Manual Extrusion not working
Hi All, trying to get my printer up and running after a long time of not using it.
I never used to have a problem manually extruding, but it doesn't seem to work anymore.
03/10/2024, 19:42:52 m115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:0303/10/2024, 19:42:15 m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F2MS4-7J1F8-3SD6N-KHT8F
Used output buffers: 3 of 24 (12 max)
Static ram: 23876
Dynamic ram: 75072 of which 80 recycled
Never used RAM 15388, free system stack 164 words
Tasks: NETWORK(ready,14.4%,237) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,85.4%,441) IDLE(ready,0.1%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:38:36 ago, cause: software
Last software reset at 2024-10-03 19:03, reason: User, GCodes spinning, available RAM 15496, slot 0
Error status: 0x00
Step timer max interval 0
MCU temperature: min 28.0, current 28.4, max 29.4
Supply voltage: min 24.2, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2024-10-03 19:42:13
Slowest loop: 12.37ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.8ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.75ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address 84:0d:8e:b3:b4:98
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24120
WiFi IP address 192.168.0.2
WiFi signal strength -68dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 18 2020 09:46:25 GMT+0100 (British Summer Time); General preferences
M550 P"BLV mgn Cube" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes backwards
M92 X160.00 Y160.00 Z400.00 E418.00 ; set steps per mm
M566 X720.00 Y720.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X350 Y445 Z350 S0 ; set axis maxima; Endstops
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
G31 P25 X28.5 Y-5 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:285 Y15:285 S20 ; define mesh grid; Heaters
M307 H0 B0 R0.811 C653.0 D4.65 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M307 H1 B0 R5.298 C98.0:67.3 D3.29 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossI am at a loss!
M563 P0 D0 H1 F0 seems to be right?
M302 states that cold extrusion is prohibited, but as per attached, T0 temp is well above the 160 degC minimum, but the manual extrusion buttons are greyed out.What am i missing?
Many thanks in advance
- WiFi -
Where do i need to type it?
where …
As I wrote: at the end of your config. Place it above or below the 'Miscellaneous' section.
@wharris87 you need to have a tool selected in order to extrude. If you have just one tool then it's common to select it at the end of config.g.
Ah, that simple! Thanks, will give it a try
@dc42 said in Manual Extrusion not working:
Looking at the config.g of @wharris87, that's the obvious cause. However, on the DWC screenshot, the tool "Heater 1" is active and at temperature, but the extrusion controls are dimmed nonetheless. So possibly, something else is going wrong. Maybe some unlucky mismatch of DWC and RRF versions? For personal reasons, I am not that familiar with RRF 3.1.4 (specified version of the configuration tool) to 3.3 (from the M115 report) - can you recall any issues related to that?
@wharris87 @infiniteloop The heater may be active, but the tool isn't. The tool is highlighted when it is active. Subtle difference, I know. See https://docs.duet3d.com/en/User_manual/Reference/Duet_Web_Control_Manual#selecting-a-tool
@droftarts Thanks for your correction - subtle as always
@infiniteloop Adding T0 in did the trick.
Many thanks for the swift support and guidance!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
