Connecting Omron EE-SX672 to Duet 3HC Board
Hi everyone,
I’m looking to connect an Omron EE-SX672 optical NPN micro sensor to my Duet 3HC board. I’m supplying the board with 24V, and the sensor requires an input voltage of 12-24V. Is it possible to draw power for the sensor from the GND and V_Fused pins on the Duet and connect only the sensor's output to IO0.in (green marked pins)?
Thanks in advance for your help!
Best regards
Oskar -
@OskarP yes you can do that.
@dc42 Perfect. Thank you very much for your fast reply!
@OskarP another way is to connect the 3 wires of the sensor to the Voutlc, Gnd and Tacho pins of a 4-pin fan connector. The tacho pin can be used as a normal digital input.
@dc42 That is an even cleaner solution. Thanks for the suggestion.
Best regards
Oskar
