Blobs and under extrusion with S3D
I'd say you're good to go then. Print a benchy or some other actual model and see how things look for further tuning.
After playing with retraction and pressure advance everything looks good when its not moving between parts. When it is it comes out like this
https://drive.google.com/file/d/13OBB-CuOU5PKmGub2PCu8fpjo6xvNbqS/view?usp=sharingAny suggestions?
What is your travel speed in the slicer?
In your config.g do you have an M204 command to specify print acceleration and travel acceleration?200mm/s or more for travel moves is probably desirable and acceleration values 4000 to 6000mm/min. Greatly reduces the time available for strings to ooze out.
M204 P1000 T5000
