Duet 3 6HC error short to ground reported
I have an issue with one of the Duet controllers I have that runs a hobbyist cnc.
Its probably 18mths to 2 years old and all has been fine.
Switched on today and was starting to set work zero and the error came up.
It wouldn't accept any commands as though it had lost connection. Restarted and still cannot connect. Its on a network that has another Duet 3 on it which was connecting fine. I've changed the ethernet cable from the working one to the faulty one, still won't connect and tried a couple of different devices as well, still no joy.
Any suggestions?
Thanks
Can you work through this and see how far you can get? Mainly what LEDs are illuminated on the board itself?
https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
