Firmware 2.04RC1 available
I don't have an expansion board, just the plain Duet Ethernet board.
Which version of DWC do you use? If you were using an old one, that might explain the connection issues.
I'm running 1.22.6
At this point, can this version of the firmware considered stable?
@garyd9 2.03
2.04RC1 is stable, however there are a couple of 2.03 bug reports that I want to investigate before I do the 2.04 release. Unfortunately there is a tight deadline to meet for the Duet 3 firmware development, so it may be a while before I get back to 2.04.
@dc42 said in Firmware 2.04RC1 available:
Oh, I completely understand about deadlines and RRF/Duet3. (In fact, I'd be on the duet3 first-run list if I wasn't extremely tight on money these days.)
I really just needed to confirm that this RC is (at the moment) the best stable choice for a delta printer.
Thank you
Gary -
@garyd9 I have been using this 2.04RC1 version on my delta since it came out with no issue's at all, go for it!.
Same here. I use it on both my deltas
Thanks - it seems to be working fine for me (so far*.)
* Typically, if I say something is working, it breaks immediately afterwards. Hopefully, by qualifying the statement with "so far", things will stay working.
I had definite problems with it, I’m totally willing to re-upgrade. If DWC stops being able to connect to the firmware again, can I still run M122 in a terminal connected via usb?
Those with Deltas that haven’t any problems with it, what DWC are you running?
DWC 2.0.0-RC7
@jay_s_uk said in Firmware 2.04RC1 available:
DWC 2.0.0-RC7
@boldnuts said in Firmware 2.04RC1 available:
DWC 2.0.0-RC7
I just re-updated to 2.04RC1 and this time I updated to DWC 2.0.0-RC7, seems like I'm not having the issue with the higher than normal first layer this time. Wierd, autocalibration calibrated to the deviation I expected, but it seems to be normal now.
Seems fine like last time but we'll see after I power it off and back on in a couple of days.
