Duet WiFi always starting and will not connect to WiFi
@tetele, I suggest you first send M997 S1 from USB or PanelDue to reinstall the WiFi firmware. That usually fixes this type of issue. The WiFi firmware file should already be on your SD card. If you need a fresh copy, you can find it here https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWiFiServer.bin.
@dc42 worked like a charm. Thanks!
