Unable to connect to DWC after startup
Ok so it works again and i have updated to Wifiserver 1.23
I just checked with the router and this is what i got.It says it is connected, but it is no witchcraft since the DWC works also at the moment.
If i get another disconnect, i will check back if it says the same address, correct? -
It looks like it says dynamic rather than static. You may be able to tell the router to assign the same IP address every time.
Ok so i´ve just had a disconnect, just around the time i was looking around in the router system.
I checked in the router, and the 192.168.0.199 , so my printer, was still marked as connected.
That disconnect settled itself after a restart though.
So i tried switching off the duet, and check if it said it was still connected, which it did. It did not disapper for about 5-10 minutes after i had shut the duet down. When i restarted the duet, it was right back there. -
Next time it disconnects, check the IP address again in the router or on PanelDue (by sending M552), then see if you can ping that IP address from your PC.
Ok so i wasn´t printing for some time, but i started it back up again now. DWC does not work.
So i checked the M552 and it says it is connected to the usual (197.168.0.199) address.
I check the router and it does say that it is connected.
I tried to ping it and this is what came out
Now it works again
Have you tried setting your router to use a different WiFi channel? I recently encountered a situation in which a laptop used to connect reliably to a Duet WiFi running in AP mode; but when the pair were moved to the hall at 3D Meetup Sweden, it kept disconnecting. A wifi scan showed that the entire wifi spectrum was congested. Changing the WiFi channel resolved the problem (AFAIR we changed it from channel 6 to channel 2, but channel 1 might have been better).
Ok so this hasn´t happened for quite a while now, but now here it is again.
Resetting and restarting the router has no effect.
This time the Duet also says that it is not connected to the wifi (it doesnt really say that, it just does not say anything about wifi being connected)
I can´t set the router to use a specific channel, and it doesnt show me which channel it is using.
All i can do is set what frequency i want.
What should i set?
@dc42 said in Unable to connect to DWC after startup:
I tried filling the three "favorite" boxes with any of the corresponding Wifi channels frequencies but no luck. This is now going on for two days, longer than it ever has.
What else could i do? -
Ok so this seems permanent now. 20 days later and i still can´t connect anymore.
Any idea? -
As an exercise to test the functioning of the wifi module, can you try setting it up in access point mode where the duet creates its own wifi network that you connect to.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface
M552 S2 and M587 to set the IP of the access point
Ok so i tried this. I first set
M552 S-1 to disable
M552 S2 to configure access pointThen i tried the M587 command but it didn´t let me ("Failed to add SSID to remembered list") so i checked with M552 and it says that the wifi module is being started, and that doesn´t change.
What does that mean? -
@nitrofreak said in Unable to connect to DWC after startup:
M552 S-1 to disable
Instead of S-1, try S0 instead.
Then I think you need to configure M587 with SSID for the duet, and IP address first, then enable access point mode with M552 S2
It's been a while since I've put it into access point mode.
@phaedrux said in Unable to connect to DWC after startup:
Doesnt work, I´ve tried every combination, if i do
M552 S0
M552 S2
it says i have to stop the running wifi mode before selecting the new mode.
If i do the M587 while either S-1 S0 or S2 is active, it gives me
"Failed to add SSID to remembered list" -
Ok so this is annoying the heck out of me, especially since after the 2.03 update i had / have to redo my toolchange tpre/tpost/tfree gcodes for dual extrusion. (yes i read the release notes) I have a new problem that it is now doing an additional Y offset each time it is doing the coordinate offsets, as well as a Z offset where it moves the bed up when changing from t1 to t0, but then does not move it back down when switching from t0 to t1. This moves the bed up by the specified offset each time it is doing two toolchanges, until it crashes into the nozzle. But i should put that into a different thread.
The point is i can not change the config files when troubleshooting.i have also done another firmware (re) update. I can connect over YAT, but when i want to M997 S1 it gets me this:
M122<CR>
Trying to connect at 230400 baud: failed
Trying to connect at 115200 baud: failed
Trying to connect at 74880 baud: failed
Trying to connect at 9600 baud: failed
Error: Installation failed due to comm write error
ok
WiFi module is disabled
ok
ok
ok
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F23T0-6J9DJ-3S86S-TWBWD
Used output buffers: 1 of 24 (6 max)
Static ram: 25680
Dynamic ram: 93952 of which 0 recycled
Exception stack ram used: 320
Never used ram: 11120
Tasks: NETWORK(ready,1360) HEAT(blocked,1172) MAIN(running,3756) IDLE(ready,160)
Owned mutexes:
Last reset 00:06:57 ago, cause: software
Last software reset at 2019-07-31 01:38, reason: User, spinning module GCodes, available RAM 11084 bytes (slot 2)
Error status: 0
Free file entries: 10
MCU temperature: min 36.9, current 37.3, max 37.7
Supply voltage: min 24.5, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Cache data hit count 1069836646
Slowest loop: 3.08ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== DDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M997 S1M552 M552 M552 M552 M122M122M122M122M122M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1001.22ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is disabled
ok
I have done some research and usually this problem resolves when updating the DuetWifiServer.bin file to the matching one with the firmware. I have also paid attention to install the firmwares while VIN is applied.
@dc42 recommended to replace the board in this thread.
https://forum.duet3d.com/topic/8541/duet-wifi-always-starting-and-will-not-connect-to-wifi/19It is weird because it worked in the beginning, also after the 2.03 update it worked for some time flawlessly.
If i replace the board, can i only do it with the resellers that i bought it from? I bought it from e3d, but i live in germany so it is sort of stupid.
I also dont know if the sporadic inability to connect to DWC has anything to do with this, or not. But still.
Is there anything else i can try?
The firmware is 100% updated, all the files are, the second to last update before my attempt now was even through DWC.It´s really frustrating but i don´t want to chuck that board because i spent already 350€ between the board, 7i panel, breakout and pt100 board.
Any help greatly appreciated.
Thanks
Max - WiFi -
@dc42 are you ignoring me?
It would be great to know what to do, if the board is broken so that i can send it back to be up and running again in a timely manner.
Also with the scan, you said to switch from channel 6 to channel 2/1. However those are not Mhz specific and my Channel ID and Channel # are different. Check my Post from 31 July please
M552 S-1 to disable
To set up access point mode:
- M552 S0 to go into idle mode, if client mode isn't working
- Set up access point parameters using M569
- M552 S2 to start access point mode
The comm write error when you try to install the WiFi firmware suggests that the board (probably the wifi module) is faulty. If the error persists, pease ask your supplier to replace the board.
Regarding WiFi channels and your post of 31 July, the configuration pages you posted were for the cable model part of the router configuration. There should be a separate page for the WiFi part.
Hi @dc42 , thanks for the reply.
Are you sure about M569? This is the Set motor driver direction, enable polarity and step pulse timing M-code.
Ok i seemed to miss that part.
Is it this page? It was already auto set at 1 ( or should i uncheck that box and manually select 1?)Thank you
Max -
I have been printing some dual extrusion tests today, and always had to restart because mounting the SD card. I didnt expect this, but the wifi module just randomly started working again after i restarted the machine.
It gave me the popup that it was connected to the access point, and voilà, even DWC shows up.This is so weird.
Here is the M122 report directly from DWC after it started up and connected, can you spot anything?
M122
Used output buffers: 3 of 24 (9 max)
Static ram: 25680
Dynamic ram: 93996 of which 0 recycled
Exception stack ram used: 312
Never used ram: 11084
Tasks: NETWORK(ready,652) HEAT(blocked,1172) MAIN(running,3820) IDLE(ready,160)
Owned mutexes:
Last reset 00:02:07 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11052 bytes (slot 3)
Error status: 0
MCU temperature: min 39.7, current 40.7, max 41.3
Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2019-08-26 20:27:01
Cache data hit count 495289833
Slowest loop: 9.56ms; fastest: 0.07ms
=== DDARing ===
Heater 0 is on, I-accum = 0.3
Heater 1 is on, I-accum = 0.4
Segments left: 0
serial is idle in state(s) 0
=== Network ===
Slowest loop: 15.47ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address b4:e6:2d:52:f6:45
WiFi Vcc 3.35, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24904
WiFi IP address 192.168.0.93
WiFi signal strength -57dBm, reconnections 0, sleep mode modem
@dc42 what could cause this random behaviour?
Any explanation at all? - WiFi -
