Wort investing in Bed levelling with independent Z motors?
I have a CoreXY printer evolved from a D-Bot, equipped with three lead screws for the Z-axis.
I'm considering converting it to use three independent lead screw motors. I already have the motors, but since I’m using a Duet 2 WiFi, I’m looking for the most cost-effective option to add an extra stepper driver.Recently, I bought a Bambulab P1S, and I’ve come to appreciate the convenience of greater automation in the calibration process
Thank you all
@claustro Your options are:
- a DueX5
- add stepper drivers as outlined in https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external
- a third party board like the BTT-EXP-MOT connected to the CONN_LCD connector
As to whether it's worth it, some swear by having only 1 Z motor driving 3 leadscrews, and never having to change the bed level. However, many machines now do come with three (or four) Z motors.
@droftarts thank you very much for your comprehensive answer.
I didn't know about the BTT-EXP-MOT option, it seems a very cheap option. Does it have some problem I can incur using it?
I could use it to drive my single extruder letting the duet drive the 3 lead screws. Will still be possible to use a panel due connected with a 4-wire connection?Andrea
@claustro said in Wort investing in Bed levelling with independent Z motors?:
You do need to buy drivers for it, not just the bare board. As far as I'm aware, it only supports two drivers when connected to CONN_LCD. @jay_s_uk may know better than me (I've never used one), and I think @oliof may have used one.
Yes.
@droftarts I actually got the Duex5 from you and never gave the mot exp a chance in the end (-: And then I upgraded to a Duet 3 mini 5+ with the +2 board; only to switch in toolhead toolboards which made managing the IDEX machine so much easier ...
@claustro as @droftarts said, you'll need drivers for it. You'll also only be able to use them in standalone mode, so no UART/SPI. So you'll need drivers where you can set the driver current using a potentiometer
@jay_s_uk
thank you all ,
Can I use a DRV8825? I have several available. Am I correct in thinking that using the expansion board for the extruder won't affect performance, even if a less capable driver is used -
@claustro that should work.
@claustro two caveats about using a DRV8825:
- It supports only x16 microstepping AFAIR. This isn't a problem if your extruder has a large steps/mm (e.g. 300 or more at x16 microstepping), however extruders with low steps/mm (e.g. 100 at x16 microstepping) benefit from using higher microstepping.
- Check that the DRV8825 can use 3.3V signal levels on the step, direction and enable pins.
@dc42 thank you for your answer helpfull as usual
Can you suggest me a fully compatible driver just in case?
Thank you
Andrea
