Rambo 1.4 power supply to Duet 3
Just when I think I have asked all the stupid questions, I have another.
My Rambo 1.4(24v) board has 6 wires from the power supply. The supplies are separated into Heated bed, Logic, and motors. The Duet 3 is just looking for 12v-24v +-(two wire connection).
How do I go about wiring this up, correctly?
@Theboz1419 I assume it's a Duet 3 Mini if it has only two VIN terminals. In which case, you can just connect the 24V V+ and V- terminals of the PSU to Duet VIN+ and VIN gnd using two wires.
If you want to use the same PSU output cable, first make sure that all 3 supplies are connected together at the PSU end (i.e. the PSU provides a single output, not 2 or 3 separate ones). Then crimp the 3 ground wires into one fork terminal and crimp the 3 positive wires into another, and connect these to the Duet VIN terminals.
If it's a Duet 3 MB6HC then that board has a separate VIN input for the bed.
@dc42 wow, I am actually impressed with the Duet Forums. The quickness of getting answers to questions is awesome, Thank you.
I have the Duet 3 mini wifi. I figure that was probably my answer to my question was to just group them up, and if I had my multimeter available I probably wouldn't need to ask the question, but I wanted to be sure or it was going to drive me crazy and I wouldn't get much sleep, lol.
Thanks again for the fact response
