PanelDue cant update
@oliof aahh good point, @TPJensen did you follow there steps pf the guide you linked to:
Press and hold the Erase button of the PanelDue for at least one second. You can access this button by pressing the end of a straightened-out paper clip through the hole in the enclosure.
Release the Erase button, then press and release the Reset button. If you have a version 2.0 board then the backlight will turn off.
Identify the COM port number or port name of the PanelDue board on your PC. If you use Windows, you can do this via Start->Control Panel->System->Device Manager. Expand Ports (COM and LPT), and look for Bossa port. Make a note of the port number. If you can’t find the port, try repeating the Erase and Reset sequence, or disconnecting and reconnecting the USB cable, or try a different USB port on your computer. Note: the port number of the Bossa port for PanelDue will not be the same as the one you use when uploading firmware to Duet electronics.
Okay thanks to your all, I will try to erase the firmware tommorow when I have more time.
I hope it will go smooth.It is a weird way paneldue have to update.
okay now it find it as com5
But cant get the program to update to paneldue
here is what I do and what comes upC:\Users\jense>C:\Program Files (x86)\BOSSA\bossac.exe" --port=COM5 -e -w -v -b D:\PanelDue-v2-7.0C.bin
'C:\Program' is not recognized as an internal or external command,
operable program or batch file. -
@TPJensen said in PanelDue cant update:
wrong use of "
try
"C:\Program Files (x86)\BOSSA\bossac.exe" --port=COM5 -e -w -v -b D:\PanelDue-v2-7.0C.bin
The single quote mark " is messing up the command. It's probably easiest to cd (change directory) to the folder that contains bossac, then you don't have to worry so much about getting the path right.
cd "C:\Program Files (x86)\BOSSA\"
Then run it from there with
bossac.exe --port=COM5 -e -w -v -b D:\PanelDue-v2-7.0C.bin
@bearer beat me to it! -
@bearer @droftarts
Thank you that worked
can I on the paneldue set TEMP with onscreen keybord or macros ?
or is the only thing to do is use
-5 -1 SET +1+5 ?
@TPJensen You can set temps using macros or the onscreen keyboard if you wish.
@Phaedrux said in PanelDue cant update:
How fo I get it to use the onscreen keyboard for TEMP ? I only get -5 -1 SET +1+5 if I choose the temp
you don't get a keyboard for the temp, you get a console for generic g-code.
If you hold your fingernail on the +5 it will auto-repeat, allowing you to go from 0 to printing temperature quite quickly.
@dc42 said in PanelDue cant update:
Super that works.. Thank you
If your intention is to do a preheat or something you could create a macro with the temp command and name it 0_Preheat and it should show up in the control screen in the quick macro list.
Nice Thanks again now preheat is setup
