One more Wifi module disabled - start timed out ^^
I'm Patrick from France. I've been using Duet3D for 4 years now and have never had any issues until 2 months ago, when I started receiving the following message and couldn't connect to my WiFi:
"WiFi module disabled - start timed out"
Suddenly, the board started working again. Sometimes it was impossible to connect to WiFi, but it would work occasionally.
However, yesterday, the same problem occurred, and this time I couldn't solve it.
Based on many forum discussions, it seems my WiFi module is fried.
I tried flashing different firmwares—didn't work.
I erased the board and reinstalled using Bossa—still didn't work.
I even tried a different SD card—no success.I've run an m122 with the result below (my board was connected to my laptop with YAT, because impossible to use DWC of course)
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.4 (2024-11-24 10:43:42) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6B2-NJ4S8-6JKF6-3S86L-1A7UL
Used output buffers: 1 of 26 (11 max)=== RTOS ===
Static ram: 23488
Dynamic ram: 76508 of which 0 recycled
Never used RAM 13480, free system stack 192 words
Tasks: NETWORK(1,ready,19.9%,376) HEAT(3,nWait 5,0.0%,328) Move(4,nWait 5,0.0%,361) MAIN(1,running,80.1%,526) IDLE(0,ready,0.0%,29), total 100.0%
Owned mutexes: USB(MAIN)=== Platform ===
Last reset 00:11:55 ago, cause: power up
Last software reset time unknown, reason: User, Gcodes spinning, available RAM 10084, slot 2
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 8.1, current 9.0, max 9.3
Supply voltage: min 1.2, current 1.5, max 1.5, under voltage events: 0, over voltage events: 0, power good: no
Events: 0 queued, 0 completed
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Slowest loop: 942.67ms; fastest: 0.16ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0=== Storage ===
Free file entries: 10
SD card longest read time 250.0ms, write time 0.0ms, max retries 0=== Move ===
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
no step interrupt scheduled
Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0=== DDARing 0 ===
Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1=== Heat ===
Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0=== GCodes ===
Movement locks held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Q0 segments left 0
Code queue 0 is empty=== Network ===
Slowest loop: 1001.08ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 0 of 8=== WiFi ===
Interface state: disabled
Module is disabled
okWith M552 ;
WiFi module is disabled<LF>ok<LF>With M552 S-1
WiFi module stopped<LF>ok<LF>With M552 S0
ok<LF>
WiFi module disabled - start timed out<LF>With M587
Failed to retrieve network list: WiFi module is disabled<LF>ok<LF>With M997 S1
Trying to connect at 230400 baud:
failed<LF>
Trying to connect at 115200 baud:
failed<LF>
Trying to connect at 74880 baud:
failed<LF>
Trying to connect at 9600 baud:
failed<LF>
Error: Installation failed due to comm write error<LF>ok<LF>My board came from DOLD Mechatronik in germany, and Sarah from duet3d told the seller that I have to post so it's done mates !
Thanks for your help !
@Patrick-L thanks, as M997 S1 isn't working it appears that the WiFi module on your board has failed. Please email warranty@duet3d.com with a link to this thread.
@dc42 many thanks for your fast answer ! Will do that.
Thanks a lot !
@Patrick-L If the board is 4 years old, it's out of warranty. See https://www.duet3d.com/page/warranty-policy
