does duetpi support firstrun.sh?
As per title, firstrun.sh doesn't seem to execute on duetpi (I've been using latest image 2024 04 19 duetpi - full not lite, and I've tried 32 and 64 bit versions)
It will get edited to change the directories as appropriate (from /boot to /boot/firmware), but nothing included in the files seems to execute, and the file does not self delete.
Is this intended behaviour or is something going wrong?
I've attempted to add test echo's to a test file just see if anything in it gets run, and those aren't produced either.
@jhalewood It has worked fine for me a number of times - setting user name and credentials and self-deleting. I've used the lite image, mainly 64 bit but once or twice 32 bit.
@jhalewood It works just fine but note that the RPi imager also adjusts cmdline.txt AFAIK. I guess you need to do the same as well.
