as not triggered, that suggests a hardware fault on the Duet.
Both triggered and untriggered shows the same response. Endstops -X:not stopped, Y: at min stop, Z not stopped, Z probe: not stopped.
Does it matter that the led on the board is responding when I engage the endstop?!
If I unplug the connector I get:
"Endstops - X: at min stop, Y: at min stop, Z:not stopped, Z probe not stopped"
did you swap x and y by accident?
(https://www.dropbox.com/s/urfze0jxykpspvo/IMG_3413.jpg?dl=0)
Black is the X endstop White is the Y
black is plugged into e0 endstop and white is plugged into x
Sweet Jesus. I'm so sorry for wasting everyone's time.
Pat
Pat
Problems like yours can be hard to diagnose over the internet because we sometimes make assumptions that the basics, like things plugged into the correct connector, have already been verified.
Glad to hear you got it sorted.
