Duet wifi lost web connection
I confirm the problems with the Wifi connection in 2.03RC1. In combination with HTTP + FTP, the connection was extremely unstable, it was impossible to transfer files over hundreds of bytes either via http or ftp.
Editing config.g to disable ftp caused it to self-delete when writing.
Recovered on sd card from backup.
In the only http mode, it became possible to record files, but the recording speed dropped 10 times.M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03RC1 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DGM-9T6BU-FG3S8-6J1DJ-3SD6P-1SKMF
Used output buffers: 3 of 24 (11 max)
Static ram: 25656
Dynamic ram: 94672 of which 28 recycled
Exception stack ram used: 492
Never used ram: 10224
Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3752) IDLE(ready,156)
Owned mutexes:
Last reset 05:55:41 ago, cause: software
Last software reset at 2019-05-12 13:42, reason: User, spinning module GCodes, available RAM 10128 bytes (slot 1)
Error status: 24
Free file entries: 8
SD card longest block write time: 403.7ms, max retries 0
MCU temperature: min 30.7, current 35.9, max 36.7
Supply voltage: min 0.5, current 24.2, max 24.5, under voltage events: 1, over voltage events: 0, power good: yes
Driver 0: ok, SG min/max 0/1023
Driver 1: ok, SG min/max 0/1023
Driver 2: standstill, SG min/max 0/93
Driver 3: standstill, SG min/max 0/1023
Driver 4: ok, SG min/max 0/1023
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Date/time: 2019-05-12 19:37:56
Slowest loop: 123.17ms; fastest: 0.06ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 58, FreeDm: 163, MinFreeDm: 106, MaxWait: 10107016ms
Bed compensation in use: none
=== DDARing ===
Scheduled moves: 238342, completed moves: 238317, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Heater 0 is on, I-accum = 0.0
Heater 2 is on, I-accum = 0.4
Segments left: 1
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is doing "G1 X94.042 Y115.929 E0.22561" in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 404.11ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address cc:50:e3:14:fc:fb
WiFi Vcc 3.30, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 19184
WiFi IP address 192.168.1.6
WiFi signal strength -66dBm, reconnections 0, sleep mode modem
Socket states: 0 2 0 0 0 0 0 0
- WiFi -
I get this all of the time. I just turn my printer a little and it fixes everything.
@dc42 now i'm returned to WiFi Server Version: 1.21 and IMHO problem solved ?
Printer have uptume Last reset 98:00:53 ago, cause: power up
And connection not lost all that time!May be wifiserver version 1.23 totally consumes memory then controller lost any connection, and freezes.
@avaradus said in Duet wifi lost web connection:
Unlikely. Please try switching between 1.21 and 1.23 enough to be certain that there is a correlation between the DuetWiFiServer version and the problem occurring.
If you connect a USB host and send M111 P14 S1 then you may get some useful WiFi diagnostic messages reported to USB.
@dc42 Yes unlikely. Now with wifi server 1.21 again connection lost =(
With M122 I see Used output buffers: 24 of 24 (24 max)
All connection DWC to DUET is canceled.
i try disable wifi with M522 S-1 but used buffers is not release.
Automatic release of buffers is broken and not work =( -
We have same problem with freezing duets in longer prints. Is this problem already solved ?
Thank, Supik (TriLAB)
below I am sending a diagnostic report from today's freezing
Recv: === Diagnostics === Recv: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03trilab7 running on Duet Ethernet 1.02 or later Recv: Board ID: 08DGM-917NK-F2MS4-7J1FD-3S86T-1ZTDD Recv: Used output buffers: 24 of 24 (24 max) Recv: === RTOS === Recv: Static ram: 25708 Recv: Dynamic ram: 93672 of which 312 recycled Recv: Exception stack ram used: 532 Recv: Never used ram: 10848 Recv: Tasks: NETWORK(ready,472) HEAT(blocked,1236) MAIN(running,372) IDLE(ready,160) Recv: Owned mutexes: Recv: === Platform === Recv: Last reset 13:34:00 ago, cause: software Recv: Last software reset at 2019-10-08 18:48, reason: User, spinning module GCodes, available RAM 11072 bytes (slot 3) Recv: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Recv: Error status: 4 Recv: Free file entries: 9 Recv: SD card 0 detected, interface speed: 20.0MBytes/sec Recv: SD card longest block write time: 0.0ms, max retries 0 Recv: MCU temperature: min 44.0, current 44.4, max 44.6 Recv: Supply voltage: min 23.0, current 23.5, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Recv: Driver 0: ok, SG min/max 0/171 Recv: Driver 1: ok, SG min/max 26/153 Recv: Driver 2: ok, SG min/max 0/168 Recv: Driver 3: ok, SG min/max 0/1023 Recv: Driver 4: standstill, SG min/max not available Recv: Date/time: 2019-10-09 08:23:40 Recv: Cache data hit count 4294967295 Recv: Slowest loop: 1.96ms; fastest: 0.07ms Recv: I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 Recv: === Move === Recv: Hiccups: 0, FreeDm: 141, MinFreeDm: 89, MaxWait: 0ms Recv: Bed compensation in use: mesh, comp offset 0.000 Recv: === DDARing === Recv: Scheduled moves: 1699629, completed moves: 1699589, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 Recv: === Heat === Recv: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Recv: Heater 0 is on, I-accum = 0.2 Recv: Heater 1 is on, I-accum = 0.7 Recv: === GCodes === Recv: Segments left: 1 Recv: Stack records: 2 allocated, 0 in use Recv: Movement lock held by null Recv: http is idle in state(s) 0 Recv: telnet is idle in state(s) 0 Recv: file is doing "G1 X-16.905 Y-13.359 E0.01805 F1249.6" in state(s) 0 Recv: serial is idle in state(s) 0 Recv: aux is idle in state(s) 0 Recv: daemon is idle in state(s) 0 Recv: queue is idle in state(s) 0 Recv: autopause is idle in state(s) 0 Recv: Code queue is not empty: Recv: Queued 'M106 S153' for move 1699600 Recv: Queued 'M106 S184' for move 1699601 Recv: 2 of 16 codes have been queued. Recv: === Network === Recv: Slowest loop: 1.05ms; fastest: 0.02ms Recv: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) Recv: HTTP sessions: 0 of 8 Recv: Interface state 5, link 100Mbps full duplex
I couldn't figure out where the memory leak occurred. I tried to make a temporary fix - automatic reset when the buffer overflow.
Can you test this firmware ? (Based on version 2.04RC3)
https://github.com/mat100/RepRapFirmware/releases/tag/2.04RC3-fix-freeze
Matej
@mat100 Automatic reset (reboot) printer ?
This post is deleted! -
I now get the same error during homing on RRF 3.0beta12.. DO you know the reason for that?
same problem here exactly as above.., web interface hangs,
@tracar said in Duet wifi lost web connection:
This thread is very old and discusses very old firmware. I suggest you start a new thread with your issue. Are you running up to date firmware?
