bltouch
@tdybare69 said in bltouch:
M558 P7
This should be M558 P9 for the BLTouch.
I suggest you do some reading:
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe -
@Phaedrux i was wondering if the deploy,and retract files look right.
; deployprobe.g ; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v2.0.4 on Wed Sep 18 2019 22:41:11 GMT-0400 (Eastern Daylight Time)
M280 P5 S10 :deploy bltouch; retractprobe.g
; called to retract a physical Z probe
M280 P5 S90 :retract bltouch -
Do they work? Are you using heater pin 5? You may need to invert the command with
I1
@Phaedrux i believe it is pin 7 or 8. heater 3 i hooked it up according to pic on website. but cant find wiring diagram.
@tdybare69 i get a m280 error no matter if i set it to 5,7, or 9 like everybody is recommending. really need help.
Did you read any of the links I posted?
https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
You'll need to know what pin you're connecting to. You'll need to follow the directions to unbind that heater pin to make it available as a servo pin. And you'll need to format your deploy and retract commands to use the right pin you've chosen.
@Phaedrux thanks for that i have it on pin 8 like in the pic, wich is heater3.
@tdybare69 i really do appreciate you taking the time to help me
Well if you are using heater three then you need a command M307 H3 A-1 C-1 D-1 to enable use of PWM on pin 8 of the expansion connector - assuming you are correct that pin 8 is heater 3.
And in your M280 commands you also specify heater 3 use M288 P3 ### where ### is the servo position value needed by the BLTouch.
For example M280 P3 160 will clear a BLTouch alarm condition.
I put all the needed commands for configuring a Z-probe using a BLTouch in a file named configprobe.g. Then I call this file where needed.
This is what is in that file - I am using heater 7:
M307 H7 A-1 C-1 D-1 ; disable heater 7 to enable PWM5 - PWM signal still appears on E6 connector on Duex5
M558 P9 H5 F300 T6000 A5 S0.01 R0.2 ; set probe configuration - step 1
G31 X-44 Y0 Z1.350 P25 ; set probe configuration - step 2
M280 P7 S160 ; clear BLTouch alarm (if any)Frederick
@tdybare69 I reloaded dc42 frmware version DuetFirmware 2.03, then went into reprap configtool. while in there when i got to the endstop section before i clicked bltouch. i checked the box for deploy/retract option. then finished config. uploaded it here is my config
; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Sep 21 2019 00:16:41 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Turnigy X5S" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z400.00 E97.00 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; set active low and disabled endstops; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-70 Y-30 Z2.5 ; set Z probe trigger value, offset and trigger height
M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
then i went into the deploy.g file
; deployprobe.g
; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Sep 21 2019 00:16:42 GMT-0400 (Eastern Daylight Time)
M280 P3 S10 I1and the retract.g
; retractprobe.g
M280 P3 S90 I1
now i just have to calibrate.
thanks for all the help. -
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1side note B4138 is the default and is most likely wrong for your thermistors.
