Duet 3 Motor 23 CL torque curve
I am constructing a custom 3D printer. Please provide a
torque curve (torque at different speeds)
for the Duet 3 Motor 23 CL to check if that one is suitable.
https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Motor_23CL
I did not find any via the above link.
undefined abraxas marked this topic as a question
btw: "1,26kg/cm" as a holding torque found via above link is not a valid torque unit
if we assume "1,26kg*cm" at 9,81N/kg is meant, then this value translates to a valid torque of 1,236Nm.
@abraxas here is the torque curve for the 76mm long motor on which the M23CL-76 motors are based, measured at 2A current with 24V power. With 48V power the drop-off will occur at higher speed.
@dc42 Thank you very much
undefined abraxas has marked this topic as solved
undefined abraxas referenced this topic
