Duet 3 Mainboard 6HC - initial production run.
Will there be a variant that does not use a raspberry?
@Cata said in Duet 3 Mainboard 6HC - initial production run.:
The current 6HC board has an SD card slot and an ethernet port that allows you to use it in standalone mode.
@gtj0 Thanks, i re-read again the wiki and its fine for my use.
No worries. There was some talk about the boards not having the SD card holder or the ethernet jack populated at first so there was a little confusion.
For info, I've been running mine in "stand alone" mode without the RPi.
@T3P3Tony From the wiring diagram and from my testing it looks like the "reset" pin on the Duet3 has a pull-up resistor and is expecting to be pulled to ground for a reset. Can the pin be driven directly by an SBC GPIO? I.E. If I configure a GPIO as a simple active-low pin will the Duet3 be OK with 3.3v from the SBC also keeping it high?
@gtj0 yes that should work fine but i have not tested.
As the SBC and Duet will be powered from different 3.3V supplies, I recommend you use a resistor in series with the connection from the SBC. AFAIR the pullup on the Duet is 10K, so a 470R resistor should do.
@dc42 Good point, thanks.
Another power question: Should the "SBC -> 5V" power option be working? With only that jumper installed, the Duet3 won't power up using 5V on pins 2 and 4 of the 26 pin connector. I've verified that the voltage is there and if i connect pins 4 and 6 on the SBC to the 5V and GND pins on the ATX header things work fine (with no jumpers).
this is what tony
saidtold me earlier: (not sure if changed since)you need both fitted this is the schematic. Its actually that the protection is between the 5V_INT and 5V_EXT circuits, the 5V_EXT to the 5V_SBC is just a jumper that connects those two rails. What really should happen is the "SBC->5V*" jumper is fitted and the 5V_EN jumper is removed...
@bearer Ah thanks. I must have missed that.
Any news on the ToolBoard?
Would love to test it with my new printer and Hemera -
@Selecta_Mota I expect we will announce the production pre order before Christmas for shipping either end of Jan or beginning of Feb.
@T3P3Tony and now I'm going to have to order one of those too
@T3P3Tony great to hear, thank you
@T3P3Tony So Duet 3 is out. when is the expansion board coming out for the external stepper drivers? As I understand 3HC board still doesn't support external stepper drivers and/or servos.
It sounds a bit one step forward two steps back with a loss of the external stepper driver support. -
@Aurimas said in Duet 3 Mainboard 6HC - initial production run.:
It sounds a bit one step forward two steps back with a loss of the external stepper driver support.A somewhat uniformed post that makes no real sense if you look at and understand the road map of what the duet team is preparing they have already given info on when the expansion boards will be available. (pre order is open)
@CaLviNx I think the key words in @Aurimas post were "external stepper drivers".
We finalised the tool board design and ordered the PCBs last Friday. We're now working on the single-external-stepper board, which is very simple because it is essentially a cut-down tool board. We are aiming to order the PCBs for them in time to get them before Chinese new year (25 January). We have already tested prototypes made from hacked prototype tool boards.
