Firmware 2.04RC1 available
I'm running 1.22.6
At this point, can this version of the firmware considered stable?
@garyd9 2.03
2.04RC1 is stable, however there are a couple of 2.03 bug reports that I want to investigate before I do the 2.04 release. Unfortunately there is a tight deadline to meet for the Duet 3 firmware development, so it may be a while before I get back to 2.04.
@dc42 said in Firmware 2.04RC1 available:
Oh, I completely understand about deadlines and RRF/Duet3. (In fact, I'd be on the duet3 first-run list if I wasn't extremely tight on money these days.)
I really just needed to confirm that this RC is (at the moment) the best stable choice for a delta printer.
Thank you
Gary -
@garyd9 I have been using this 2.04RC1 version on my delta since it came out with no issue's at all, go for it!.
Same here. I use it on both my deltas
Thanks - it seems to be working fine for me (so far*.)
* Typically, if I say something is working, it breaks immediately afterwards. Hopefully, by qualifying the statement with "so far", things will stay working.
I had definite problems with it, I’m totally willing to re-upgrade. If DWC stops being able to connect to the firmware again, can I still run M122 in a terminal connected via usb?
Those with Deltas that haven’t any problems with it, what DWC are you running?
DWC 2.0.0-RC7
@jay_s_uk said in Firmware 2.04RC1 available:
DWC 2.0.0-RC7
@boldnuts said in Firmware 2.04RC1 available:
DWC 2.0.0-RC7
I just re-updated to 2.04RC1 and this time I updated to DWC 2.0.0-RC7, seems like I'm not having the issue with the higher than normal first layer this time. Wierd, autocalibration calibrated to the deviation I expected, but it seems to be normal now.
Seems fine like last time but we'll see after I power it off and back on in a couple of days.
