Solved: Setting Z offset for T1
Ok now the bed is moving down by the value I entered (50mm) Before T1 is activated but it goes back to 0.2mm (the layer height) after T1 is activated. It should go to 50.2mm after T1 is selected and stay there to print. (So now the Z offset is taken into account only during tool change).Thank you for your time, we are getting closer
; tfree1.g
; called when tool 1 is freed
G1 R2 Z-50
M98 P/macros/parkT1; tpre1.g
; called before tool 1 is selectedG1 R2 Z50
I gave up on this. So much time for nothing. Sometimes it works, sometimes it's not. even tho same commands are used and after rebooting and homing. And the most important is in config.g
The z offset doesn't work. (G10 P1 X0 Y0 Z0.85)I'll have to redesign the tool mounts to be adjustable mechanically instead or move back to Marlin..
I'll look into this when I get time. However, E3D uses Duets to control their tool changers and they haven't reported any similar problems.
I appreciate that!
Here's a short video I recorded for you so you can see what actually is happening and maybe it makes it easier to solve the problem.
I don't have any offset commands set anywhere else other than what you see in config.g.
https://www.youtube.com/watch?v=MuGbiBkKNUI -
@rajaakahel
Try this macro, and parts of what happens.G10 P0 S0 R0 G10 P1 S0 R0 G28 T0 G0 X100 Y100 Z50 G4 S5 M291 P"X100 Y100 Z50 with T0" S2 T0 T1 G4 S5 M291 P"T1 active" S2 T0 G0 X100 Y100 Z50 G4 S5 M291 P"X100 Y100 Z50 with T1" S2 T0 T-1
Just tested with mine,
You have to do 30 negative (just to test)
At positive 30 he wants to drive 29.8mm minus, but this would require the bed to be driven 29.8mm higher that does not make the Duet.
At T0 Z0 position, it is over -
@zerspaner_gerd Thank you, I will try with negative value and see if it works
@zerspaner_gerd
Thank you sir! That's it! in order to move the bed away from the nozzle, the value must be negative not positive!
M563 P0 D0 H1 ; Define tool 0
M563 P1 D1 H2 ; Define tool 1
G10 P1 X0 Y0 Z-30 ; Set tool 1 axis offsets
G10 P1 R0 S0 -
Just to be clear, the XYZ parameters in the G10 commands are the offsets of the tip of the nozzle relative to the head reference point. You can choose the head reference point to be wherever you like, but the G10 offsets, G31 offsets for the Z probe and M208 limits must all be specified in terms of the head reference point.
It's probably safest to choose the head reference point Z position to be the lowest nozzle you have (or slightly lower), so that the Z values in G10 commands for other tools are all positive.
