Firmware 2.03beta2 available
@dc42 said in Firmware 2.03beta2 available:
Beta 3 is available now.
In agreement. I'll try it this weekend.
Thank you -
It is already tested and in beta 3 it works correctly again.
Thanks and best regards
When running G29 now the printer is using the nozzle reference and my z probe is out of the bed area. But when showing the map it thinks it was the probe at the nozzle position.
@brunofporto said in Firmware 2.03beta2 available:
The only change should be that if you run G29 within a system macro file (for example, bed.g) then tool offsets will be applied., whereas in firmware 2.02 they are not. But Z probe offsets are always applied by G29. Are you using tool offsets?
@dc42 Not using any tool offsets. The only offset is the z-probe defined at the z-probe configuration line.
Pretty sure it is putting the nozzle exactly where it should be the probe when I send a G29 - needed to change some parameters to make sure the probe is over the bed but the height map shows as the nozzle position is where the probe took the measurement.
@dc42 ps.: just realized that I post at the wrong thread! I am using the beta3!
