Duet 2 WiFi w/ Duet Accel - No Accel Found?
So I have the Duet accel mounted between my nozzle and heat block as such (Origin is rear right from this picture, x axis switch on right, y axis up front)
I have the supplied ribbon cable connected to the "Temp Daughterboard" header. I assume correctly, otherwise would the LED light up?
My M955 in config.g is
M955 P0 C"spi.cs2+spi.cs1" I60I have the Input Shaping plugin installed and activated, but when I go to run a "record motion profile", it says "No accelerometer found!"
WHY?
(the 123 block is to offset my Z zero so the board wont crash into the bed when the bl touch tries to home)
@APynckel What firmware version are you running?
https://docs.duet3d.com/Duet3D_hardware/Accessories/Duet3D_Accelerometer#firmware-notes
Firmware notes
Duet3D Accelerometer v0.2 is compatible RepRapFirmware v3.4.6 or v3.5beta4 and later
Duet3D Accelerometer v1.0 is compatible RepRapFirmware v3.5.0-rc.2 and laterIan
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.5 (2022-11-30)
Duet WiFi Server Version: 1.27 -
@APynckel ok, and what version accelerometer? It’s on the PCB.
@droftarts said in Duet 2 WiFi w/ Duet Accel - No Accel Found?:
says v1.0
@APynckel upgrade your firmware to 3.5.2 then
@jay_s_uk Seems to have fixed it. Through my input shaping graph looks very strange, no big peaks
