Firmware 1.16 released
@Russ:
also, when using the command "M307 H# A-1 C-1 D-1"
i get no feed back in the command line.
but if i just enter "M307 H#" after using "M307 H# A-1 C-1 D-1" then and only then do i get "Heater # is disabled"
just FYI
~Russ
That is as intended. Most commands generate no output when they succeed, and most commands report current values if you invoke them with no or minimal parameters.
I installed all three binaries in my printer, and tried a print. Temperature control and fan control a Lot better. But all my stepper motors start and stop now all going in a Strate line. Is there a Configuration change?
[[language]] ; Configuration file for RepRap Ormerod ; RepRapPro Ltd ; M111 S0 ; Debug on M550 PTricolour Mendel WIFI M551 Pgdww1620 M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEA ; Set the MAC address M552 S1 ; Enable WiFi M555 P2 ; Set output to look like Marlin M575 P1 B57600 S1 ; Comms parameters for PanelDue M906 X800 Y1000 Z800 E800:800 ; Motor currents (mA) M305 P0 R4700 T10000 B3988 ; set bed thermistor parameters M307 H0 A117.7 C395.8 D1.8 B0 ; set Heater 0 PID M307 H1 A662.1 C75.5 D5.9 B0 ; set Heater 1 PID M574 X0 S1 ; Set endstop configuration M574 Y2 S0 ; Set endstop configuration M574 Z0 S1 ; Set endstop configuration M569 P0 S0 ; Set X Axis Direction M569 P1 S1 ; Set Y Axis Direction M569 P2 S0 ; Set Z Axis Direction M569 P3 S0 ; Set E0 Axis Direction M569 P4 S0 ; Set E1 Axis Direction M558 P1 X1 Y0 Z1 ; Set Z probe type M92 X100.25 Y100.25 Z4001.50 E420.00:420.00 ; Set axis steps per unit M570 S180 ; Set heater timeout M667 S0 ; set Cartesian mode M350 X16 Y16 Z16 E16:16 I0 ; Set microstepping mode M563 P0 D0 H1 ; Create tool 0 = Color 1 M563 P1 D1 H1 ; Create tool 1 = Color 2 M563 P2 D2 H1 ; Create tool 2 = Color 3 G10 P0 X00.0 Y0.0 Z0.0 S0 R0 ; Set tool 0 operating and standby temperatures G10 P1 X00.0 Y0.0 Z0.0 S0 R0 ; Set tool 1 operating and standby temperatures G10 P2 X00.0 Y0.0 Z0.0 S0 R0 ; Set tool 2 operating and standby temperatures M106 P2 T45 H1 ; Fan control, Thermostatic on Heater H1 M106 P0 F75 B1 ; Fan control, Cooling fan M572 D0 S0.05 ; Set extruder 0 pressure advance M572 D1 S0.05 ; Set extruder 1 pressure advance M201 X800 Y800 Z15 E1000 ; acceleration tweaks for improved finish M203 X15000 Y15000 Z150 E3600 ; speed tweaks for improved finish M208 X200 Y200 Z120 ; set axis max travel M208 X0.0 Y0.0 Z0.0 S1 ; set axis minimum (adjust to make X=0 the edge of the bed) G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; relative extruder moves G31 P500 Z0.35 ; Set the probe height and threshold PLA = 0.65, ABS = 0.75 T2 M500 ;Store setting in EEPROM
@Russ:
just FYI
~Russ
Thank you!
servo's working just fine!!
https://www.youtube.com/watch?v=50i_HihgNto
so thankful for all the hard work!
~Russ
