Please help us to test firmware 1.17RC3 and DWC 1.14
This was without starting g-code only after hitting tool button (setting it to active state) on DWC or PanelDue.
It's strange because once it worked wrong, then ok. I must have messed something then.I just tested it selecting a tool on PanelDue and I was able to move the print head around while it was heating up. Let me know if it happens again and you manage to reproduce it.
I have nothing in tool selection macros, but as we are here I have another question.
In KISSlicer (and others only we use K. extensively) there are custom g-codes for prefix, select new tool, cool and retire, postfix etc.
I understand the correct behaviour is not to use slicer custom g-codes for selecting/deselecting tools, only new macros tfree, tpre?
So in KISSlicer It would be only useful to make prefix (eg.T0, M116 P0, M140 S70) and postfix (eg. T-1, M140 S0) and don't use tool selection g-codes at all, just macros?You can use tool selection macros in KISSlicer if you wish, but IMO it makes more sense just to have it generate tool selection commands (T0, T1 etc.) and use the tool change macros that RepRapFirmware supports.
After a restart it works ok, I hit heater 1, it starts heating up, then home all and it homes while heating.
But when I pause and cancel printing a file and then after the cancel hit heater 1, it starts heating up and waits until it's ready.Said g-code starts with :
G21 G90 M83 T0 M116 P0
And I have no magic in pause gcode also, just move up and to the center and retract a bit.
As far as I remember there was no such behaviour in 1.16
Perhaps it would be best to update to your todays version and check.
