Pay for config / json files for my corexy printer build.
@phaedrux thank you very much like that
@stevo said in Pay for config / json files for my corexy printer build.:
; generated by RepRapFirmware Configuration Tool v2 on Wed Jun 26 2019 19:39:28 GMT+0100 (BST)
G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
G1 R1 X0 Y0 ; go back to the last print move
M83 ; relative extruder moves
G1 E10 F3600 ; extrude 10mm of filamentMore of a question than a suggestion....
Theway I read the above is that 10mm of filament will be deposited on top of the last print position. Shouldn't the extrude filament command be first...as a priming step....then move the extruder to the last position to start printing again?
This is a really helpful thread...thanks! -
Evening,
I have done the final wire up and fitted the BLTouch and both X and Y limits.
Been editing the files to get me to where I am as follows,
When I turn on the printer the BL touch deploys and retracts twice and then lights up red self test ?
I can then hit the home all and the y axis will home firstly then followed by the x axis homing after this has completed the print head moves to the centre of the printbed which then starts to rise but the probe does nothing in regards to the homing of the z axis.I realise I have not put the offsets in for the BLTouch just wanted to get an understanding of how the z homing should work.
Have wired BLTouch as per be true 3d link
Would appreciate a pointer please.
; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 23 2019 21:10:42 GMT+0100 (BST); General preferences
M83 ; ...but relative extruder movesM669 K1 ; Select CoreXY mode
M550 P"WILE E COYOTE" ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S1 ; Physical drive 0 goes forwards
M569 P1 S1 ; Physical drive 1 goes forwards
M569 P2 S0 ; Physical drive 2 goes backwards
M569 P3 S1 ; Physical drive 3 goes forwards
M92 X80.00 Y80.00 Z1600.00 E420.00 ; Set steps per mm
M566 X900.00 Y900.00 Z30.00 E2400 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z144.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
M906 X800.00 Y800.00 Z2000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X-220 Y-220 Z0 S1 ; Set axis minima
M208 X220 Y220 Z660 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active low and disabled endstops
M574 Z1 S2 ; Define Z to use Probe. Home to Min.
M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. Not using on XY, but using it on Z.
G31 P25 X0 Y-25.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
G31 X0 Y0 Z0 P25 ; Set Z probe trigger value, offset and trigger height
M557 X220:220 Y-220:220 S20 ; Define mesh grid; BLTouch - Heaters
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.; Heaters
M140 H-1 ; Disable heated bed
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 C ; Part cooling fan
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
T0 ; Select first tool; homeall.g
; called to home all axes
G91 ; relative positioning
G1 Z15 F6000 S2 ; lift Z relative to current position
G1 S1 Y-445 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 S1 Y-445 F360 ; move slowly to Y axis endstop once more (second pass)
G1 S1 X-445 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 S1 X-445 F360 ; move slowly to X axis endstop once more (second pass)
G90 ; absolute positioning
G1 X0 Y0 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z15 F100 ; lift Z relative to current position
;G90 ; absolute positioning; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 23 2019 21:10:42 GMT+0100 (BST)G30 ; Do a single probe to home our Z axis
G90 ; Make sure we are in absolute mode
G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.; Uncomment the following lines to lift Z after probing
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 Z-15 F6000 S2 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G90 ; absolute positioning; deployprobe.g
; called to deploy a physical Z probe
M280 P3 S10 I1; retractprobe.g
; called to retract a physical Z probe
M280 P3 S90 I1 -
; BLTouch - Heaters
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.You've got a few commands duplicated there. You should probably clean those up to prevent future confusion.
G30 ; home Z by probing the bedIt would seem you are using 0,0 as bed center? Just checking.
; homez.g
G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.You may want to add a G1 X Y move before the G30 to place the probe in the same location as you do in homeall for consistency, unless you have different plans for using homez alone in certain situations. That's valid, but just be aware that G28 and G28 Z will give you very different results.
; BLTouch - Heaters
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.@stevo said in Pay for config / json files for my corexy printer build.:
; deployprobe.g
M280 P3 S10 I1You're unbinding heater pin 7, but then you're targeting servo 3 in your deploy and retract commands. I think this is the reason the probe isn't doing anything. If you are actually using pin 7, then change the servo commands to be P7 instead of P3.
Did you test the deploy and retract macros? What happens if you send M401 and M402? (should be deploy and retract)
Use this procedure for safely testing your probe. https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
@phaedrux Thank you for the help as always much appreciated!
Will report back once I have sorted my mess out lol.
Evening all,
Now have signs of life from the BL touch on hitting the home button the bed lowers 15mm the y axis then homes followed by the x axis homing and then the printhead moves to the middle of the machine and deploys the probe and upon touching the bed and retracting the table lowers 15mm again.
Its a little hit and miss as sometimes when I turn the machine on the bl will just flash red and will not deploy at the z axis homing stage.
If I actually deploy the prove manually after one of these instances but prior to powering the machine on everything seems to be ok ?; Configuration file for Duet WiFi (firmware version 1.21)
G31 P25 X0 Y-25.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment; Z-Probe
M558 P9 H15 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P500 X32 Y2 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X220:220 Y-220:220 S20 ; Define mesh grid; Heaters
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
G1 X0 Y0 F6000 ; go to first probe point
;G90 ; absolute positioning -
Some people add a command to reset the BLTouch out of an error state, before using it for probing. You can add this command in homez.g and homeall.g (before the G30 command), and if you wish in bed.g. It's an M280 command but I forget the details. You may need a short G4 delay command after it, to make sure that the reset happens before the firmware tries to deploy the probe.
Try adding this to the end of your config.g to clear any BLTouch errors and retract the pin just in case.
; BLTOUCH PREP ; G4 S1 M280 P7 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed G4 S1 M402 ; Retract probe just in case it's down
G31 P25 X0 Y-25.3 Z0.0 ;You've still got some probe settings duplicated in the endstops and zprobe section.
Thank you that's done the trick !
Evening all,
Just wanted to ask when the printer has finished its task how / where do I ask it to lower the bed and come back to the homing corner minima on x and y to cool print head down bearing in mind my origin is the centre of the build plate.
M104 S0 ;Turn off extruder heater
G91 ;Relative positioning
G1 Z 10 E-5 F300 ; Lower bed by 10mm and retract filament by 5mm
G1 S1 Y-150 X-150 F500 ;Move nozzle 150mm home direction out of the way of finished print.
M84 ;Motors off
G90 ;Absolute positioning -
Does this help? https://forum.duet3d.com/topic/6760/stop-g
@zapta thank you !
Evening all just wondered if one of you kind folk could cast an eye over my config file to see if it could be improved in any way please speeds and placement of codes within the file.
As always your comments greatly received
M550 P"CORE XY" ; Set machine name
M92 X80.00 Y80.00 Z1600.00 E415.00 ; Set steps per mm
G31 P25 X2 Y32 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment; BLTOUCH PREP
G4 S1
G4 S1
M402 ; Retract probe just in case it's down; Z-Probe
G31 P500 X32 Y2 Z0.96 ; Set Z probe trigger value, offset and trigger height
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; BLTOUCH PREP
G4 S1
G4 S1
M402 ; Retract probe just in case it's down; Automatic saving after power loss is not enabled
T0 ; Select first tool -
@stevo If I was being really pedantic I'd say that you have disabled thermostatic mode for your part cooling fan (M106 P0 H-1) which is fine, but the comment after says "Thermostatic control is turned on" (should say "off").
But I'm not feeling pedantic so I won't make that comment.
Seriously, nothing leaps out as being obviously amiss. I think you are at the stage of playing around with things to see if the end result looks any better or can be printed faster without degrading quality. One good thing about Duet is that you can play around with things "one the fly".
If you want, you can give your heaters and fans names for example such as "Hot end" rather than the default "heater 1" (M305 "S") or "Part fan" rather than "fan 0" (M106 "C").
You could try firmware retraction (G10 /G11). It won't work any better than your slicer but you can play around with it "on the fly" which is a far easier way to tune the retraction settings.
You could also play around with pressure advance (M572).
Thank you for the input always appreciated !
I have been tinkering with the driver speed settings in the config file only would this have any effect on the bltouch operation as when the x and y axis has homed and the head moves to the centre the bed raises a little before the bltouch has lowered the pin then changes its mind and lowers the bed.
The bltouch then flashes red -
You can add a bit of a pause delay to the probe movements with M558 R0.5. This gives the BLTouch a half second chance to settle before starting to probe.
Afternoon everyone,
I wonder if I could seek some clarification please Part cooling fan and hot end fan operate as they should during the print apart from the part cooling fan not turning off when the print has finished which I'm guessing I need to add a line to my S3D end code this is what I have in the config g file .; Fans
M106 P0 S0 I0 F500 H-1 ; Part cooling fan
M106 P1 S1 I0 F500 H1 T35 ; Hot end fan set to come on and off at 35and S3D end code.
M104 S0 ; extruder heater off
G1 E-1 F300 ; retract the filament
G1 Z15 F1000 S2 ; lift Z relative to current position
G1 Y5 F1000 ; go back a few mm
G1 X5 F1000 ; go back a few mm
M84 ;steppers off
G90 ;absolute positioning -
@stevo Add "M106 S0" to your end gcode.
Thank you
