Can you help , wifi issues
somehow both heaters and temp sensors are linked , i control 1 it affects the other
20= tool board "can" address; Sensors ;nozzle M308 S0 P"20.temp0" Y"thermistor" A"Nozzle" T100000 B4388 C7.06e-8 ; configure sensor #0 ;bed M308 S1 P"temp2" Y"thermistor" A"Bed" T100000 B4388 C7.06e-8 ; configure sensor #0 ; Configure sensor #0 for the nozzle on temp input 0configure sensor #0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ;-------------------------------------------------- ; ; Nozzle M950 H0 C"20.out0" T0 ; create heater #0 for the nozzle M140 P0 H0 M143 H0 P0 T0 C300 S0 A0 ; configure nozzle heater monitor ; Heaters BED M950 H1 C"out0" T1 ; create heater #1 for the bed M140 P1 H1 ; assign bed heater to heater 1 M143 H1 P1 T1 C100 S0 A0 ; configure bed heater monitor ;------------------------------------------- ; Fans M950 F0 C"20.out1" ; create part cooling fan M106 P0 S0 L0 X1 B0.1 ; configure fan 0 M950 F1 C"20.out2" ; create hotend cooling fan M106 P1 S0 L0 X1 B0.1 ; configure fan 1 ; Tools M563 P0 S"Evo" D0 H0 F0 ; M563 P0 S"Evo" D0 H1 F0 ; create tool #0 M568 P0 R0 S0 ;M563 P1 S"Bed" H1 F0 ; M563 P0 S"Evo" D0 H1 F0 ; create tool #0 ;M568 P1 R0 S0
Can you send M122 and M98 P"config.g" and post the results?
Can you upload your full config.g?
I notice you have an extra space in your tool definition.
Also, you do not create a tool for the bed.
Does your DWC version match your firmware version?
@Richard-F said in i have no idea:
; Nozzle
M140 P0 H0
M143 H0 P0 T0 C300 S0 A0 ; configure nozzle heater monitor; Heaters BED
M143 H1 P1 T1 C100 S0 A0 ; configure bed heater monitorYou have defined both the 'Nozzle' and the 'Heaters BED' as bed heaters with M140. Remove the
M140 P0 H0
in the Nozzle configuration.Ian
@droftarts Hi Ian , that worked, thanks, I'm still getting my head around how the code works. i was trying to figure it out myself for hours, lol .. But we learn .. Thanks again Ian
im always getting this M552 Error . im not sure why , and connection keeps dropping out. i don't think it's my network
or signal strength; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3 on Thu Mar 14 2024 13:43:02 GMT+0000 (Greenwich Mean Time) ; General M550 P"Duet 3" ; set hostname ;M911 S19.8 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ; Network M552 S1 M587 S"HeX" P"Spyder30" ; configure WiFi adapter M586 P0 S1 ; configure HTTP ;------------------------------- ; LED Strips ;M950 E0 C"io1.out" T2 ; configure LED strip #0 ------------------------------------- ; Smart Drivers M569 P0.0 S0 D3 V3 ; driver 0.0 goes forwards (X axis) M569 P0.1 S0 D3 V3 ; driver 0.1 goes forwards (Y axis) M569 P0.2 S0 D3 V3 ; driver 0.2 goes forwards (Z axis) M569 P20.0 S0 D3 V3 ; Motor Idle Current Reduction M906 I50 ; set motor current idle factor M84 S50 ; set motor current idle timeout ;-------------------------------------- ; Axes M584 X0.0 Y0.1 Z0.2 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X1000 Y1200 Z1000 ; set axis driver currents M92 X80 Y80 Z400 ; configure steps per mm M208 X0:300 Y0:215 Z-3:160 ; set minimum and maximum axis limits M566 x20 Y10 Z20 ; set maximum instantaneous speed changes (mm/min) M203 X7000 Y6000 Z500 ; set maximum speeds (mm/min) M201 X350 Y300 Z25 ; set accelerations (mm/s^2) ;------------------------------- ; Extruders M584 E20.0 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E900 ; set extruder driver currents M92 E397 ; configure steps per mm M566 E800 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E1000 ; set accelerations (mm/s^2) ;------------------------------------ ; Kinematics M669 K0 ; configure Cartesian kinematics ;---------------------------------------------------------------------------------------------------------- ; Endstops M574 X1 P"!io5.in" S1 ; configure X axis endstop M574 Y1 P"!io6.in" S1 ; configure Y axis endstop M574 Z1 P"!io0.in" S1 ; configure Z axis endstop ;------------------------ ; Mesh Bed Compensation ;M557 X25:175 Y25:175 S40:40 ; define grid for mesh bed compensation ;------------------------------------------------- ; Sensors ;nozzle M308 S0 P"20.temp0" Y"thermistor" A"Nozzle" T100000 B4388 C7.06e-8 ;bed M308 S1 P"temp2" Y"thermistor" A"Bed" T100000 B4388 C7.06e-8 ; ;-------------------------------------------------- ; Nozzle M950 H0 C"20.out0" T0 ;M140 P0 H1 ; create heater #0 for the nozzle M143 H0 P0 T0 C0 S300 A0 ; configure nozzle heater monitor ; Heaters BED M950 H1 C"out0" T1 ; create heater #1 for the bed M140 P1 H1 ; assign bed heater to heater 1 M143 H1 P1 T1 C0 S100 A0 ; configure bed heater monitor ;------------------------------------------- ; Fans M950 F0 C"20.out1" ; create part cooling fan M106 P0 S0 L0 X1 B0.1 ; configure fan 0 M950 F1 C"20.out2" ; create hotend cooling fan M106 P1 S0 L0 X1 B0.1 ; configure fan 1 ;-------------- ; Tools M563 P0 S"Evo" D0 H0 F0 M568 P0 R0 S0
@Richard-F remove the M587 line from config.g -- the wifi module stores these values and M552 S1 is sufficient in config.g to start it up.
@oliof
thank you
, i wasn't sure
