Trobuble after firmware 2.03 (2019-06-13b2)
Hi
I have some problems after firmware update...After some time printing hotend shutdown but it continue like it still working.
I cant see what is wrong, old firmware just printet fine and my Fan1 dont turn on. On the old firmware I used the slider to turn it on but no slider on the new firmware.
Do you have logging enabled (M929)? If so, check the log for a heater fault.
@dc42 said in Trobuble after firmware 2.03 (2019-06-13b2):
Where do I put the M929 P"eventlog.txt" S1 and M929 S0 ; stop logging ?
In config.g ?
Can you post your config.g please?
@phaedrux said in Trobuble after firmware 2.03 (2019-06-13b2):
; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time); General preferences
M83 ; ...but relative extruder moves; Delta Settings
M665 L440.000 R227 H456.0 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them; Network
M552 S1
M550 P"Anycubic Predator" ; Set machine name
M551 P"" ; Set password
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P3 S0 ; Drive 3 goes forwards
M92 X80.00 Y80.00 Z80.00 E380.45 ; Set steps per mm
M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2)
M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Retraction
M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction; Axis Limits
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops; Z-Probe
M558 P4 H3 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z16.0 ; Set Z probe trigger value, offset and trigger height
M557 R115 S20 ; Define mesh grid
G29 S1 ; Load the heightmap; Heaters
M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S250 ; Set temperature limit for heater 1 to 240C; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
M572 D0 S0.1 ; Pressure Advance
;M591 D0 P2 C4 S1 ; Activate filament sensor
M404 N1.75 ; Set for print monitor
M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0; Miscellaneous
M501 ; Load saved parameters from non-volatile memory -
It looks like you do not have a T0 command at the end of your config.g. You would need to have one in the slicer start gcode or at the end of config.g (or both) to ensure that a tool is selected/enabled before a print is started.
From your screen shot though, it looks like the tool was heated, so there must be a T0 in your slicer code, or you manually enabled it. In which case, there may be a heater fault causing the heater to turn off. Do you see any heater fault error messages in the gcode console?
Have you done a PID tune on your heater? Are you sure you have the correct thermistor values for your thermistor?
As an aside, you may want to use Firmware version 2.04RC1 due to some bug fixes for delta printers.
Yes I-am sure it works because with the old firmware I did alot of prints with no problems.
here is my start g-code from my slicer there is T0
M104 S[extruder0_temperature] T0 ; heat nozzle
M190 S[bed0_temperature] T0 ; heat bed and wait
M109 S[extruder0_temperature] T0 ; wait for nozzle
G28 ; home all
G1 X-50 Y-180.0 Z5 F4000.0 ; go to the outer front edge
G1 Z0.3 ; lower nozzle to purge height
G92 E0 ; reset the extruder
G1 X0.0 E9.0 F1000.0 ; purge nozzle
G1 X50.0 E12.5 F1000.0 ; purge nozzle
G92 E0 ; reset the extruder -
@tpjensen
T0 has to be its own command. not part of the M104 or M190 or M109 -
@veti said in Trobuble after firmware 2.03 (2019-06-13b2):
@tpjensen
T0 has to be its own command. not part of the M104 or M190 or M109Okay I did not know that...
Okay can you maybe help my and rewrite my start gcode so it works ?
And maybe if I have to put in the config.g file where and what to write -
put this at the end of your config.g
T0 ; select first tool -
hehe okay it that all ??
You can add a T0 to the start of your slicer gcode as well to catch the cases where the tool may have been disabled at some point between power on and starting a print.
yes it is.
see
https://duet3d.dozuki.com/Wiki/Gcode#Section_T_Select_Tool -
Okay that was easy then
