Job status by filament usage
PS - one thing I noticed during testing is that if you turn the printer off in the middle of a print and then resurrect it, the print times are inaccurate. This is because the resurrection data doesn't include the amount of filament consumed, so it counts from zero again. I'll make a note to fix this.
@gnydick said in Job status by filament usage:
@dc42 sorry I've been away, @dc42 . The prusa slicer bug is what I'm referring to. The DWC shows nothing for filament usage.
When was that fixed?
Did you read what dc42 has written? Please post a sample g-code file with this problem and config.g. And maybe M122 response because I use Prusa Slicer too and don't have any problems with filament usage.
There is an entry for Prusa slicer in the version 2.03 section of the whatsnew file. Is that the one you mean?
Prusa slicer just starting to print skirt of model...…….
In Cura, all jobs have max layer of 25...…….
Firmware version?
Its a Duet Ethernet on version 2.02RTOS. Luckily I have a camera so I can guestimate myself.
@chas2706 said in Job status by filament usage:
Please try 2.04RC4.
Ok thanks I will try it out later and let you know.
"Recognise filament usage comment in Prusa slicer" was added in RRF 2.03.
If you're going to update, don't forget to check through the What's New document to see how changes to the firmware may effect your configuration. And back up your existing, working config, so you can revert to it if necessary.
Ok will do, thanks for that.
Just Updated to 2.04RC4 and everything looks good.
Many thanks. -
Many thanks.Thanks for the confirmation!
